Question about Sewing Machines
I have a Singer CG-550 and am sewing a heavyweight fabric using needle size 18. The engine whirs but the needle no longer moves up and down once it hits the fabric. It occurred suddenly, and I wonder
Needle no longer moves up and down after it hits the fabric.
  • 1,511 Answers
The motor may not have enough torque to force the needle through the fabric and back in a cycle. If you continue to force the needle into course material, it could bend the shaft, needle, or cause a misalignment of the needle pitch and direction. It sounds like the machine is a light duty appliance and you cannot force it to do commercial appliations.
Posted on Dec 25, 2013
bargainbox
  • 1388 Answers
SOURCE: Sears Kenmore 1168280 (Old machine not used much)
Untangle any mess under and around the needleplate very gingerly trimming threads as you go if necessary....remove and clear.
Undo the needle clamp and remove the remains of the needle.
Open the door for the bobbin and bobbin case and undo the clips holding the hook in place......don't force anything, just ease any tangle loose slowly.
You may want to take a photo of how it goes back together if unfamiliar, or lay the bits out sensibly, so you can replace easily later.
Inside the bobbin/hook area is the most likely region for thread jamming the motion of everything, so make sure all is clear and clean, then.......
Without replacing the bobbin or hook, test the handwheel after cleaning before re-assembly.
You may also want to check the take-up crank for thread jams........the small arm in the top cover that moves up/down to "take-up" the top thread has a cam attached to the top shaft and often tangles thread around the shaft, open the L side cover to access.......remove thread by unwinding handwheel manually ....again be patient and careful not to break threads.
Best Wishes
bargainbox.com.au
Posted on Jun 08, 2008
kent581
  • 87 Answers
SOURCE: needle hits needle plate with heavy fabric
that is your problem, your needle bar is centered too far to the back. There are 2 little bolts (Below the presser foot lift on the back of the machine) that must be loosened while the needle bar is repositioned aligning the needle bar assembly.
Posted on Mar 24, 2009
SOURCE: singer quantum cxl sewing machine needle hitting metal
Your needle is probably to long or you need to open it more
Posted on Apr 08, 2009
  • 255 Answers
SOURCE: I am using a Singer CG-550 C, and when I changed
Hi. Hm.........it might be that you have the flat side of the needle facing the wrong way. Check your instruction book to be sure. Another thing to check would be that the screw is going in straight. If it's slanting up or down, the screw might be getting stuck before it gets to the needle.
There have been times when I've gone back to the instruction book and ********** the parts again, just to make sure I was turning the right screw. (It happens!)
Another possibility I've run into is that the needle slips down while I'm tightening the screw. So (this might sound weird), I put the needle in as far as it will go, then use my index finger under the point of the needle to hold it in place. (yeah, ouch!)
Hope this helps!
Posted on Jan 19, 2010
  • 980 Answers
SOURCE: New Problem...I have a Singer CG-550. When I try
On the right of the black bobbin case there are two screws, you can slacken those screws off and move the bobbin case nearer to the guard leaving enough room for the thread to pass through, if the needle is hitting the bottom you may need to retime the machine.
Posted on Mar 07, 2010
WHAT NUMBER NEEDLE DO I NEEDLE FOR SINGER 5838C
According to this manual, it takes Singer needles which are probably 130/705 type:
http://homeappliance.manualsonline.com/manuals/mfg/singer/5838.html
Singer enthusiasts generally recommend using Singer needles, however, other sewists will use other brands as long as they are the same type. As for the needle size and the point, that depends on the fabric you are stitching.
All About Needles SCHMETZ Needles
Dec 14, 2017 | Singer Sewing Machines
How to adjust the feed dog tension on Singer CG550? It isn't strong enough to hold the fabric in place - stitches are uneven. My old Kenmore had an adjustable button on top above moving needle pole.
you are referring to the walking foot tension
ask a sewing machine repair shop how to adjust it
could be a lock washer held in place by a set screw where you loosen off the screw and push it closer against the spring and re tension the screw
Mar 19, 2017 | Singer Sewing Machines
I have singer touch tronic 2001. I was wondering if a HD needle size 18 work on this sewing machine
Yes, you can use a size 18 needle in the TouchTronic 2001. See page 15 (page 21 of the PDF) of the manual. The PDF is available here: http://www.singerco.com/uploads/download/66946ce4f503e17bfd20036aef30c05707c736e1.pdf .
You should only use a heavy duty machine needle (2020-18 or 2032-18) with a heavy cotton mercanized or synthetic thread when those are appropriate for your fabric. You should always match the thread to the needle. The thread should fit in the groove on the front of the needle. If the thread is too thick or thin compared to that groove, you can have problems with tension.
