Question about 1003-0097 Yamaha YFM 250X Bear Tracker CARBURETOR CARB REPAIR KIT 1999-2004 Moose 10030097
Does not have fire coming to the sparkplug. - 1003-0097 Yamaha YFM 250X Bear Tracker CARBURETOR CARB REPAIR KIT 1999-2004 Moose 10030097
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1003-0097 Master
  • 1,190 Answers
Check plug cap resistance against a new one ! touch ht lead to earth or if your brave hold it and crank engine ! it wont kill you !
Posted on Jul 10, 2014
Tao tao manual
You need to first determine whether the problem is fuel or electrical. Remove the sparkplug and pour in a small quantity of gas. Replace sparkplug and high tension lead. Crank it over. If it does start and run a bit then your problem is fuel and not electrical. If it does not fire and the sparkplug is wet, then start be replacing the sparkplug with a new one.
Sep 06, 2014 | RTO 125cc Full Size Adult 4 Wheelers ATV...
Scag zero turn 52"deck tiger mower
If you have spark, compression, and fuel to the carb but not at the plug. You have a clogged carb. Try starting with starting fluid, if it fires briefly, your carb needs to be removed and cleaned.
Sep 03, 2013 | Garden
Firing order for sparkplugs 2005 pathfinder
Firing order: 1-5-3-6-2-4 distributor rotation: counterclockwise. ...
Mar 13, 2010 | 2005 Nissan Pathfinder
How to replace spark plugs for 1999 ford contour
to replace spark plugs remove spark plug wire boots. use special sparkplug socket or else you can break the sparkplug. to remove turn ratchet counterclockwise remove all four one at a time, make sure that the sparkplug gap is correct. most plugs come pregapped...read the box it will tell.you. do not overtigheten plug once it has fully seated give it a good snug....if you do one at a time you dont need to mark the spark plug wires. if you mix up the wires your car will back fire which could cause severe internal damage.
Feb 13, 2010 | 1999 Ford Contour
I have two codes that come up for my 2005 dodge
Multiple miss-fire and miss-fire on #5. I would first change the sparkplugs then replace the distributor cap and rotor. There is a good chance this will fix the problem, but no guarentees.
Nov 09, 2009 | 2005 Dodge Stratus
03 ford taurus wont fire ,spins over,no fire
What you do is take either and old sparkplug from the car or pull one from the car and connect one of the sparkplug wires to it. Then with an insulated set of pliers hold the sparkplug so the electrode is grounded. Then have someone crank the car over. This is best done at night so you can see if there is a spark. During the day however you should be able to here a spark. If not probably a bad coil.
Jul 20, 2009 | 2003 Ford Taurus
No Spark
The " FIRE" doesnt come to the coil from any of those things you have changed.......The "fire" comes from the coil TO those items!!!! Good luck, RC
Mar 06, 2009 | 1996 Jeep Cherokee Country
1003-0097 Yamaha YFM 250X Bear Tracker CARBURETOR CARB REPAIR KIT 1999-2004 Moose 10030097 Logo
123 people viewed this question
Top 1003-0097 Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a 1003-0097 Boating Expert? Answer questions, earn points and help others
