Question about Mr. Heater MH170FAVT Open Flame Gas Utility
Heater won't relight after shutting down, but fan continues to run
Heater lights properly, but flame shuts off after about 5 minutes, no matter what thermostat setting. The fan continues to run, but the flame won't relight automatically when temperature drops below thermostat setting. Heater won't stay lit when thermostat is set at max temp. setting. Running off of 1000 gal LP tank with commercial regulator installed by gas supplier.
  • 3 more comments
  • Roger Hornaday Dec 25, 2013
    This heater is being used in a 30FT x 30FT x 12FT high building and worked fine for years.
    To answer your questions. John, the flame is the normal blue with occasional yellow tips. There is the normal roaring sound when the unit is ignited and the flame is normal size. When it does shut off the flame, it is as if the thermostat abruptly shuts it off, but it doesn't seem to matter where the thermostat or flame control are set as to the length of time that the unit stays lit and when the flame shuts down the blower fan keeps running. Voltage is normal and there is plnty of propane in the tank (it was just filled in October and is a 1,000 gal tank). The original pressure regulator was replaced by the LP gas supplier several years ago with a larger commercial regulator and was set by them to the proper specs. and there is no frost on the pressure regulator or gas smell indicating a malfunction there and the unit worked well until recently. I will check the high limit switches and terminal block, as well as the thermostat continuity at different settings, as well as all connections. Any additional help would be greatly appreciated. Thank you!
    John, I checked the continuity on the high limit switches and thermostat, checked all wire connections, cleaned the igniter plug, checked the resistance on the gas valve solenoid and again checked the pressure regulator. All checked out good. Is it possible that the solenoid for the gas valve is sticking shut and causing the problem? I tried manually shutting off the flame by turning the thermostat off and waited 7 minutes and still could not get the unit to light. I heard the igniter and the solenoid for the gas valve energize, but it wouldn't light. The limit switches were room temperature and closed. Any help would be greatly appreciated.
  • Roger Hornaday Dec 26, 2013
    John, The gas valve is the original Goyen Model# 10QG-EDANA-7281 valve. The resistance on the coil is 217.9 ohms. Jumping out the thermostat didn't solve the problem. It still shuts the flame off in 6 minutes and both high limit switches remain closed. I do have an engineering degree and did disconnect and isolate each component when doing continuity tests. I do not, however, have a manometer and since the secondary regulator (3/4" commercial grade) supplying this heater was professionally installed, using 3/8" copper tubing for supply and outlet to the 1/2" black pipe nipple and shutoff valve inside the building, by the LP gas supplier and they own the 1,000 gal. tank, I will have to call them to have that checked. The shutoff valve is fully on at the tank and inside the building that the heater is in. This tank also supplies the 95,000 BTU furnace inside my house with no problem with the regulators freezing up. I did find out that the gas valve on the unit is shutting the gas off for some reason after 6 minutes and the unit can't be restarted for about 10 minutes affter this happens (The gas valve will not open even with the thermostat jumpered out). Is it possible that the problem could be caused by the control board? The igniter spark is a strong blue spark, even when the gas valve won't open.
  • Roger Hornaday Dec 27, 2013
    John, I checked the voltage to the gas valve solenoid with an autoranging true RMS meter and it is staying between 117 and 118.6 volts while the flame is burning and the voltage is still there when the flame shuts off, but decreases to about 45 volts and less, a couple of minutes after the flame shuts off. To eliminate the gas lines and regulator, the company that supplies the LP gas and the hookup replaced the regulator with a new one and checked the gas pressure, which is to spec. The unit is still shutting off after 6 minutes. The igniter plug on this unit also acts as a flame sensor and is glowing orange when the flame is lit. There is no oxygen depletion sensor on this unit, but the blower has plenty of suction into the unit and there is no impeded air flow. Could it be that the flame sensor portion of the ignitor is going bad or is that contained in the flame control board? I cleaned the ignitor plug and it didn't seem to help. The unit consistantly shuts off the flame after 6 minutes, no matter what setting the thermostat or the BTU output control valve is set at. If it were something in the gas valve causing this it would seem that it would be more inconsitant, which leads me back to either the igniter plug or the flame control board.
  • 794 Answers
Roger, you either have a gas supply issue or a voltage problem.
