Question about RCA L42WD22 42 in. LCD Television
I HAVE A RCA 42" LED TV. I RECEIVE MY SIGNAL FROM AN ANTENNA. I CAN ROTATE MY ANTENNA, SCAN THE TV FOR CHANNELS, AND THIS WORKS FINE. THE PROBLEM IS IF I HAVE TO ROTATE THE ANTENNA FOR OTHER CHANNELS, AND THEN RE-SCAN, THE TV LOSES THE ORIGINAL CHANNELS STORED IN MEMORY. IS THERE ANY WAY TO MANUALLY ADD CHANNELS TO THE TV, SO THAT ALL YOU HAVE TO DO IS ROTATE THE ANTENNA TO THE DESIRED CHANNEL, WITHOUT HAVING TO RE-SCAN THE TV AGAIN. ALSO, MY TV DISPLAYS THE TIME IN MILITARY TIME IN THE TV GUIDE DISPLAY. IS THERE ANY WAY TO MAKE IT DISPLAY IN AM / PM TIME INSTEAD.
    Problem Solver:
  • 13 Answers
On B:Press the MENU button on the remote.Select Setup.Select Auto Program.Choose Air or Cable.Select Auto Program to let the TV reprogram the channels.Check that the channel is programmed into memory. There are a couple of ways to do this: Use the TV menu system. Accessing this setting varies depending on the model TV that you own. Here are two options that are common on many TV's: Option A:Press the MENU button on the remote.Use the VOL and CH buttons to move through the menu and add any missing channels try this if not r
Do a full reset if this dosnt work
Posted on Dec 25, 2013
  • 718 Answers
SOURCE: have a 42 in rca lcd tv ,hsound but no picture
IF the set is under warranty, you should return it.
Do this to see if your set is "sending" the image to the LCD panel.
1) What the set on take a bright flashlight and press it against the screen.
2) Look for the "image" moving around the edge of the flashlight.
3) If you see the "image" then the problem is in the inverter/CCLT or the power to it.
4) If you do not see the "image", you should look at the LCD controller(TCON) for the problem.
Posted on Feb 25, 2009
  • 86 Answers
SOURCE: no signal display on rca 42" lcd
If you have tried other input jacks and cables with the same result, then yes, the input/output board is defective or buggy.  Sometimes a power drain can clear this up as well so it's worth a try:
1. Unplug the product's power cable so the device is not grounded to the house. 2. Press and HOLD the product's own power button for 1 minute to drain the capacitors. 3. Plug the product back into a wall outlet and try to turn it on.
Note: This procedure works with battery operated devices as well so remove the batteries and hold down it's power button.  Electricity can remain in capacitors and on circuit boards enough to prevent normal functionality. By clearing the residue electricity, your product will have a fresh start and many times this will resolve a buggy or non-responsive device that appears to be dead.
If this doesn't resolve it, service would be necessary.
Posted on Mar 25, 2009
SOURCE: I just purchased the RCA model L32HD31R.
I had the same problem and finally sloved it. You have to leave the input channels ( Vid1, Vid2, SVid, Cmpt, HDMI, etc ) in the In Channel List. So push the INPUT button, go to VID1, press Menu, go down to List & Labels then check In Channel list. Do this for all the inputs and then run your Channel search again. I hope this works for you. It did for me.
Posted on Jun 24, 2009
  • 8457 Answers
SOURCE: 42 RCA TV flashing unusable signal
Ur backlight video board it dead,must replaced.
Posted on Dec 05, 2009
  • 8457 Answers
SOURCE: RCA LCD TV L42wd22YX5 - Gets unusual signal to all inputs
Tries Ebay.com,Shopjimmy.com for used signal tuner main board.
Posted on Jan 07, 2010
I bought an RCA smart tv and it was working fine until I picked up the RCA remote to change channels and now I get "no signal" on my TV screen. How do I fix this?
What was going on before you picked up the remote? Did the remote work OK to initially turn on the TV? Where you able to change channels prior to this issue? If yes, then maybe you accidently changed the source mode of the TV via the remote?
