Question about Dishwashers
Blomberg dishwasher On /off button - nothing happens when try to turn dishwasher on, no lights come on nothing
  • 1,511 Answers
Check your line fuse, circuit breaker, and/or ground Fault switch at the wall outlet. If they are OK; then a technician needs to do some troubleshooting techniques in you home to see if the panel circuit board is at fault.
Posted on Dec 25, 2013
SOURCE: Whirlpool GU2548 green light flashing, nothing working
I have had the same problem with my the same dishwasher. The manual says that "the dishwasher has malfunctioned. Call service to check heater element". I called service and they are saying that replacing the heater element and possibly the electronic panel may be required. Total cost (part + labor) = $350-400!! I am very very upset with Whirlpool right now.
Posted on Oct 09, 2007
  • 338 Answers
SOURCE: Kenmore 24 in. 17842 dishwasher heated dry light blinking
you have a shorted keypad. you will need to replace it. you can get parts at jacobyparts.com
Posted on Dec 01, 2008
  • 423 Answers
SOURCE: Dishwasher does not turn on
I believe if you look closly, you will see the G is actually a Q. So the valid model number is DU980QPDQ3.
This model has a controller module (CNTRL-ELEC $188.00 US) that includes the buttons in the door panel. The logic/control begins there and communicated with the display and the timer/timer motor.
Depending on the age of the unit, you need to choose between repair or replacement. Good Luck!
Posted on Apr 01, 2009
  • 7 Answers
SOURCE: My dishwasher will not start. The 3 second button
It sounds like you have "locked" the dishwasher. This was an added feature that most people never wanted since it only seems to be set by accident.
Try pressing the 3 second button and holding it down for at least three seconds. This should turn the light off. Drove us nuts the first time it happened. If it doesn't turn off then I guess it is broken.
Posted on Jan 23, 2010
  • 901 Answers
SOURCE: dishwasher will not start error message F3
Refer user manual. Contact service provider for assistance.
Posted on May 26, 2010
Dishwasher is powered on but and making normal start up noise but no water is entering the dishwasher and not beginning the wash cycle
My Dishwasher is a Blomberg DWT 25200 SSWS. It had the same problem. It powers up but no water enters in it and the clock didn't advance. This is what I did to fix it.
You can display the error code by powering off the dishwasher then pressing the 'Program' and 'Half Load' buttons at the same time then power on the dishwasher. This will show an error on the screen. My error was E:1.
The problem was a disconnected blue hose at the bottom of it.
This is the overflow detector.
This little board has a 12 Volt relay that activates the main water valve which is a 120 VAC valve. There was nothing wrong with it.
This plate is at the bottom of the dishwasher to hold the water that spills.
May 07, 2015 | Blomberg Dishwashers
How to reset Blomberg DWT23100W computer?
Remove lower dish basket and inspect where water drains looking for clogged inlet
Jun 02, 2014 | Dishwashers
Blomberg DWT34240 error code IF. What does that mean?
Hi, same dishwasher here, same error code. Did you or anyone find out more about this?
Thanks!!
Jan 04, 2012 | Blomberg DWT34200 DWT34210 DWT34220...
My Blomberg dishwasher will not stop draining once all the water is out. It is at the beginning of the cycle and it's like its stuck and won't move on to the next part of the cycle to bring water...
Doug Smith\'s solution of Oct. 20, 2008 worked for my Blomberg Dwt57500ss model.
Removed small filter basket by pinching 2 tabs inward at the top of the basket. Turned larger basket counter-clockwise by hand and lifted out stainless steel screen. Used wet/dry vac to suck all the water out. The anti-flood switch reset itself. Turn power back on to unit, and pressed start. Then pressed program I wanted to use and reset button to start machine. Worked immediately and started washing dishes.
Sep 05, 2011 | Blomberg Dishwashers
Our Blomberg DW-35100 is not draining. We did have a service person in who fixed the problem temporarily. He took the bottom plate off the tub and told us water was present there which raised some float,...
If your Blomberg dishwasher will not drain, it might be the same problem that I had. The filter is a bad design and it lets a lot of debris through. The hose from the dishwasher to the main drain is very small and it gets plugged. Under the sink, loosen the clamps around the hose going into the main drain and take off the dishwasher hose. I use a screwdriver to push the debris through the small hose (that is attached to the big main drain hose) into the big one where it will be carried away. Then I turn on the dishwasher, hold the start button of the dishwasher for three seconds and shut the door. It drains like magic. The first time I did this, it took two hours to figure it out and now I can do it in three minutes. I am going to write to Blomberg now and see about this terrible filter system!
Feb 12, 2011 | Blomberg 35100 24 in Builtin Dishwasher
Water is settled at the bottom. Filters have been cleaned but the dishwasher won't turn on at all. Blomberg dishwasher
My dishwasher did the same thing after a cycle was interrupted. Try putting your hand under the handle and firmly pushing against the top center of the door so the actuation of the switch is completed (the switch is in the door on my model and I suspect the actuator's travel is not getting completed).
Worked for me after pushing every combination of buttons and waiting for anything to happen.
PS: I pressed the START/CANCEL button during power up and the display showed IF for 5 secs then showed alternating H/H6. Anyone know what that means?
May 21, 2010 | Dishwashers
My dishwasher will not start. The 3 second button light is on and when I press it nothing happens . I try pressing any other button and nothing works
Jan 03, 2010 | Maytag MDB7100AWB Dishwasher
Bosch DLX series didn't drain, now no power
I had a Bosch DLX series dishwasher that had multiple problems.
First, it had greyish water in the bottom and pushing the power button did not turn on any lights. it had mostly finished a cycle, but not quite. my first thought was to clean it out. i sponged out all the water and removed and cleaned out the filters from the bottom which were all quite nasty. i found food, tiny bones, etc. I cleaned it out and that did nothing but was still probably the cause of the problem. I called Bosch tech support and asked about areset switch. There is none. They told me to switch off the circuit breaker for 30 MINUTES to reset everything. I did that which did not fix the problem.
I then examined the connector wires (connecting the electric to my house wiring) which are in the front under the kick plate, and discovered that they had MELTED! The wiring supplied by Bosch was stranded wire, and my home wiring is solid core. i trimmed the burnt stuff and reconnected it with new wire nuts. if this happens again i plan to disassemble the dishwasher's electric and replace the stranded wire with the good stuff.
That restored the electric and the lights and display. i then ran a test cycle and it seemed to just hum. my guess after googling a bit was that the float was stuck in the up position, and it was trying to drain. This site http://www.applianceaid.com/boschDW.html told me how to run the test mode.
"To start test program, press and hold both POWER SCRUB PLUS and REGULAR WASH program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button."
The test mode tested out all functions which I think wound up reseting the float switch which actually fixed the rest of it.
Sep 01, 2008 | Dishwashers
Dishwashers Logo
243 people viewed this question
Top Dishwashers Experts
Owen Barnes
