Question about ViewSonic VFD820-50 - digital photo frame
Cant get my photos to show up
My photos wont load to the frame I get a black screen with a red no signal circle.
The bobbin case went ajar while sewing blue jean fabric. I cant figure out to put it back in. Your help is very much appreciated :
Hi Debbie,
This type bobbin case can be a pain to get back in. On photo #1, at the top left you see a silver piece (circled in red) with a rectangular hole in it (circled in green)...take a flat head screw driver and insert it into the slot then twist to the right so the little bar/flange (circled in blue) will twist to the left past the bobbin well wall (marked in neon green). Photo #2 Now the bar/flange (marked in blue) should be on top of the bobbin well wall (marked in neon green). Now set the bobbin case in the bobbin well (marked in pink). Photo #3 as you set the black bobbin case in, kind of angle the flat part that is marked by the orange X so that it will begin to underneath the bar/flange with large orange circle. It won't go in all the way but just start it and then set the rest of the case down in the well. Now twist the entire black case to the right and the flat black are marked with the orange (X) should slide underneath the bar/flange marked with orange circle. The flat piece marked with a purple (X) should be sitting in the area marked with an (X) in the bobbin well. Now take your screwdriver and stick it in the rectangular box and twist it back so the silver piece marked in blue with go back over the edge of the black bobbin case to help hold it in. Hope you can understand my instructions and good luck!
Apr 11, 2016 | Singer Merritt 8734
Make photos show with correct orientation on digital photo frame
sir,
Your camera may be having more options of orientation or keystone or resize etc, if it is set to such options the picture results as you said, please try to re set your camera to factory default. then you try the photos effect.
Jan 31, 2016 | Cameras
How do I get"connected to computer "off screen on my 8" Aluratek digital frame?
pluging in a usb cable from a computer that allready has the device driver loaded , should send the photo frame into accept mode automaticly , then its all done via the connected computer , nothing on photo screen should matter , till usb cable is disconnected , sorry you cant leave cable connected .
Dec 31, 2014 | PANDIGITAL 8.0" Digital Photo Frame...
My DPFMate is showing a blank screen
you must flashing that because the system software is error
Dec 27, 2013 | Spectra DPF-105 Digital Photo Frame...
Movies
The file extension '.MP4' ex. might not be readable in the frame.
Videos: Play your favorite videos on the true color TFT LCD screen. Simply connect your USB drive to the USB port on the frame to transfer your videos to the on-board memory or store on a SD/SDHC card.
May 16, 2013 | Aluratek ADMPF108F 8-inch Hi-Res Digital...
Black circles on left edge of lcd tv screen
Bad LCD panel. https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=7857212
May 01, 2010 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
Error on screen showing 'unusable signal' - input probs
Make sure you have all the cables in the right places, best to disconnect everything and start from scratch. Julio milleniumtvsvc@gmail.com
Jul 23, 2009 | RCA HD52W58 52" TV
7" sunpak frame wont recognize usb connection
How do I get my computer to recoginze the connection of my USB?
Dec 31, 2008 | Sunpak (SDPF-070AW-0US) Digital Picture...
Displaying pictures Sunpak 7" Digital Photo Frame
This can mean many things. Pictures don't fit, Wrong file type e.g .png .jpeg .gif. Or has no more pictures to display.
Dec 19, 2008 | Sunpak (SDPF-070AW-0US) Digital Picture...
ViewSonic VFD820-50 - digital photo frame Logo
57 people viewed this question
Top ViewSonic Photography Experts
Tony
Are you a ViewSonic Photography Expert? Answer questions, earn points and help others
