Question about Viking 42" Side By Side Refrigerator - Stainless Steel - Vcsb423ss
Light bulbs burned out after leaving door ajar
We left the door open to he fridge and the bulbs burned out. Everyone says to unplug but the fridge is built in. Do you think if I shut the breaker off that it would work?
  • Jacquelyn Zito
    Jacquelyn Zito Dec 25, 2013
    So I shut the breaker off and tested one bulb. It worked! So I shut the breaker again to put the other three bulbs in and the only one that worked is the original first one that I put in. Very strange! Any help would be appreciated as this is so frustrating!
2 Suggested Answers
  • 42 Answers
SOURCE: Fridge light not shutting down, alarm on, temperature heating up
you do have a switch at the top door hinge . make the phillip screw are tight at the top of the door . if they are loose the door will not align in order make contact with that switch. or you may have a faulty light switch
Posted on Dec 21, 2008
Light not working in fridge. Replaced bulb but still not working?
Probably the door switch. With the fridge unplugged, remove the door switch (pry out with a screwdriver), short the two wires (leave the door open). Plug in the fridge and if the light is on, it's the switch.
Aug 02, 2017 | Refrigerators
Light bulb burned out
Did you have a hinge kit recently replaced? If so call them back they missed something. If not, look into the light circuit a if it goes to ground this light issue would happen. Most of these issues I found in the upper section behind the upper grills. I hope this helps
Dec 25, 2013 | Viking Professional VCBB363SS Stainless...
Door ajar warning light/interior light won't come on
Good Afternoon bibliophilel, based on the symptoms you are describing, may I suggest resetting the refrigerator. This can be done by either unplugging it or flipping the household circuit breaker off. Wait roughly ten minutes and then turn the unit back on. If the issue persists, then more than likely the light socket and/or the door switch that triggers the bulb and alarm are faulty. In this regard, I would suggest contacting an Authorized Service Technician that will be able to assist you in the exact diagnosis of the appliance and repair.
Jul 19, 2013 | Frigidaire Refrigerators
Freezer side is working fine. the fridge side appears not to be as cold as it use to be. a few days ago my kid left the door ajar all night. how ever it should be cold by now. there is power I can hearthe...
When a refrigerator door is left open the freezer will continue to run to keep it cold and since it can't cool an open area it will freeze up on the inside, to resolve this you will need to unplug the fridge and open the freezer door and allow the freezer to thaw completely, once it is thawed you can plug it back in and everything should go back to normal after a 24 hour period
Jun 28, 2011 | Kenmore Side by Side Refrigerator
Light is off in fridge and the bulb is NOT burned out
first unplug the machine then:
check the lamp scoket for flattened metal bars
if they are not touching the bulb pull them up to contact the side and, bottom of the lamp base replace the bulb and plug the machine in then:if that didn't work; if you can substitute another new identical bulb then: check again next check for a broken door switch
Apr 06, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Door ajar light stays on after i close the door
I had the same problem in my 98 and 96 Sables. Ford dealer says it is a problem with a sensor, located behind the left rear quarter panel. It doesn't recognize when the doors are closed, therefore it leaves the dome light, etc. on--sometimes briefly, but possibly until the battery goes dead. Worse when the weather is damp. Their solution was to throw it on the diagnostic computer BUT ONLY WHILE THE PROBLEM IS ACTIVELY HAPPENING, then replace the sensor--they quoted me a minimum of $300. I leave the cover off the dome light, and pull the bulb when necessary.
Mar 15, 2009 | 1996 Mercury Sable
Whirlpool gold refridgerator light not working and is making funny noise
I had the same problem. Model Number GS5SHAXNL00 Light wouldn't work on the fridge side and the led's wouldn't light up. Ended up being a blown circuit path on the control board.
All I did was soder a wire between the 2 points that path was connecting and *BINGO* the lights are back on!
Hope this helps someone. To find the burned out spot just look for a little black smudge on the white plastic case when you remove the board.
Feb 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Fridge bulb burns out in fridge side
check to see if the light is turning off when you close the refrig door. its possible the door is out of adjustment and is not hitting the light switch properly when the door closes
Dec 12, 2007 | Kenmore 53642 / 53644 Side by Side...
Viking 42" Side By Side Refrigerator - Stainless Steel - Vcsb423ss Logo
Top Viking Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