Since I don't know your aptitude and abilities pertaining to LP gas troubleshooting/testing procedures, I don't know how detailed you want to go...basically, make sure your propane tank isn't empty; or that the pressure regulator didn't freeze up. Make sure that it is rated and set for 28" of water column output.
Check to make sure all the wire connections are secure to the flame control terminal block and to each of the hi-limit switches.
Isolate & perform continuity checks to each electrical component, including the gas valve.
You'll need a manometer to test and set the gas input & output water column levels.
When the unit is running,, what color is the flame?
Is there a roaring sound?
Is the flame small and weak?
Posted on Dec 25, 2013
  • 3 more comments
  •  John
    John Dec 26, 2013
    Hi Roger- I just want to double check that you performed the continuity tests correctly because I had another person who I instructed and did not understand what I meant when I told them to isolate the cycling thermostat, hi-limit thermostat, & thermal fuse to their gas dryerbefore performing taking resistance readings. So please don't feel slighted that I'm asking. You did remove any leads (wires) to each of the components you tested, correct? Just because you see no icing or frosting around a gas regulator does not mean that it is okay. There is moisture in the lines that carry propane & natural gas; hence drip legs- so the regulator could in theory be frozen internally. That's why I suggested taking pressure readingsusing a manometer to ensure there is proper gas flow and at 28 inches of w.c.. Speaking of gas flow, I would also check the inlet and outlet pressure (using a manometer) at the ags valve too. Process of elimination to determine why gas valve is not opening to release the gas.. It could be like the regulator, internal freeze do to condensation build up in valve. It could be a bad gas valve assembly; a bad gas valve coil; or a clogged orifice. Is the spark on the spark plug weak or strong? Did you try jumping out the thermostat?
  •  John
    John Dec 26, 2013
    What is the make and model number to the gas valve?, please.
  •  John
    John Dec 26, 2013
    BTW, is the shutoff valve on the LP tank fully open? And is the pressure regulator and gas valve rated for LP gas?
  •  John
    John Dec 27, 2013
    Roger, I contacted Goyen, the manufacturer of the low pressure gas control valve (a subdidiary of Pentair Environmental Systems). They're supposed to send me the data sheet specs on it. In the meantime, what voltage reading are you getting at the valve during normal operation- and does the voltage drop out after you lose the flame? What about the oxygen depletion sensor, is that kicking in causing the flame out? I have been on service calls where such things as a dead spider in the vent limiter or breather cap as being the culprit as the cause of low or no gas flow from the regulator to the appliance. I have also gone on calls where "professional" installers improperly connected gas regulators- reverse flow; improper orientation; sizing; and using NG regulators on LP installs; so I leave no stone unturned when troubleshooting problems like yours, especiall when this is being done remotely and I'm not there.
  •  John
    John Dec 27, 2013
    And yes, it is possible that the control board is the problem. You'll have to troubleshoot it at the component level.
  • 2976 Answers
SOURCE: tank-top propane unit won't stay lit
I had to replace the regulator. If you have a propane appliance shop near you, you can probably just get the nipple that goes into the bottle. It's aboit 3/16" diameter, 3/4" long and may have a 6 sided end up inside the screw on cap of the regulator.
Posted on Feb 24, 2009
  • 9 Answers
SOURCE: Heater Burner ignites but main blower motor will not turn on.
it sound like the blower motor may be seizing up. try spining the blade by hand to see if it feels free or not. the motor could be trying to turn but can then tripping itself out on overload. (most motors have built in safety overloads which will trip during an overcurrant event. aka too many amps.) you may have to replace blower motor
Posted on Mar 22, 2009
terrencio
  • 20 Answers
SOURCE: Stays lit for 25 minutes and shuts off
How large and sealed of an area are you using it in? I ask because those units have a low oxygen sensor which will shut it down if there is not enough oxygen in the space.(kinda prevents that pesky suffocation thing). Otherwise if using it in larger cold spaces, the issue is can be from the smaller tanks. As mentioned above, a larger tank can solve this, because these units have a fairly good input rate, which will cause the smaller tanks to freeze, and lower the propane temperature and evaporation rate, basically runs out of gas until the tank warms back up.
