Question about Toys
My radio contrled street pounderz corvette will not do snything
With all the batteries in place and switch on bottom of car turned on it will not do anything. is there another switch that needs to be turned on?
  • MissBliss SkinnyWraps NV
    I am having the same issue. I have had this issue with every Street Pounderz rc cars that my son has ever gotten. I try to stay away from them but after getting at least 5 of them I want them to send me at least 1 car that actually works! Let me know if you get your issues resolved. I\'m trying to find a way to contact the company so I can request a new one. morgan.bliss55@gmail.com. Thanks!
  • ashley c
    ashley c Dec 02, 2014
    Also having the same problem with the one my son got for his birthday. We've changed batteries etc and nothing works. Will one of you please let me know. I thought about emailing the company but i've seen a lot of reviews where people have had no luck doing that. my email is angelbaby8486@gmail.com. thanks!
I need the radio wiring color diagram for my delco radio, 1998 corvette
1998 Chevrolet Corvette Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Orange
Radio Switched 12V+ Wire: Yellow
Radio Ground Wire: Black
Radio Illumination Wire: Gray
Radio Dimmer Wire: Brown
Radio Power Antenna Trigger Wire: Pink
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 4? Speakers
Front Speakers Location: Kick Panels
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6?
Rear Speakers Location: Rear Sides
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
Dec 22, 2016 | Cars & Trucks
Steering wheel controls do not work on radio
By Who?
Was the Battery disconnected? in the Process?
Sounds Like a possible short in the Sound contrl Module
Jan 06, 2014 | 2009 Chevrolet Chevrolet Malibu LT
2009 street glide won't crank
Is the kill switch "on"?
If so then find starter and bridge contacts to see if it cranks.
Sep 12, 2012 | 2009 Harley Davidson FLHX Street Glide
How do i remove a ignition swith on a 1971 corvette
I believe the ign. switch sits on top of the steering columbe diconnect - battery cable lossen the 2 nuts that hold steering colume in place take of the nuts if necessary to get to ign switch,unplug electrical connector from switch remove & replace switch &bolt back up the steering columb dont over tighten or pinch electrical lines whendrawing steering columb back up reconnect - battery cable
May 30, 2011 | 1972 Chevrolet Corvette
How do you remove the battery from a 1992 corvette
Access is by removal of the exterior side panel. There are two 10mm bolts on top and bottom of the panel, the top needs to be removed, the bottom just loosened. There are 3 Torx screws inside the wheel well, difficult to remove with the tire in place unless you turn the steering to a stop, or use a Torx bit in a wrench. Bolt securing the battery on its base facing the driver seat needs to be removed.
Feb 28, 2011 | 1992 Chevrolet Corvette
1994 corvette air conditioner cold air during acceration and then on deceration it blows out hot air. And in the winter the heat blows cold during driving and gets warmer when not accerating and slower...
On the a/c send the radiator to flush,as for the heater you need to check the vacuum hoses that goes into the contrl panel,check for a leak on vacuum in the engine as well.
Sep 24, 2010 | 1994 Chevrolet Corvette
I have a 1993 corvette and I can not find my manual. I'm trying to figure out how to remove the battery. Any suggestions?
Open the hood and locate your battery. The side panel next to the battery comes off. You'll notice one nut on top securing it in place. Look at the bottom of the same panel and you,ll notice two more nuts. Remove the top nut and loosen the two bottoms one and remove the panel.
Snake
Aug 24, 2010 | 1993 Chevrolet Corvette
Antenna will not go up or down,but still has
Have the antenna motor tested re place it if not working if antenna motor is working you will need a new antenna mast and antenna cable to remove this unscrew the washer nut at the base of the antenna and turn radio on antenna should push up and play out he cable to replace insert new cable and turn radio off it will draw cable in and antenna tighten washer nut and your dne
Aug 07, 2009 | 1993 Chevrolet Corvette
My Radio on a 1995 Corvette would not turn on
you will need the code . If you disconnect the battery you want to have a device that plugs into your radio so that this doesn't happen . contact a dealer they will help you with getting the code
Mar 22, 2009 | 1995 Chevrolet Corvette
Safety 1st yellow corvette
Below the radio is a panel held on by two knobs labelled "driver" and "passenger." Unscrew these knobs to get to the radio battery cover. Remove the battery cover with a phillips screwdriver and replace the batteries.
May 15, 2008 | 2004 Chevrolet Corvette
Toys Logo
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