I hope this helps.
Mar 01, 2017 | Singer Sewing Machines
From where can i buy elna sewing machine needels? Pleace.
Consult your owner's manual for the size needles your machine takes. Usually, it is 130/705 needles.
If so, you can purchase this size from most any fabric, sewing repair shops, or online vendors. There are many manufacturers who make needles, ie Schmetz, Organ, Klasse, as well as Singer. Schmetz is readily available most places in the US. (IMHO, Singer needles are made more specifically for Singer sewing machines and may not work as well on a non-Singer machine. Most Singer machine manuals recommend using only Singer needles and some sewists have experienced problems when using a different brand.) You may have to experiment with brands if you have any problems with a specific manufacturer brand.
However, there is much more to choosing needles for your machine than the size and brand. The most important choices are to choose needles that suit the thread & fabric you will be sewing. Be sure to read up on the needle types (from smallest 65/9 to heavier 110/18) and the design/shape that will work best for you, ie sharps (for woven fabric) or ball-point (for knits), quilting, topstitch, embroidery, microtex, stretch, denim, universal, leather, etc.
"The European metric sizing system for sewing machine needles is numbered from 60 to 110. The American sizing system is numbered from 8 to 18. For both sizing systems, the lower the number the finer the needle and the higher the number the larger the needle. Most needle companies show both sizes on the package." (quote from Singer)
In addition, if your machine is capable, you may also be able to use twin, triple needles, wing, wedge point needles. The following will be helpful when you make your purchasing choices:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahUKEwjhzOqwyKzMAhVisoMKHUO2CR0QFggjMAE&url=http%3A%2F%2Fwww.schmetzneedles.com%2Flearning%2Fpdf%2Fschmetz-needle-chart.pdf&usg=AFQjCNHTR52AmqwzvyCjbXmD5Ch52Va5_Q
All About Needles
FREE Printable PDF Guide to Schmetz Sewing Machine Needles
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwjO4dSey6zMAhWpg4MKHUWjDAgQFgglMAI&url=http%3A%2F%2Fwww.joann.com%2Fon%2Fdemandware.static%2FSites-JoAnn-Site%2FSites-joann-project-catalog%2F-%2Fimages%2Fhi-res%2Fproject%2Fpdf%2FPA00223.pdf&usg=AFQjCNG8bnom5KfB1eLB6lEjHIsosUBgMw&cad=rja
Machine Needles
Apr 26, 2016 | Elna Sewing Machines
Needle size for singer 3014
Your machine takes standard sewing machine needles, available from quite a few manufacturers like Organ, Schmetz and Singer. I have even seen them for sale in drugstores! Most people use #11, #12, or #14 needles--the higher the number, the larger the needle, and the thicker the material. In addition, Sharps are used for all woven fabrics like cotton and wool; ball point needles are used for things like t-shirts and other knit fabrics. Home sewing machine needles range from #8 to about #18. For instance, you would probably use a #14 or #16 needle for Jeans, although for those, there are also specialty Jeans needles you can also use.
Jun 11, 2014 | Singer Sewing Machines
Needle no longer moves up and down but the engine whirs
sounds like the needle is bent replace the needle
Dec 25, 2013 | Sewing Machines
My singer HD 110 will sew a bit then suddenly the needle will slow down to a stop & the handwheel seems stuck, yet the motor is still running.
Hello there! Make sure your pattern selector is compatible with the presser foot. Good idea to test with a straight stitch setting: Tension: 4. Width:4-5. Length 5 after you insert a new needle and re-thread machine. Your previous needle may have become bent when machine malfunctioned. Use fabric compatible with needle size. Always raise presser foot when threading! Then always lower presser foot before sewing. Remember to use blue tip scarf needles with synthetic fabric silk thread 50. Purster thread 50, mercerized cotton thread 50-60; #11 or #9 for fine or lightweight fabric with silk thread 50 or fine Pollyester thread; #18 leather needle for leather, #14 - 16 denim . Jimmy Sweep out shuttle carefully with small brush for broken threads and lint.
Mar 31, 2012 | Singer Sewing Machines
I have a Mini Ultra machine. Sometimes when I am sewing a heavy weight fabric the needle jams -- that is, it hits the plate instead of going through the opening. What is wrong and what can I do?
Most likely reason is the needle is bending. Try using a thicker needle. Heavyweight fabrics such as denim, duck and canvas. Use a 90/14 or a 100/16 needle if sewing on these fabrics; a lighter 70/10 or 80/12 if sewing on cotton. Singer codes this with a blue top.
J
Please post any question is comment and don't forget to rate my free answer.
Apr 16, 2011 | Kenmore Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
