Question about HP Computers & Internet
My mouse only works if I push the cord hard against the mouse?
For my mouse to work, I have to push the cord (strongly and occasionally at the right angle) into itself to work. Otherwise, it won't connect to the computer at all. I suspect the cord was pulled too hard and has come loose. Is there anything I can do or must I buy a new one?
    Sergeant:
  • 302 Answers
Buy a new one, they are really cheap and not worth mucking around with
Posted on Dec 26, 2013
SOURCE: Wacom Mouse XC-100-03 Right click doesn't work
Greetings,
You can buy any other style or brand of mouse and it will work right along side of the Wacom. I chose to keep my Logitech wireless mouse after installing my Wacom tablet because it provided a better feature set (i.e. more buttons ). I have had no issues. Please rate me well if this helped.
Take Care,
-WN
Posted on May 06, 2008
cTech1
  • 66 Answers
SOURCE: wireless mouse problem
This mouse needs to be synched up with its base.
Press the button on the base, then press the button on the bottom of the mouse. After this, when the light flashes on the base, it is synched and should work again.
Posted on May 15, 2008
  • 57 Answers
SOURCE: Microsoft Mouse Wireless Model 1023/1024 won't work
try using an eraser on the contacts if you can reach them. Sounds like dirt/corrosion build-up.
Posted on Aug 04, 2008
wmsfarris
  • 22 Answers
SOURCE: how do i get my wireless mouse to connect with my laptop
Do you have a wireless keyboard also. It may be the reciever.
Posted on Apr 06, 2009
SOURCE: cordless Logitech optical mouse scroll wheel stopped working
in fact this one is one of my Favorite Combo set, change with the the fresh bettery, link the mouse again, clean the mouse wheel with the cleaner I think it'll work.
Posted on Jul 02, 2009
My water heater hasn't seemed to work right since our new house was built 7 years ago. It doesn't seem to heat right most of the time. Once in a while, just occasionally it will work right and put out hot...
make sure the thermostat is pushed tight up against the tank, any gap between the tank and back of thermostat will cause erratic operation
Mar 04, 2010 | Hammering
Freezes up often. USB comes on says its malfunctioning. Anything I can do this mouse isnt that old
I see this caused a lot of the time by a bad wire within the cord. If you are good with soldering and circuit boards you can replace the cord. But getting a new cord is the fun part, you can usually take it out of another device. Sometimes for a temp fix, you can find where the cord is broken and twist n turn it just right to make it work again, then finding a way to make the cord stay that way. With most breaks in the cord happening right where it meet the mouse, you can sometimes push the cord further into the mouse and get a few more months out of the mouse.
I personally just replace the device when I know it is a cord problem, saves a lot of time, trouble and frustration. I always buy the same model of mouse and it runs around $60+, I use my old devices to repair the newer ones when something goes awry...if permitting.
So my advice is to just buy a new mouse, you can get them for under $10 depending on what you choose to buy.
Oct 17, 2009 | Dell U0636 Mouse
It wont power up
could be any number of issues, first try replacing the power cord, if that doesn't work, replace the power mechanism (easy to find on the inside as the power cord plus right into it), next, if that still doesnt work, replace the hard drive (there are ways to recover your data, but not for people without the right equipment, so i strongly advise against trying, go to a professional), and if that doesnt work, then the motherboard.
Oct 11, 2009 | HP Compaq Presario V2000 Notebook
TOO MUCH SUCTION
Clearly no one read the question problem is not low suction but too much
Sep 24, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Retractable Cord won't lock
When fully extended (you have to hold the cord in place since it won't lock), slide the rectractable device down the cord until it is butted up against the USB connector. You can use the mouse with no problems like this. When you are done, slide the retractor back to the middle of the cord and the ends will wind back in. It's not a perfect solution but at least makes the mouse usable.
Apr 23, 2009 | Targus (AMU02US) Mouse
Keyboard wont type mouse is working
Please send full setails, is it USB or PS2 keyboard, operating system, You can try following before sending details.
1. Right click my computer then properties then hard ware. then device manager. See keyboard is listed against + sign, if yes expand it and see "Standard101/102-key or standard Microsoft manual PS/2 keyboard. If Yes the right click on it and update driver. If problem is not solved click on properties ans see device status " device is working properly. Further try to uninstall and remove USB or PS/2 cable and reinstall . Reboot the system.
Nov 11, 2008 | Logitech 967437-0403 Keyboard
Battery
The portion of the mouse right behind the two buttons slides back exposing the batteries. The snap action is quite strong so you have to push straight bak quite hard. A small screwdriver will help pushing back if youa re carefull
CDB
Nov 04, 2008 | Silver Jeans 1650-56SL Mouse
Logitech mouse doesn't respond to my clicks
Even though it does not make sense, if you are using a wireless keyboard that is part of a combo pack (mouse included) sometimes (some brands) you have to plug in all cords on the keyboard/mouse receiver.
Oct 30, 2008 | Dynex Keyboard/Optical Mouse DX-CKB102
Pen problem: need to push extremely hard
You should buy a new tablet pen from acer's website and see if that works that is the cheap fix if it works
May 29, 2007 | Acer TravelMate C302XMi Tablet PC
Computers & Internet Logo
111 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