Posted on Sep 26, 2009
  • 65 Answers
SOURCE: heater shuts off
The heater thermostat senor for this heater could be bad or indicating a abnormal temperture shutting it down. You might want to return item if still under warranted
Posted on Nov 06, 2009
bobicehouse
  • 1524 Answers
SOURCE: heater turns on and heats
Problem: Your furnace will not ignite the gas to produce heat for your home. When a furnace has a bad ignitor what I see most of the time is the following sequence of operation:
1. Thermostat calls for heat. 2. Draft inducer motor starts. 3. Pressure switch attached by a small plastic or rubber tube senses the negative pressure produced by the draft inducer and closes. 4. Draft inducer runs for 30 seconds to a minute before you hear a gas hissing sound. The ignitor did not glow, the flame sensor (a small metal probe about 1/8" in diameter, with a white porcelain base) does not sense the flame, so after 8 to 10 seconds the hissing sounds stops with no ignition of gas to heat your home. Your furnace shuts down and goes into a lock out condition until you turn your power switch back off and on again. Then the sequence starts all over again with no ignition of the gas. Solution:You probably need to purchase and install a new ignitor. I would suggest that you inspect your ignitor closely for cracks. Make sure you do not touch the ignitor with your bare hands. If you do not visually see a crack, then you could have a furnace control board problem or a limit, rollout switch problem. The furnace's control board might not be supplying the voltage to the ignitor.If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Posted on Dec 11, 2010
Pilot light keeps going out
pilot light keeps going out! more then likely its the thermal coupling doing this. if bad it shut all gas to heater for a safety measure. just shut power off, then turn gas off and replace it. then you should be ready to go. to relight heater hold down on gas vavle knob in the pilot position, hold down and light it at the coupling where gas comes out. when it is lit, continue to hold down for 60 seconds. release knob very slow. then if its lit, turn to the run position. if flme goes out, wait at least 5 minutes to expel the gas fumes and turn to pilot and try again. good-day !
Mar 31, 2012 | Water Heaters
Furnace lights and in about 2 to 5 mins. the flame shuts down. the furnace trys to relight but does not. the unit trips out and the light flashes 1 time to show to many times tryin to light
Probably a filthy flame sensor. You can clean it off with steel wool or light sand paper. This should do it for you. If this does not work I would suspect a gas valve that is failing and dropping out after a few minutes. Always remember to change the filter while you are at it. Good Luck :)
Dec 03, 2010 | Goodman GMS90703BXA Heater
Flame out on a DCS Patio Heater
thermo-coupler (cheapest to fix) or valve
Jan 30, 2010 | DCS PHFS Phoenix III Outdoor Patio Heater
Flame wont stay lit
Sounds like a flame sensor problem. The board is not getting the proper signal from the flame sensor so it thinks the burner did not light and shuts the gas supply off. It keeps the blower operating to ensure that no gas is accumulated in the burner area. I suggest you contact a local mechanical contractor to service your heater.
Jun 23, 2009 | Pentair Minimax NT Heater
Gas log will not stay lit for more than 5 minutes
Sounds like the gas regulator has failed.
There will be sufficient gas flow to light the pilot and get a flame prove, then the main burner lights, you will probably see the pilot flame reduce somewhat, and no longer fully surround the flame prove sensor.
When the unit is relighted, the complete sequence starts all over again.
Have the gas regulator checked and adjusted (if adjustable) or replaced by a qualified technician.
Jan 20, 2009 | Heating & Cooling
Will not stay burning
i think i may have solved it. i heated the thermal couppling and very gently bent the tip about 45 degrees. it has been running about an hour now i'll let you all know if this fails but so far so good
Mar 06, 2008 | Berkeley Forge G-PH001PSS Open Flame Patio...
Wont stay running
Reddy suggests: 1. Propane supply may be inadequate 2. High surrounding air temperature causing thermal limit device to shut down heater 3. Restricted air flow 4. Damaged fan 5. Excessive dust or debris in surrounding area solutions are: 1. A) Refill tank B) Provide additional and/or larger tanks. 2. This can happen when running heater in temperatures above 85° F (29° C). Run heater in cooler temperatures 3. Check heater inlet and outlet. Remove any obstructions 4. Replace fan. 5. Clean heater. could not get manual for your exact model but if you want manual for RLP 125 then; http://12.153.20.74/manuals/113893-01C.PDF appears to be the same beast. Hope helps :)
Feb 27, 2007 | Reddy Heater RLP100 Portable Forced Air...
Mr. Heater MH170FAVT Open Flame Gas Utility Logo
152 people viewed this question
Top Mr. Heater Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Mack Baxter
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