The source mode button chooses what signal you want to use for getting a signal transmitted to your TV (E.g., antenna, HDMI, etc.) If the source button is clicked to something that is not supported (E.g., Line1, or Line2, or Line3, or a particular source like the antenna option is not set-up properly to receive a signal, then you will receive a, "no signal" message".
I
Dec 14, 2016 | RCA Televison & Video
19" Element HD Digital LED TV Model ELEFW195 Does not scan Digital Channels just Analog Channels.
Auto-channel search can't find digital channels - Community ...
community.insigniaproducts.com/...channel...can...digital-channels/.../13...
Aug 6, 2010 - When I ran the auto-channel search it could only find 4 analog ... Notgetting Digital Channels on NS-26L450A11 ... I've plugged the cable from the wall into the TV, and preformed the auto channel scan, with "cable" selected.
Troubleshooting Guide for Digital-to-Analog Converter Boxes
https://www.fcc.gov/.../troubleshoo...
Federal Communications CommissionIf you aren't receiving digital signals on your analog TV, you can purchase a ...antennas are designed only for reception of either VHF or UHF signals (but not both). ...The channel scan will automatically search for digital broadcast channels ...
Antennas and Digital Television ' Federal Communication
Jan 13, 2016 | Televison & Video
How to reset rca tv
Hmmm, if you're using an antenna then go into the menu on the TV and hit the Scan for channels button. If it's a Cable box then make sure it is connected correctly and on the right input.
Aug 22, 2014 | RCA L42WD22 42 in. LCD Television
Why can't we get a channel of our bought television?
First, is the antenna to which your TV is hooked up working? Are the other three on you block receiving TV channels? The signal from the antenna has to be split four ways, so you need to use a four-way signal splitter and probably a signal booster/amplifier. It is probably wise to have a professional TV antenna installer at least access your setup and make suggestions.
May 12, 2014 | Sony KDL55EX620 55 inch BRAVIA 1080p LED...
Hello, I bought an ONN TV #LE-22G90 a few months ago and I can't receive any digital channels. My time zone is: Eastern time (I live near Sherbrooke, Quebec, Canada). The tuner mode is: Antenna. I...
I bought the same TV wich is in fact a Seiki TV, see the warranty paper. The television has digital and analog tuners so is able to receive digital channels.Our television receive signal thru a rabbit ear antenna and we had some trouble to scan all the digital channels. We had to change the orientation of the antenna to receive correctly the signals and we had to scan many times. We finally conected the TV to a roof antenna so we where able to scan all the channels of Montreal, north Vermont and north New York areas since we are living in the south shore in front of Montreal. After the scan was completed we conected back the TV to the rabbit ear antenna and the television is working correctly receiving all the stations of Montreal area with a very good picture quality.
Claude
Sep 07, 2011 | Televison & Video
LG 42LB5D-UC cannot find channels when scanning
No,Ur Digital antena not getting a good signal,because of lanscape like hills or big buildings,blocking the signal,that why u not getting good signals,or no signals at all.Buy another name brand digital antena with a stronger signal amplifier.Or buy a digital roof antena,well help or solved these problems.
Mar 20, 2010 | LG 42LB5D 42 in. LCD Television
I am in Los Angeles,Ca. Converter box signal problem
Just go to walmart and buy a good digital antena.Should work great.Just rescan all ur channels again.
Mar 11, 2010 | Digi Sansonic FT-300A tal To Analog TV...
Toshiba 46HM95 wont display 720p from dtv antenna other tv works
lets start with the easiest first.does your tv in the menu option offer an input output source like 720p or 480p?on my set i can change to any format.maybe yours does too.let me know and we go from there.
Mar 04, 2010 | Toshiba 42H81 42" Rear Projection...
Digital Visio 42" LCD TV stopped receiving digital TV
Check all your connections in the back, if they're all good replace the main board in the tv.
Aug 22, 2009 | Televison & Video
RCA L42WD22 42 in. LCD Television Logo
144 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
