Question about Gateway NV5207u Notebook
Wont connect to wifi
I just received a gateway nv 5207u for Christmas and we cannot get it to connect to wifi. We entered the DEP key code and WAN code on back of the router. It picked it up immediately but when we click to get on internet it says that its not connected. What do we need to do..I want to use my present!!!!!
  • Connie Gresham
    Connie Gresham Dec 25, 2013
    Thats a gateway nv570POu, sorry. Please, someone,,,,,
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 544 Answers
It is possible that your router is not connected to the interent.
Call your internet service provider for assistance.
Posted on Dec 25, 2013
3 Suggested Answers
tanvierahmed
  • 118 Answers
SOURCE: gateway laptop was connecting to internet wirelessly, not now
Check that if there is Static ip configured on your Lan-Card...
if yes.. then you need to configure the IP addresses manually for W-LAN as well.
One more thing; if Lan-card is not configured with static IP then
make sure your W-lan IP seting is on "obtain Ip automatically"
Here is the way to do this....
Click on the start orb to open a list of programs and content. The start menu has been replaced by the “start orb” which still gives you the same functionality as the start button from previous OS versions, but consumes less screen real estate.
Right click on “Network” and go to properties. That opens the “Network and Sharing Center” which is your central office for anything pertaining to (just as it says) networking or sharing resources.
On the left hand column you want to click on “Manage Network Connections.”
This opens the Network Connections Window which you will find familiar to Windows 2000/XP. It will list all of your NICs or Wireless Connections.
Right click and go to properties of the connection you would like to statically assign. You will now be prompted for an administrative password. This is part of Microsoft’s new User Account Control (UAC) which will help unauthorized changes to your systems.
Once you have authenticated you will see the properties of the selected network connection.
The properties screen is very similar to what you’ve seen in the past, but one thing you will likely notice is by default Windows Vista supports IPv6. If you’re on a corporate or government network that is running IPv6 you can fill in your IP information there.
Otherwise, you will select Internet Protocol Version 4 (IPv4) and click properties. Now you will be able to Choose the option "Obtain Ip adress automaticlay"
Close the Network Connections Window
Let me know if this helps.. Good luck...
regards,
Posted on Dec 04, 2008
bozape
  • 44 Answers
SOURCE: my wireless laptop gateway won't connect to my
Hi!
It is possible that the wifi networking where you connect in the Hotel use the same name of you home wifi network!
Try deleting your wifi profiles and reconnect again.
If you don't know how to delete the wifi profiles let me know and I tell you.
Thanks!
Posted on Feb 18, 2009
Connects to wifi but wont respond
Have you entered the router code?
Dec 25, 2013 | Gateway NV5207u Notebook
How to install the router
onfigure your router with below method then all messup will be fixed. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on WAn settings and set wan settings as internet service provider settings. Then click on wireless settings then enable wifi also enter SSID name and enable broad cast turn on wifi . If you want to secure wifi then enable WEP in wireless security .Enter code it is your password to connect wifi. Then connect internet cable to WAN port then you can use internet with it. Let me know if you need further assistance. Thanks for using FixYa.
Aug 07, 2010 | Encore 802.11G WIRELESS LAN ROUTER...
What do I need to make this WI Fi
First make sure wifi switch on laptop is turned on press Fn key +F5 then turn on wifi power . Make sure wireless network driver installed and enable in network settings. Check wireless led on router it should be on. Access your router with below method . If all settings of wifi router are fine then RESET it to defaults. For that press RESET button for 10 seconds it is in back side of router. Then configure it again with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on WAN settings and set as your internet service provider settings enable wireless .If you want secure wifi then enable WEP security in wireless security then enter code it is your password for connect wifi. Let me know if you need further assistance. Thanks for using FixYa.
Aug 04, 2010 | Intel Computers & Internet
It stopped all of a sudden getting signals from the wireless system from the router and desktop I have in my office.
Reset your router to factory default settings for that press RESET button for 10 seconds it is in back side of router then all settings defaults.Then configure your router with below method then all messup will be fixed. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on WAn settings and set wan settings as internet service provider settings. Then click on wireless settings then enable wifi also enter SSID name and enable broad cast turn on wifi . If you want to secure wifi then enable WEP in wireless security .Enter code it is your password to connect wifi. Let me know if you need further assistance. Thanks for using FixYa.
Aug 04, 2010 | Compaq Computers & Internet
I brought new wireless router G ADSL2 4 PORT ROUTER but i dont know how to fix
Configure your router with below method then all messup will be fixed. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on WAn settings and set wan settings as internet service provider settings. Then click on wireless settings then enable wifi also enter SSID name and enable broad cast turn on wifi . If you want to secure wifi then enable WEP in wireless security .Enter code it is your password to connect wifi. Then connect internet cable to WAN port then you can use internet with it. Let me know if you need further assistance. Thanks for using FixYa.
Aug 04, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
When i try to connect to the internet by wifi it will not do it
Aug 04, 2010 | Computers & Internet
Same problem
Aug 03, 2010 | Computers & Internet
Wan connection
In newer laptops, turning on the WAN (wifi) radio receiver is done via keyboard key combination.
Look closely at the function keys. Do you see any wifi radio icon printed in orange or any color that is not similar to the normal key color? In some model, a wifi icon (looks like a wave like ")))" is in F2. Now pressing FN+F2 turns the wifi ON. Press and hold down the FN key and press F2 (or the key where the wifi icon is printed) to turn on your WAN.
Feb 08, 2010 | Acer Aspire 3000 Notebook
Can't remember 13 digit WEP code for Linksys router. I am creating seperate accounts on Windows XP laptop and each account has to have a seperate setup to get to the router. How to find the original WEP...
hi dear
try this
On windows
Start-->Run
cmd
ipconfig /all
write down the IP address of the Default Gateway on your Local Area Network Adapter.
Open your web browser and type http://{IP address of Default Gateway}
ie http://192.168.0.1
The Web Administration Username and Password should be
Username: admin and the Password should be left blank by default.
Enable the DHCP server on the router. Save the settings.
Now enable the Wireless radio and give it a name (SSID) and use encryption (64-Bit WEP is sufficient). Give it a 5 character password and REMEMBER IT (make it easy to remember like the first 5 digits or your phone number or your street address). Save the settings and the router should reboot.
Now plug the WAN the cat5 cable into the modem and then other end into the router's WAN port. Cycle the power on the router.
Wait about 30 seconds.
Go to the laptop of WiFi desktop and enable the WiFi connection and scan for WiFi networks. Connect to your (the SSID you entered) then type in the password and you should be good.
You can always use a cat5 ethernet cable and plug it into one of the 4 switch ports on the router to get a more reliable connection.
oke
cropp
Mar 22, 2008 | Computers & Internet
Gateway NV5207u Notebook Logo
63 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
