Question about Sewing Machines
Needle no longer moves up and down but the engine whirs
I ma sewing a heavy weight fabric using 18 size needle. Suddenly, the needle hit the fabric and stopped moving up and down. The bobbin winder still works. Is something broken inside? The lower serpentine belt looks okay.
    New Friend:
  • 4 Answers
Sounds like the needle is bent replace the needle
Posted on Dec 28, 2013
4 Suggested Answers
  • 323 Answers
SOURCE: The fabric doesn't move forward.
We need to do some examining. Remove the foot. Put the stitch length dial at the longest stitch. Turn the wheel and see if the feed dogs move about 1/4 inch. Also check to see that they rise just slightly above the needle plate. If it does these two things it will work. If the teeth don't rise above the plate, remove the needle plate and clean the lint out from between the rows of teeth. If you find a lot of tightly packed lint there this will solve your problem. Reinstall the needle plate and foot. If the feed dogs don't move about 1/4 inch, you probably have a problem which is going to require the services of a technician.
sewman7
Posted on Jun 12, 2008
SOURCE: needle clamp won't attach to needle bar
There is a set screw above the needle pin screw which tightens with an allen wrench--try that.
Posted on Feb 21, 2009
Obertelli
  • 3006 Answers
SOURCE: The thread is bunching up
Your problem stems from the faulty foot lever mechanism. It's coupled to the upper thread tension control which only provides tension when the presser foot is in the locked down position.
If the presser foot won't positively engage in the down position, there's no upper thread tension and the thread bunches up below. Everything else stems from there. If the needle has hit the bobbin case too frequently then the bobbin timing may also be slightly out and the needle itself will be damaged and won't pass straight through the fabric; it only takes a tiny deflection from the vertical as it passes through the workpiece for the needle to flex and hit the bobbin case.
In summary, your machine is in desperate need of repair and adjustment. You haven't stated which exact Singer model you have, but they are usually easy to get servicing manuals for or you can take the machine to a sewing machine servicing specialist. Most singer spare parts (even for 100 year old machines) are usually still available fairly cheaply from a variety of sources, just enter "Singer spares" into your search engine to find suppliers.
To prevent re-occurrence, clean the mechanism regularly and lubricate it as directed by the manufacturer using sewing machine oil. Depending on how often you use the machine, do (or have done) a more thorough service periodically to check the timing and also that all mechanism screws remain tightly fastened.
I hope that my reply has shed some light on your problem and enables you to decide what to do next. Please take a moment to rate my answer.
Posted on Sep 30, 2010
Yamata gc8500 needle thread breaks as soon the machine goes fast
Make sure you're using the correct size needle for the fabric you're sewing.
Delicate / Very light weight.... china silk, fine lace, organza....size 8 or 9 .....Light weight taffeta, lining fabric, thin velvet, synthetic sheers size 9, 10 or 11.... Medium weight cotton nylon, crepe, knits, flannel, spandex, linen, poplin, wool, muslin size 12 or 14..... Heavy weight fleece denim, leather, vinyl upholstery fabric size 14 or 16....Very heavy weight ; heavy canvas ; thick leather size 16 or 18
Apr 28, 2018 | Yamata Sewing Machines
WHAT NUMBER NEEDLE DO I NEEDLE FOR SINGER 5838C
According to this manual, it takes Singer needles which are probably 130/705 type:
http://homeappliance.manualsonline.com/manuals/mfg/singer/5838.html
Singer enthusiasts generally recommend using Singer needles, however, other sewists will use other brands as long as they are the same type. As for the needle size and the point, that depends on the fabric you are stitching.
All About Needles SCHMETZ Needles
Dec 14, 2017 | Singer Sewing Machines
I have singer touch tronic 2001. I was wondering if a HD needle size 18 work on this sewing machine
Yes, you can use a size 18 needle in the TouchTronic 2001. See page 15 (page 21 of the PDF) of the manual. The PDF is available here: http://www.singerco.com/uploads/download/66946ce4f503e17bfd20036aef30c05707c736e1.pdf .
You should only use a heavy duty machine needle (2020-18 or 2032-18) with a heavy cotton mercanized or synthetic thread when those are appropriate for your fabric. You should always match the thread to the needle. The thread should fit in the groove on the front of the needle. If the thread is too thick or thin compared to that groove, you can have problems with tension.
I hope this helps.
Mar 01, 2017 | Singer Sewing Machines
Keeps breaking needles
Slow down and watch what you sew over.
No needle is going to sew through the metal part of a zipper.
With many layers of fabric you have to slow down. If you have multiple layers of a thick fabric you may have to resort to using the hand wheel to get through the layers.
Another tip would be to not pull on the fabric. The machine is capable of "feeding" the fabric at the rate it requires. When sewing with many yards of fabric the weight of the fabric may create a pull on the needle. If the needle is pulled so that it no longer goes through the need plate properly it will hit the metal of the needle plate and break. Instead rest your hands on either side of the fabric and gently steer the fabric. Do not pull it out of the back of the machine or shove it into the needle. With large yardages wad up the fabric around the machine so that the weight of the fabric isn't causing strain around the needle.
