Question about Dryers
Replacement igniting replacement
All the lights work theres no response will not trun the drum
If you can hear motor running, it is possible the belt (from motor to drum) has broken or is slipping. If you cannot hear motor, it is likely an electrical problem; maybe safety start/stop switch in door, or wire connector has vibrated loose, or computer brain failure.
Posted on Dec 25, 2013
Printer ask for cartridges
turn off your printer...then replace new cartidges.after replacing cartridge restart printer...always when you want to change or replace cartridge/Drum/fixing/belt trun off your printer...
Jul 12, 2012 | Lexmark X9575 InkJet Printer
Hi, we have the hp color laserjet 2840 series and we are getting a supply error (10.1004). The picture shows that there is a problem with our imaging drum. We bought a brand new imagind drum and it is...
Reseat the toner cartridge. Turn the printer off, and then back on again. You may want to try a new cartridge, but if that does not eliminate the error, call your HP support line. If the imaging-drum light is still blinking but the Attention light is not on, you must replace the imaging drum before the printer can continue printing. The imaging-drum light might be blinking by itself or at the same time another light is on or blinking. If another light is also on or blinking, turn the imaging-drum light off in the simulator and turn the other light on or blinking to isolate the condition. The printer has determined that it cannot read or write to the e-label on the imaging drum.Reseat the imaging drum, and then power cycle the printer. If this does not work, replace the imaging drum. If the imaging drum light is still blinking but the Attention light is not on, turn the printer off, and then back on. If the problem persists, replace the imaging drum E-label reader. The imaging-drum light might be blinking by itself or at the same time another light is on or blinking. If another light is also on or blinking, turn the imaging-drum light off in the simulator and turn the other light on or blinking to isolate the condition.
If Hope that this helps,, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks,Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 04, 2011 | Office Equipment & Supplies
It will trun on but will not run. You can set the controls and hear a click and then it will just go though the mode with the lights and never trun the drum.Brand New
hello make sure the long pin that sits inside the door is connected this makes the motor turn if ok the it could be the capacitor next to the motor in side the dryer also check the belt it may snaped good luck
regards
shaun
Aug 02, 2010 | Dryers
No response from ignition dead
check and replace if worn out ignition wire ,ignition solinoid and the wires connected to the ignition switch up to the battery.
Jul 27, 2009 | Orion Vehicle Parts & Accessories
2000 mercury mystique can not get drum back on after replacing brakes
make sure the brake shoe fits in the drum and is seated tip to tip and you can push it all the way around the inside of the drum.
then install the shoes.
and then trun the adjuster screw all theway in to colapse the shoes in all theway.then the drum will fit.
the adjust the adjuster screw back out untill it just begins to rub on the drum.not tight at all just enough to rub very lightly.
after a few miles you may have to go back to the rear brakes and adjust them a little more.
proper adjustment in the rear shoes is important to a good strong pedal.
hope this helps
thank you
jm
Jun 18, 2009 | 2000 Mercury Mystique
My run lights dont trun on
Check for a Burned out Bulb on these Lights. I had one of these in School and it Did this. Had a Bulb Blown. Replaced it and they Started Working Just Fine. Please Rate My Response! Thanks!
Feb 01, 2009 | 1984 Oldsmobile Cutlass
2000 ford windstar wont shift out of park
do the trun sigals work and have check the fuse. take a test light go to the brake light switch one side of the switch will be hot all the time the other will show power after you close the switch . stepping on the pedal close the switch. so if you have no power to the switch it will not work , check the fuse before going any fruther good luck kdc744
Jan 18, 2009 | 2000 Ford Windstar
Oven will not light
ignitor lights up , so im assuming its a glow bar style ignitor. replace it, although its glowing its not glowing strong enough to release gas from the valve, the fact that it lights at all is a sign that the vavle isgood and control to turn it on as well!Common,Common problem
Jan 25, 2008 | Whirlpool GS460 Gas Kitchen Range
GE Oven does not light - no gas smell and no electronic ignition clicking sound
It probably needs an oven igniter. Remove oven racks. Remove oven floor. Usually 2 screws towards back. Remove flame spreader if it has one. You can see long tube with holes in sides and igniter with 2 wires from rear. Now try oven. See if igniter glows. If it does but doesn't light within 1 minute, replace igniter.
If it doesn't glow, you need to check for power to igniter. Should be about 100 volts. If not may need ERC, "Electronic Range Control".
Nov 19, 2007 | GE JGRP17 Gas Single Oven
Dryers Logo
41 people viewed this question
Top Dryers Experts
