Question about Tablets & eReaders
How do i restart my rca tablet
Help
RCA tablet troubleshooting. Our RCA tablet will not turn on. It has been charging but the screen is completely blank. We have attempted several times to restart the tablet. Any suggestions
RCA are cheaply made entry level tablets. Try this though. Hold the Volume Up button and the Power button for 15 seconds. If that doesn't bring it back to life, take it back and get your money back. The brand leaders are Acer, Samsung and Apple iPad.
Dec 30, 2016 | Tablets & eReaders
How do i get the safe mode to turn off?
Did you try turning the tablet off and back on?
If that doesn't help, try uninstalling the last application you installed and restart your tablet. That should hopefully start your tablet out of safe mode.
Jan 21, 2016 | RCA DWA1015D - Digital Stream 10-Inch...
RCA tablet freeze
I think this kid has the answer.
How to restart rca
Jan 05, 2016 | Tablets & eReaders
Rca 10.1 tablet rct6303w87dk with 5.0 lollipop. How do I factory hard reset?
Follow the detailed instructions below on how to completely reset your RCA Android 5.0 tablet.
Applicable models: RCT6773W22B, RCT6203W46KC, RCT6213W87DK and RCT6303W87DK
Step 1. With your tablet off, press and hold the volume up (+) button and power button until you see the RCA splash screen with Nipper and Chipper. Release both buttons to reveal the Android bot on his back with a caution symbol above him.
Step 2. A new screen will appear asking you to use your volume up/down keys to move and the power button to select.
Step 3. Use the volume down (-) button to highlight "wipe data/factory reset." Once highlighted, select using the power button.
Step 4. A new screen will appear asking you to confirm your selection. Use your volume down (-) button to highlight "Yes -- delete all user data." Press the power button to select once highlighted.
Step 5. Once the tablet is finished wiping data, you may press the power button to select "reboot system now." This will restart your tablet.
Step 6. The system will begin to reboot and once again display the RCA logo with Nipper and Chipper. The next "Welcome" screen will prompt you to select your language of choice. Scroll through the options using your finger and press start when finished. Congratulations, you have successfully reset your RCA 7 Voyager tablet.
How to completely reset your RCA Android 5 0 tablet
Nov 19, 2015 | Tablets & eReaders
RCA android tablet frozen won't do anything.
Try restarting the tablet, and see if that works. If you are unable to restart it, try removing the battery if you can. If you are finally unable to do anything, take it back to the location you purchased it from and get a new one.
Sep 06, 2015 | Tablets & eReaders
TABLET WON'T COME OFF OF THE MAIN RCA SCREEN HOW CAN I FIX THIS
If restarting does not help, then leave the tablet on until the battery drains to zero and the tablet shuts off. Then plug it in and charge it fully. When you turn it on, everything should be reset. Worked for me and have had no problems since.
May 02, 2015 | Tablets & eReaders
Rca tablet is frozen
Same with me but it got cracked so I brung it inside and it froze idk what to do :(
Dec 26, 2013 | RCA Tablets & eReaders
Tablets & eReaders Logo
137 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