One other tip. If you have a needle plate in your machine that only supports straight stiching, that is one with a needle hole that is just big enough for the needle to move up and down, and you switch to a zig-zag stitch, you will break the needle. Most factory installed needle plates have a needle hole large enough to support the largest zig-zag that the machine can support. But some machines have custom needle plates (for quilting) that only support a straight stitch.
Dec 08, 2014 | Sewing Machines
I have a Singer CG-550 and am sewing a heavyweight fabric using needle size 18. The engine whirs but the needle no longer moves up and down once it hits the fabric. It occurred suddenly, and I wonder
The motor may not have enough torque to force the needle through the fabric and back in a cycle. If you continue to force the needle into course material, it could bend the shaft, needle, or cause a misalignment of the needle pitch and direction. It sounds like the machine is a light duty appliance and you cannot force it to do commercial appliations.
Dec 25, 2013 | Sewing Machines
What size needle does the euro-pro x 384 take?
The needle size depends on the type of fabric you're using. Generally, if you're sewing heavy or sturdy fabrics you'll need a size 16 needle. If you're sewing light weight fabrics, you'll need an 11. Nowadays, most machines will take any brand of needles. I hope this helps. If it does, please return and rate my suggestion.
Jun 06, 2011 | Euro-Pro Shark 60 - 384
I have a sewing machine-single needle model 03914, but I don't how to put the needle for delicate fabric and for thick fabric?
Use size 60 for very fine (chiffon), size 70 for light weights like voile and cotton, 80 or 90 for medium weights such as a broadcloth, size 100 for denim and size 110 for something very heavy like a thick curtain or upholstery weight fabric. If you aren't sure what size to use, try pushing a needle into the fabric you are going to sew with your fingers, if it goes in easily and the hole it leaves is not noticeable then it is okay, if it leaves a big hole, then go down a size. If you use a needle that is too small on a fabric, then it is going to go blunt quickly or break.
good info here http://sewing.about.com/od/sewingmachineindex/ig/Sewing-Machine-Needles/Needle-Sizes.--94.htm on needle sizes.
Apr 07, 2011 | Sewing Machines
My bobbin stitch is loose. I have tried adjusting tension and have changed the needle.
A. To correct loose stitches, try the following: (1) Balance the thread tension. If the stitches are loose on top of the fabric, decrease the tension to the next lower number. If they are loose on the underside set the tension to the next higher number. (2) Make sure the needle/upper thread follows the threading path. (3) Check to see that the bobbin case is threaded properly. (4) Use a different size needle. For fine fabrics, use a smaller needle (size 9, 11); medium-weight fabrics require a size 14 or 16. And use a size 18 or "Denim" needle for heavy corduroy or denim.
Sep 20, 2010 | Singer Curvy 8770 Electronic Sewing...
Does it make a difference whether I use a 14 or 16 in my Kenmore sewing machine, basic 12 stitch. I had a 16 needle in it but after my friend cleaned it, in trying it, the needle hit the presser foot>...
Hi. You use different size needles for different fabrics and fabric weights. Size 16 needles are used for heavy fabric, like canvas, duck, or blue jeans. Size 14 needles are still on the heavy/thick fabric size. Size 10 needles are for very light-weight fabrics and size 12 needles are for medium-weight fabrics. Also, you need to pay attention to the type of fabric--if sewing on knits, you need ballpoint needles. If sewing on woven fabrics, you need sharps or universals. Universals are supposed to be for knits, too....but ballpoint needles are SO much better!
Use the right size and type of needle for your fabric, don't sew over any pins (they can bend or even break the needle), and make sure you don't pull or push the fabric while you're sewing on it. Let the feed dogs do the work of moving the fabric--you just gently guide it.
Hope this helps!
Aug 25, 2010 | Kenmore Sewing Machines
What is the size of the needle used in the white superlock 1934D
This is a very highly regarded serger. Check out the reviews on http://sewing.patternreview.com if you're interested--but they are all extremely positive.
I also checked out the White Sewing Machine site--the three sergers they currently sell all use regular sewing machine needles.
Based on what I read on both sites, I believe your machine also uses regular sewing machine needles (not all sergers do, BTW). To be absolutely certain, you can call the White Help Line (l 800-331-3164, Monday through Friday 8AM to 5PM, EST).
If your serger uses regular sewing machine needles, then the size of the needle depends on the type of fabric you're sewing. Sizes 8 to 10 for lightweight fabrics, 12 to 14 for medium weight fabrics, and 16 to 18 for heavy weight. Use ballpoint needles for knits, jeans needles for denim, and universal needles or sharps for woven fabrics.
Jan 26, 2010 | White Sewing Superlock 1934D Mechanical...
Sewing Machines Logo
105 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
