Question about Toshiba Satellite A135-S2276 Notebook
No Power to Toshiba Satellite A135-2276
Started having intermittent problems with charging mechanism. Had to start wiggling the wire to make the AC adapter power the laptop.
Replaced the charger. Seemed slightly better for a while, then worse, then it stopped powering the laptop completely.
Searched for solutions. Found the next most likely culprit to be the input jack. Got a replacement and soldered it into place. Good continuity from positive and negative pins to the motherboard. Reassembled. Still no power.
Disassembled again. Searched motherboard for some sign of a problem, couldn't recognize any. Still no power. Is there a fuse somewhere in this laptop? Can anybody think of a solution?
Plugged in and not charging
1) Use a multimeter, check the AC adapter (Charger) for power.
Make sure it is putting out the required voltage.
Have an assistant gently wiggle the cable FROM AC adapter TO laptop. See if there is an intermittent reading on the multimeter.
Have an assistant gently wiggle the power cord.
An intermittent reading on the multimeter indicates a broken wire.
Power cord is bad? Replace cord.
Cable from AC adapter to laptop is bad? Replace AC adapter.
If you have posted the laptop manufacturer NAME and MODEL NUMBER, I could have given you more than generic information.
Model Number is in the Bottom of the laptop. Post back in a Comment.
AC adapter works OK?
Check the DC Power Jack.
The DC Power Jack is the jack on the laptop, that the AC adapter plugs into.
DC Power Jack checks OK, this is your problem,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
Regards,
joecoolvette
Jan 31, 2013 | Computers & Internet
AC adapter 4750z
The solution to your problem lies in one of the following three areas:
1.) Your charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
If you need to buy a new laptop charger, the following to adapters are for your reference:
Replacement Acer Aspire 4750 AC Adapter 65Watt 19V 3.42A
Replacement Acer Aspire 4750 AC Adapter 90Watt 19V 4.74A
Nov 15, 2012 | Acer Pwr Ac Adapter For Travelmate 4750...
Hp pavilion dv6 2117ax will not power up
Since you already got a new charger, then the problem could be the power jack of the laptop and/or the connections inside the laptop.
Try to plug the power adapter slowly and try to wiggle it. It you feel that the power jack is wiggling, then the problem is a loose power jack that is why it won't charge. And you need to have a tech tighten that up for you.
Replacement HP Pavilion DV6 AC Adapter 65Watt 18.5V 3.5A Option
Oct 28, 2012 | Computers & Internet
AC adapter power connection LED blinks but not charging
This suggests to me that you need to check out the AC adapter, and see if there is an intermittent short. In otherwords a break in the wires.
AC adapter unplugged from laptop, and power, remove the AC power cord from the body of the AC adapter.
Use a multimeter set to OHM's, (1K), and connect the Positive (Red) probe lead to one of the flat bladed prongs, in the power plug that plugs into the surge protector.
Touch the Negative (Black) probe lead to one of the holes in the plug, that goes into the AC adapter 'body'.
Keep going from hole to hole, until you get a reading.
Now have an assistant gently wiggle the power cable, and see if you get an intermittent reading.
Do the same for the other plug's flat bladed prong.
Intermittent reading means replace the power cable, or if more feasible, the entire AC adapter.
Power cable proves to be fine, move on.
Plug the power cable back into the AC adapter. Plug the AC adapter into power.
Using a multimeter set to DC Voltage, touch the Positive (Red) probe lead of the multimeter, to the center hole of the plug that goes into the laptop.
(If just a symbol, the DC Voltage symbol is a dotted line over a solid line)
The Negative (Black) probe lead, touches the outside cylindrical metal shell, of the plug.
Have an assistant gently wiggle the cable, and see if there is an intermittent reading on the multimeter.
(Reading should be 18.5 Volts DC)
[There are Analog multimeters which have a scale, and a needle, and Digital multimeters that just have a digital readout.
If using an Analog multimeter the needle will drop towards 0.
If using a Digital multimeter the readout will drop to smaller numbers, or 0 ]
AC adapter checks out? Go on.
The port on your laptop where the AC adapter plugs in, is the DC Power Jack.
AC adapter unplugged from laptop, Battery removed.
Take a pencil, and gently use the eraser end to see if you can wiggle, the center pin of the DC Power Jack.
ANY perceptible movement means a problem with the DC Power Jack.
The GOOD news is that the DC Power Jack, is NOT soldered directly to the motherboard.
It slides down in a Channel on the outside edge of the Base Enclosure, and has a wiring harness coming from it.
The end of the wiring harness has a plug, that plugs into the motherboard.
The HP part number for this DC Power Harness is HP 600630-001
A) http://www.dectrader.com/600630-001-New-HP-DC-input-power-socket-connector-With-cable.html#.UD0_w6B0k9Q
B) http://www.ebay.com/itm/HP-Compaq-600630-001-DC-Power-Input-Jack-Cable-CQ42-G42-Notebook-Series-/180932154005?_trksid=p4340.m1850&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D11%26meid%3D1653940420718665976%26pid%3D100011%26prg%3D1005%26rk%3D1%26
This is a link to a free Service Manual from HP Support,
http://h10032.www1.hp.com/ctg/Manual/c02627955.pdf
Page 73 is for the Power Connector Cable.
No damage to the DC Power Jack, and the harness is not slightly unplugged?
Now you have real problems.
