Question about Samsung Refrigerators
Cloudy ice cubes
Our new Samsung refrigerator makes ice cubes that are small and cloudy. It is a bottom freezer and French top drawers.
marked
  • 6487 Answers
SOURCE: Kenmore Elite Trio Refrigerator - ice maker shut off arm
This link will be helpful to your problem , check this out this is the link for it http://www.fridgedoctor.com/fridge-doctor-book/ice-maker-not-working.html
Hope that helps........
Posted on Aug 26, 2008
  • 8 Answers
SOURCE: Ice maker is making hollow ice cubes, some only half frozen
Most ice makers have an adjustment screw to control the cube size. Its usually hidden behind a plastic panel on the front of the ice maker. A quarter turn either way and some trial and error testing should get you pointed in the right direction to your ideal ice cube.
Posted on Nov 05, 2008
  • 3 Answers
SOURCE: Ice Maker quit making ice cubes
Look on the bottom of the rectangular motor housing for the ice maker. This is the white box that holds the front end of the ice tray. In the past, this was normally a small patch of black 'runner' that covered the switch and helped kkep moisture out.
If you cannot locate it by feel, try using a small mirror and a flashlight to help you locate it.
Posted on Jan 14, 2009
woodchuck789
  • 4059 Answers
SOURCE: ge monogram bottom freezer ice maker spills ice
It takes weeks for ice to dissipate in a freezer.
You may can adjust your cut off lights or wire cut off to cut off before it's so full.
Posted on Jul 01, 2009
shane_mccown
SOURCE: water build up underneath deli tray drawer
Ok. I know why this is happening. Or at least in my case.
The coil for the Fridge is stored behind the center panel when looking directly into the the Fridge.
What happens is the drain for the coil becomes iced up. It then wont drain and when the fridge goes into defrost mode the melted water will run out of the bottom of the center panel. This is difficult to see due to all the shelves in the way. i noticed this because I could see ice through the vent holes in my center panel.
To fix this:
Take all the items out of the fridge.
Take all the shelves out so the center panel is exposed.
Remove the 3 screws at the bottom of the panel and single screw under the cover of the shelf rail. (This one is a little hidden) pop off the plastic cover first.
Now you can pull the panel off.
(Note. This can be a little difficult to get off because you have a ton of ice behind there keeping it stuck to together. Just ease it off as much as possible.
When you get this off you'll most like see alot of ice in the tray that the water is draining into. chip this ice away and then I used Hot water to pour into the drain. I would then use a shop vac to **** the water out and put in more hot water until the ice plug is removed and the water can flow freely to the drain pan under the fridge.
That is it. I own this fridge and I've been tired of having to **** water out of fridge with a shop vac every 2 weeks. So I decided to resolve this myself.
*disclaimer. I'm just a DIYer not a Samsung repair person.
Good Luck and I hope this solves your issue.
Posted on Aug 25, 2012
Samsung rf266aepn bottom french door ice maker arm
Simple but a pain. Unplug the refrigerator. Get out your hair dryers and start de-icing the freezer door. Slowly but surly you will get freezer open. Be gentle. Dry EVERYTHING!!! Tracks, rails.....then replace part, plug back in, restock.
Oct 12, 2013 | Samsung RF266AEPN
LG French door bottom freezer unit is only 5 years old. Bottom freezer suddenly not keeping food frozen. Ice cubes are melting, ice cream is soft, and there is water on bags of frozen food in top basket...
You have a defrost condensate drain blockage where all the water from defrost remains inside the freezer compartment and causes the symptons you are having. I cannot tell you how to remove every model numbers freezer rear panel but I think that if you study over my link here=> Leaking Refrigerators and this link HERE you will get an idea of what to do. I am here to answer any questions, Sea Breeze
Aug 09, 2013 | Refrigerators
Was wondering if there is way to get the ice maker to make more ice.
Don't know what type of ice maker this freezer has exactly, but you can use a small battery powered fan blowing at the water tray to make it freeze faster. This device may or may not have a temp sensor, so it might not eject the cubes any sooner however.
Jan 07, 2011 | Samsung RF265AA Bottom Freezer French Door...
The ice maker drawer was left open a crack and the ice froze up and now it will not produce ice
Hi. Use a hair blow dryer to thaw out the ice maker. Remove all of the ice, warm up the tubes, be sure the ice cube molds are ice free. THEN close the door and let it make ice. The first set of new cubes will take a long time, often up to 24 hours. Joe
4 thumbs up please. ty
Oct 21, 2010 | Whirlpool GI5FSAXV Bottom Freezer French...
Sam Sung French Door Refrigerator RF267 After one month, water dispensing slow, small ice cubes, cloudy water. What is the solution?
It sounds like the water filter needs changed. Yes I see It's only been one month. Also make sure you have good water pressure to the frig.
I hope this helps.
Aug 23, 2010 | Samsung RF265AA Bottom Freezer French Door...
I got a new french door frig and it wont make ice CUBES. It makes ice and even though the indicator says cubed ice, it comes out crushed. Is there a way to fix this easily. Otherwise i like the frig very...
Try removing the ice bucket and ensure that there is no obstruction (ice cubes stuck inside of metal blades). If no obstruction, then your problem may be in the electronic dispenser control board (if applicable) that distinguishes between cubed and crushed ice. If it appears that the problem is the board, then contact an appliance service company.
Feb 10, 2010 | Samsung RF265AA Bottom Freezer French Door...
I have NEW sumsung ref. 25.5 french door with freezer at bottom
Had the same problem, your ice maker is a known defect, insist they replace it. Don't expect heavy ice output -- our biggest complaint.
Aug 30, 2008 | Samsung 25.5 Cu. Ft. Side-by-Side...
Refrigerators Logo
89 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
