Question about Sony KLV32S400A 32 in. LCD TV
Brightnes too high
How to troubleshoot additional information
  • Sony Master
  • 1,511 Answers
Using the remote that came with the TV, you should be able to bring up the MENU on the TV screen. You will have several options to work with, one of which is setting up the screen. One of the options offers you screen brightness. Slide the value pointer along the bar to the desired brightness. All of this is detailed in the setup manual that came with the TV.
Posted on Dec 25, 2013
Kdl46s4100 HORIZINTAL DARK LOW PART-VIDEO WITH DELAY IN THIS PORTION AND COLOR DIFERENT AND LOW BRIGHTNES BOARD TCON WAS REPLACED THE FAIL CONTINUE
LCD PANEL DEFECT CONTACT SONY CUSTOMER SUPPORT THESE MODELS SONY MADE RECENTLY HAVE EXTENDED WARRANTIES ON THE LCD PANELS BECAUSE OF HIGH FAILURE RATES THEY WILL MOST LIKELY FIX THE TV FOR YOU FOR NO REPAIR COST. CUSTOMER SUPPORT NUMBER 1(800)222-7669 GOOD LUCK
Dec 17, 2010 | Sony Televison & Video
I have an EIZO T962 CRT 21 inch monitor with bright screen. I can't adjust brightnes with conventional means ( adjusting via buttons). In the past I correct this problem on Sony trinitron 19 inch monitor...
CHECK FOR DAMAGED RESISTORS ON BOARD NEAR HIGH VOLTAGE AND ALSO ON CRT SOCKET, ITS A COMPONENT PROBLEM, RECTIFY IT..CHANGE THE DAMAGED COMPONENT, ALSO CAPACITORS IF POSSIBLE..
Oct 16, 2009 | Eizo FlexScan TX D7S Monitor
How can make brightnes
Go into the Menu Key " Look for Copy Quaility or Copy Density "
Change that from normal to Darker and change the contrast to darker you should see a difference. Incase you can't find it Print the Menu Map Look under Media OR Reolution it should be there. Again print Menu map to find it
Oct 10, 2009 | HP Color LaserJet 2600n Printer
Hp 4288 all in in one scaner is not working
Suggest the following
1) if not installed - install service pack 2 for vista - remove and reinstall HP software.
2) remove any software for Kodak digital Cameras (found by Googling and may not work)
3) Contact HP ;-)
Jul 07, 2009 | HP DeskJet F4280 All In One Printer InkJet
Need instructions on changing fuel pump in a 2000 ford windstar
Tank—Fuel Removal
ani_caut.gif WARNING: Do not smoke, carry lighted tobacco or an open flame of any type when working on or near any fuel-related component. Highly flammable mixtures are always present and may ignite, resulting in possible personal injury.
ani_caut.gif WARNING: Fuel in the fuel system remains under high pressure even when the engine is not running. Before servicing or disconnecting any of the fuel system components, the fuel system pressure must be relieved to prevent accidental spraying of fuel causing personal injury or a fire hazard.
NOTE: The fuel tank comes equipped with a composite protective shield mounted with the support straps on the right side of the fuel tank. Make sure the protective shield is installed correctly whenever the fuel tank is installed.
  1. Disconnect the battery ground cable. For additional information, refer to Section 414-00.
  1. Relieve the fuel pressure. For additional information, refer to Section 310-00.
  1. Drain the fuel tank. For additional information, refer to Section 310-00.
  1. Raise and support the vehicle. For additional information, refer to Section 100-02.
  1. Remove the fuel tank filler pipe hoses.
    • Remove the clamps.
  1. Disconnect the fuel pump connector.
  1. Disconnect the tank connections:
    1. Disconnect the fuel lines. For additional information, refer to Section 310-00.
    1. Disconnect the vapor tube fitting. For additional information, refer to Section 310-00.
  1. Remove the center fuel tank strap bolt and remove the support strap.
  1. Position a safety support under the fuel tank.
  1. NOTE: Safety support not shown for clarity.
    Remove the fuel tank support strap bolts.
  1. Partially lower the fuel tank while swinging the fuel tank support straps away from the fuel tank. Remove the straps and lower the fuel tank.
Installation
  1. To install, reverse the removal procedure.
    Module—Fuel Delivery
    Special Tool(s) st1698b.gif Fuel Sender Wrench
    310-069 Removal
    1. Remove the fuel tank (9002). For additional information, refer to Tank—Fuel in this section.
    1. Clean the area around the fuel pump mounting flange.
    1. Remove the fuel module connections:
      1. Disconnect the fuel tank pressure sensor electrical connector.
      1. Disconnect the fuel fittings. For additional information, refer to Section 310-00.
    1. If repair or installation of new fuel lines or a new electrical harness is necessary, remove the fuel lines or harness from the fuel tank retaining clips and remove the appropriate assembly.
    1. Using the special tool, remove the fuel module retaining ring.
    1. ani_caut.gif CAUTION: The fuel delivery module must be handled carefully to avoid damage to the float arm and filter.
      Remove the fuel delivery module from the fuel tank.
    Installation
    1. NOTE: Make sure that the areas around the fuel delivery mounting area and the fuel delivery module flange are clean.
      NOTE: When installing the fuel delivery module, make sure to align locator tabs on the fuel tank mounting flange.
May 26, 2009 | 2000 Ford Windstar
Mita dc 1560 prints are dark
nadark_1@yahoo.com
replace the Drum and the blade
Jul 14, 2008 | Kyocera KM-1505 Copier
LG 22lc2d bought at Best Buy
Try setting your black leverl to high in the Pictutre-Advanced menu.
Apr 19, 2008 | Televison & Video
Sony KLV32S400A 32 in. LCD TV Logo
37 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
