Question about Clover Corporation CDR-4070 Video Recorder
CLOVER 4570 4CH IP ADRESSABLE STANDALONE I COULD NETWORK WITH MY DLINK 524 ROUTER BUT CANT CONNECT TO INTERENET.PLEASE EMAIL nimesh4@hotmail.com
I want to secure my DLink 524 and when I put in the ip address http://192.168.0.1 web page can not be displayed
It sounds like you are trying to connect to the D-link and either you are not connected to the internet or you are connected to another network. Be sure that if you are making a wireless connection that you have selected the 'dlink' (the usual default) or whatever the name of the network (SSID) that is being broadcast by the D-link. Once you are on the same network as the D-link router, then you may navigate to the 192.168.0.1.
Jun 16, 2011 | D-Link AirPlus DI-524 Wireless Router
How do i hook up a d link wireless router? I don't have the manual.
Go on line to the manufacturer there should be an option on the home page for support and drivers. Click there, and you should be able to download everything you need to install your router.
Feb 13, 2010 | D-Link 802.11g Wireless Router WBR-1310...
2 Notebooks without router acces at the same time
Under the DHCP settings, make sure that there is enough IP addresses for the router to assign. Although DHCP is somewhat "automatic" if there is not a sufficient range of IP addresses for the DHCP server to assign, then only a small number of clients can connect. See this page here: http://support.dlink.com/emulators/di524/h_dhcp.html
Also make sure that your notebooks are not set to the same static IP address, only one device can connect to a specific IP address. To check this under Windows XP, Right-click your wireless network connection and select "Status" then "Properties". Highlight the "Internet Protocol TCP/IP" and select "Properties". Make sure that the radio buttons "Obtain IP address automatically" and "Obtain DNS server address automatically" are selected. Click OK and OK to close the windows and save the settings.
I would also unplug the router, wait 60 seconds, then plug it back in and try to reconnect. Sometimes for whatever reason, the routers memory can get corrupted, (just like a computer) and need to be restarted.
Sep 06, 2009 | D-Link AirPlus DI-524 Wireless Router
Cant connect ps3 wireless to dlink router
The router should assign an IP address to your PS3 if it isn't manually configured. If you are connecting wirelessly make sure your security setting on your PS3 match your router. If the problem persists disable wireless security on your router and then try to connect with the PS3 with security disabled as well. Sometimes consoles have trouble connecting with WEP or WPA security encryption.
Jan 06, 2009 | D-Link AirPlus DI-524 Wireless Router
Wireless network connected, no internet
check whether your computer is able to recieve an ip address wirelessly
Dec 14, 2008 | D-Link AirPlus DI-524 Wireless Router
Dlink wireless router, shows up, can't connect
the manual can be downloaded from the dlink website;
ftp://ftp.dlink.co.uk/di_broadband_gateways/di-524/di-524_manual.pdf
you are also able to get a couple of utilities from the dlink website; it's a very long link but this is the location for the relevent files.
http://www.dlink.co.uk/?go=jN7uAYLx/oIJaWVdDbgYU93ygJVYLelXSNvhLPG3yV3oVYx+g6ltbNlwaaRp7jksED2onGQTo48EE5+3n/K9K0MH8LubPtqzEMT8pnRbyctCCrpHKcCVuErk6TGEOcGXYPgp/FUnrIBfqygTYYTwlmHkgyBavmKsERo=
the formatting is messed up but just copy and paste into you web browser.
Nov 11, 2008 | D-Link AirPlus DI-524 Wireless Router
Dlink di-524 connect to RV042
Hi.
You need to cascade the Dlink wireless router to your RV042.
Suppose your RV042 has a default IP Address of 192.168.1.1, and the DLINK IP uses 192.168.0.1. Your Physical connection is from the regular port of the RV042 going to the WAN/Internet Port of the DLink wireless router.
Once you do that, your Dlink router should automatically obtain an IP from the main router. If it did, configure your wireless settings and you should be able to connect via wireless.
This is just one way to cascade your router to another router.
For more information, click here.
Jul 21, 2008 | D-Link AirPlus DI-524 Wireless Router
Router cannot get IP with cisco 675 modem
The issue may be due to the existence of two (2) DHCP servers; 1 in the Cisco 675 and the 2nd in the DLink DI-524. You need to disable the Cisco's DHCP server function and assign static IP add & config to the DLink WAN config. This way it will only be the DLink handing out IP adds to the network.
The workaround. Install your original configuration/setting without the DLink DI-524 - PC direct to the Cisco 675 (I am assuming through Ethernet ports). Verify that indeed you are connected to the Internet and can surf the net, check e-mails, etc. Check your Networking Connection Status. Log down your PC's IP Add, Subnet Mask, Default Gateway, DNS. For purposes of discussion, let's call this "N1".
After your Internet connection has been verified with your PC directly connected to the Cisco, remove the direct connection and connect the DLink DI-524 in between the Cisco router and your PC.
Log in to the DLink and modify WAN parameters using the "N1" configurations/settings.
It might be of help to disable any security (WEP WPA, MAC etc) at least while configuring.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Feb 01, 2008 | Cisco 675 Router
Router won't speak with computer
If you check your computer's IP address, is it getting one from the router? Normally out of the box these routers are setup to give out DHCP, which basically means that your computer, if also set that way (again, default) will grab any necessary info from the router (IP address, subnet mask, gateway, etc). You didn't at some point set your PC to use a static IP address that's different than the D-Link's subnet did you? D-Links default to 192.168.0.1, so your computer should be getting an IP in that range as well.
Sep 22, 2007 | D-Link AirPlus DI-524 Wireless Router
Clover Corporation CDR-4070 Video Recorder Logo
96 people viewed this question
Top Clover Corporation Televison & Video Experts
Are you a Clover Corporation Televison and Video Expert? Answer questions, earn points and help others
