Question about Foxpro Spitfire Digital Predator Call
My spitfire has no sound
Possible problems
1974 truimph spitfire mk4 firing order
Edward, Firing order 1-3-4-2 for spitfire. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Engine Tuning Data for the Triumph Spitfire and GT6
Distributor drive gear and firing order question Spitfire GT6 Forum...
getting spark plug wires back in the right order MGB GT Forum MG...
http://www.repairservicemanuals.com/Triumph
Jun 14, 2016 | Triumph Cars & Trucks
Yamaha cart Motor makes a buzzing sound when accelerator is pressed. Will not run.
PDF]POWERED MOBILITY - Drive Medical
www.drivemedical.com/osc/catalog/catalog-pdfs/sections/Power.pdf
If you answered yes to any of these questions, then look no further. ... and electricalbreakdowns or defects in material and workmanship for up to 14 months from the ...Just call the PowerCare™ Hotline for your power mobility ... Bobcat™. 3 Wheel Compact Scooter. S38600. Red, 1/cs. S38601. Blue, 1/cs ..... SPITFIRE 1410.
Sep 09, 2015 | Electric Mobility Blue Spitfire 1410 ...
I have a technical question about the SU carbs of my 1966 Triumph Spitfire MK 2.
the little plastic /rubber bit has come off the shut off valve ,although you have no doubt found this out by now .
Aug 20, 2015 | 1966 Triumph Spitfire
My active care 1420 spitfire scotter wont start an is blinking green
You need to consult the owners manual to determine what
the blinking light means. It will flash from 1 to 9 times and
repeat the cycle. Count the number of flashes and refer
to the manual to see what the problem is.
Jun 30, 2015 | ActiveCare Spitfire EX 4 Wheel Travel...
Spitfire problems
sounds like the diff is at fault
Jun 29, 2014 | 1975 Triumph Spitfire
I need a transaxle for a 1410 spitfire scooter
TRANSAXLE FOR SPITFIRE 1410 SCOOTER POWER CART.
CALL 803 - 749 - 4449 = ACTIVE CARE MEDICAL INC.
TELL THE SECRETARY YOU WANT TO SPEAK TO THE TECH-MECHANIC " JEREMY ".
HE WILL QUOTE YOU A PRICE OF $266.40 + $12.00 SH = $278.40.
DELIVERY TIME ABOUT 5 - 7 DAYS.
Sep 22, 2010 | Electric Mobility Blue Spitfire 1410 ...
Oil type
I don't know what a pope spitfire is, but the post indicates it's a pushmower -- in that case, I would use 30 W non-detergent.
Charlie
Aug 29, 2009 | Garden
1972 Triumph Spitfire, 3rd gear grinding
Jumping out of third was a common problem with the Spitfire quick changing up from forth gear would beat the syncro and chip the teeth on the drive dog then the bits would stop the syncro from engaging fully and it would jump out. If you replaced the syncro and the drive hub it may just be a bit stiff, the selector also wore quite quickly and misaligned the drive hub causing it to be hard to select.
I will scratch about in my very old manuals and see if I can find the spitfire gearbox manual, If I can I will post it.
Jul 30, 2009 | 2006 Triumph Tr 7
Foxpro Spitfire Digital Predator Call Logo
Top Foxpro Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Foxpro Audio Player and Recorder Expert? Answer questions, earn points and help others