You have a bad Power MOSFET,
A) MOSFET:
http://en.wikipedia.org/wiki/MOSFET
B) Power MOSFET:
http://en.wikipedia.org/wiki/Power_MOSFET
C) http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
However it doesn't take a rocket scientist to replace. (Sorry Gort)
These SMD's use a J-lead contact. Simple unsoldering, and soldering.
(Better be fast though as you don't want to overheat a power transistor. Better be good, because you don't want any cold solder joints)
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 28, 2012 | HP Computers & Internet
Engine will not start
Around this shop we diagnose, and not assume.
1) Test the AC adapter (Charger)
Test with a multimeter set to DC Voltage. You should read VERY close to 19 Volts. (DC)
While testing have an assistant gently wiggle the power cord TO the AC adapter, and the power cable coming FROM the AC adapter.
See if there is an intermittent reading for either one. Indicates a break in the wire/s.
2) AC adapter checks out OK go to the DC Power Jack. This jack is the port on the side of the laptop, that the AC adapter plugs into.
(DC IN)
Remove the Battery, see if you can gently wiggle the Center Pin. Use a non-metallic object, or tool.
Also check if the metal shell inside the DC Power Jack moves around.
ANY perceptible movement indicates a problem with the DC Power Jack.
Fortunately, for this model the DC Power Jack is a Power Jack Harness,
http://www.lapdiy.com/toshiba-satellite-l305s5941-power-jack-wire-port-dc-in-cable-p-7556.html
The jack portion is a squarish shape with a channel formed around it, and sits in a cutout formed in the outside edge, of the Lower Case.
The harness coming from the jack has a plug on the end.
You just unplug it, and plug a new one back in.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L305-L305D/big/remove-lcd-screen-replace-video-cable-09.jpg
In the photo above, it shows a Toshiba Satellite L305 series Notebook PC, partially disassembled.
On the right side you see the optical drive. Squarish shaped with one corner gone. Has a large white label on it, with a smaller yellow rectangular label.
To the upper right you can barely make out a Red wire. It is connected to the black DC Power Jack.
Looking straight across from it to the Left, you see the other end of the Red wire connected to a white plug.
That's the DC Power Harness, and where it plugs in.
This is the entire article,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L305-L305D/remove-screen-replace-video-cable-2.htm
(Page 2, and 3 is listed at the top, and bottom of the page, in white.
Page1::Page2::Page3::Find another model )
Posted to show the DC Power Harness, and a pictorial guide that I feel will help get you started.
3) Power Button Board:
Has the Power On switch on it,
http://www.laptoppartsexpert.com/i-7600699-power-button-board.html
If the Power On switch is working, the laptop isn't going to turn on.
('Natch)
See the two wires coming from the board? Black and Red?
Red is the Positive wire, Black is the Negative wire.
Unplug the Power Button Board's plug to the motherboard. There are 2 pins. Carefully touch a small flat tipped screwdriver, (Jewelers is recommended), BRIEFLY to these 2 pins.
Laptop comes on you have a bad Power Button Board.
4) If none of the above is the problem you have a bad power sensor chip.
It's a Power MOSFET.
Soldered to the motherboard, and takes skill to replace.
(It's a power transistor that is used in the circuit.
Need to use Heatsinks on the J type leads when replacing, and good skills for un-soldering/soldering.
But doesn't take a rocket scientist to replace it.
{ Sorry Gort }
This example is used in a LOT of laptops,
https://docs.google.com/viewer?a=v&q=cache:oER5NNz8cwcJ:www.fairchildsemi.com/ds/FD/FDS6675BZ.pdf+Fairchild+FDS6675BZ&hl=en&pid=bl&srcid=ADGEEShOhWPjm_M-ROHme4iEMrztCTOd-28jNiy1hVLQQh_VOyv8zcXEVDB_iTQA6MuZO88UmRkDgjyW9j4CP2aIJ-4DS-h6JNM3lvxldeApQeecmz_DADCw1s7tmNLxfPknqX14SZP6&sig=AHIEtbS_rYUAeo_8rB9YHkW05ZjLqeH4Jg
Or replace the motherboard.
For additional questions or comments, please post in a Comment.
Regards,
joecoolvette
(Link to free Service Manual to be included in a Comment )
Feb 05, 2012 | Toshiba Satellite L305-S5941 Laptop
My LG laptop is not powering on. what will i do? I didn't used it for three days then when I started to turn it on. there is no power. When I put the power cord, there is no light on the battery. What...
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 06, 2011 | LG Computers & Internet
Hi i need help plz, i've my laptop do not power when i plug the ac adapter ther' is no ligth
May 23, 2011 | Dell Inspiron 2200 Notebook
My toshiba satellite l35 wont turn on,,,the light blinks then shuts off ,,,thats all it does
May 17, 2011 | Computers & Internet
My toshiba satellite pro doesn't work , even with charger in , it doesn't turn on , its like all the power is gone :o ?
You may have a bad DC connection:
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it
Dec 16, 2010 | Toshiba Satellite A60 Notebook
Advent N270 netbook will not charge. Orange light comes on initially then goes off. Also when I wiggle the plug into the laptop the light flashes on and intermittently.
It sounds like either a bad connection on the motherboard or a broken wire in the adapter making intermittent connection.
1. With the power adapter disconnected, do you have a power light? This would indicate the adapter is good and the plug is questionable.
2. Check your power adapter output with a multi-meter.(be sure to wiggle the wires around) If the power fluctuates, replace the plug.
3. If the power is solid, replace the motherboard connector.
Nov 22, 2010 | Intel Computers & Internet
Toshiba Satellite A135-S2276 Notebook Logo
367 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
