Question about Acer Aspire 5315 Notebook
Dull light while charging and bright when not charging
While its charging the screen is very dull when i take the charger off the screen lights go bright as they should be
I have dell inspiron n5110 get charging problem sometimes then after a week my display becomes dim. I can able to see that my display is working with without brightness. I connect it to external display it...
Is the brightness ok if the charger is connected to the laptop and dull when the charger is not connected - also what operatng system are you using ???
Oct 13, 2013 | Computers & Internet
Usually when i plug in the charger to computer the screens gets brighter, it no longer does that, my screen is very dull and not bright how can fix?
you can change that in power settings right click on the battery bottom right of the screen hit change power settings u will get options u want to change power settings look at the options you want to make it stay brite all the time right now you have it set to be brite only when plug is in change the option when its unplugged to brite also
Aug 10, 2012 | Acer Aspire 7741z
Samsung r519 charging port problem
Try someone elses charger in your pc, if same fault, its your pc
Jul 09, 2012 | Samsung R519-53S Notebook
My toshiba satallite p200-1ee laptop is not charging. Battry life left: 40% When on: The Charging light blinks 3 times every few seconds and the screen dims with it. When off (But pugged into mains): the...
If you plug the charger into the computer without the battery and the laptop runs fine, then I would suggest to you that your battery is failing and will no longer accept the charge. On the other hand if the laptop will not stay running or acts strage and the screen dims and gets bright, then I would suggest to you that the charger's built in voltage regulator is failing and will damage the laptop if it continued to be used. A bad charger will also permenently destroy the battery condition.
Dec 01, 2009 | Computers & Internet
Audi A6 2006 problem with battery
Yes
First thing is to test the battery and this is how Turn on head lights, if dull leave on to see how long the stay on for. Next turn lights off put battery on charge for 6 hrs .Turn on lights again if still dull either battery or charger no good
If lights bright try to start and when starter trys to turn engine over the lights go dim THEN battery is no good.
Then get a jump start from another battery and put pos term on both batterys first, then earth lead(BLACK) on last then start if starts ok remove the BLACK lead and turn on head lights if goes bright ALTERNATORs ok so replace battery ....
Sep 22, 2009 | 2006 Audi A6
Toshiba Equium laptop not powering up.....dead!
hardware problem chech the board.. maybe the regulator is damage.. need to change.. if you can't do just bring to certified laptop technican.. to fix your unit
Jun 11, 2009 | Computers & Internet
I have acer 4315 aspire model.. i have a very dull screen.. it was fine before when i bought it. but after 3 months now it is very dull.. Though the brightness is full 100% please help me, thanks.
the brightness light might gone bad. u have to examine the system by a authorized service centre or some qulified technicain.  may be hey could repair it without replacement of screen.
Nov 18, 2008 | Computers & Internet
Screen to dark
ya there is a option in your laptop in power option 1 is performance please active this option .then u never face this type of problem
Jun 08, 2008 | Compaq Presario 700 470024-192 Notebook
Dull screen lighting
There may be a bios setting to adjust the screen brightness or a utility installed in Windows - What brand and model laptop is it???
Jan 12, 2008 | Computers & Internet
Acer Aspire 5315 Notebook Logo
559 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
