Question about Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304)
I'd like to add the new notebook to my network.
I'd like to add the new notebook to my home network. But I forgot the password for config the new client for Belkin54g (ADSL2 + G Router).
How should I do?
Thank you in advance,
Aeron
  • 94 Answers
You will need to reset the router to factory by holding in the reset button if you don't have the password. Before you do that, however, you will need your user name and password to re-configure and connect to the DSL provider. When you configure the wirelss network settings, write down your wireless password which should be different from the password you create to log in to the router.
Posted on May 18, 2009
For security purposes, this process cannot be disclosed in an online guide. For assistance resetting an L-series firmware password, please contact NComputing technical support directly at http://www.ncomputing.com/techsupport
Sep 01, 2014 | NComputing L230 Network Terminal
I forgot a password and i cant access a catalyst 2960 24-port 10/10
You can only reset password this way:
1.
Attach a terminal or PC with terminal emulation (for example, Hyper Terminal) to the console port of the switch.
Use the following terminal settings:
  • Bits per second (baud): 9600
  • Data bits: 8
  • Parity: None
  • Stop bits: 1
  • Flow Control: Xon/Xoff
2.Unplug the power cable.
3. Hold down the mode button located on the left side of the front panel, while you reconnect the power cable to the switch
4. Release the Mode button when the SYST LED blinks amber and then turns solid green. When you release the Mode button, the SYST LED blinks green.
5. switch: flash_init
6. switch: load_helper
7. switch: dir flash:
8. switch: rename flash:config.text flash:config.old
Rename config.text to config.old. In that file the password is stored.
9. switch: boot
10. Enter "n" at the prompt to abort the initial configuration dialog
11. Type en to enable
12. Switch#rename flash:config.old flash:config.text
13. Switch#copy flash:config.text system:running-config
14. Overwrite the current passwords:
conf term
enable secret <new pass>
enable password <new pass>
line vty 0 15
password <new pass>
login
line con 0
password <new pass>
15. write memory
16. copy run start
Sep 25, 2013 | Cisco Catalyst Computers & Internet
D-Link wireless router forgot password how may I recover or assign a new one
A wireless router password wont be recovered unless you still have the password you can enter or if the router is unmanaged without an admin password.
another option would be resetting your router to be able to get through the router and assign a new password.
here's how: you need to directly connect your computer or laptop wired going to your router not using a wireless one. then reset, make a new network configuration and put your admin password later. dont forget to backup your router config. in a folder together with your password so the nextime you forgot any thing or change anything. just look back to your folder where you put your backup config. and password.
Jun 24, 2012 | D-Link Computers & Internet
Forgot user name and password need to add new
Sorry but this is the only to reset the password
Press the Reset Button for approximately 10 seconds
Resetting the Router will erase all of your settings (WEP Encryption, Wireless and LAN settings, etc.) and replace them with the factory defaults.
Jun 06, 2011 | Linksys Wireless-G WRT54G Router
Hi Team, My phone does not automatically connect to my home wifi. How do I get it to do that? Thanks B.
By default, Android will remember. If due to whatever reason it 'forgot' then you may add it manually.
1. Go to Wireless & networks menu
2. Select Wi-Fi settings
3. Choose a listed network, or add a hidden network by selecting add Wi-Fi network
4. If the network is encrypted then enter the password.
5. If your home network is not broadcasting (hidden network), then select Add Wi-Fi network and enter the SSID name
6. Provide the WEP/WPA key.
Hope this helps
Mar 09, 2011 | Samsung Galaxy S GTI9000 Smartphone
Not able to go online
have you been online with this computer before?
or
Are you setting up for the first time?
Once you have an Internet Service Provider ,ISP,
you just need a modem and phone line access,
plug modem into phone socket and then into the computer,
My example modem is.........
Speed Touch 5x6v6 - Broadband Modem
log on to the modem using Internet Explorer Bar
Type 192.168.254
this will open the modems log on menu
then enter user name and password
its factory default is
user ADMIN
password ADMIN or 1234
once open there are some menu options on the main page
Speed Touch,
Broadband Connection,
Toolbox,
Home Network,
to add new user and password,
go to toolbox,
user management,
add new user
add password,(write down username and password)
change default user
save and test
should have a green tick next to new default user now
selecting broadband ... shows both your,
dsl connection and internet connection status,
with a green tick next to each heading.
Home network will show you...
all devices connected to this modems network ie
the other computers and printers etc,
connected on your network.
In network ,select your computer in the menu tree,
select configure
this give you a menu to add info about your computer
ie name info, comupters ip address,
access to the local intranet or the internet
Now lets connect to the internet
select Broadband from fornt page
menu will open and display
DSL & Internet Connections
here we test functionality.on? or off?
Now we go to your computer,
start my network connection
run wizard in my network places
select new connection
follow prompts to the end.
open internet explorer
if web page opens then we are done and finished,
open tools and internet options,
connections and then lan settings
select automatically detect
Apply then close
Test webpage again,
when ok shut down and restart,
to save the computers new settings ,
Test again with internet explorrer.
if no connections run wizard again,
Hope this Helps,Cheers Misterdj
Apr 18, 2010 | IBM ThinkPad T30 2366 Notebook
Forgot factory default name and password for my Pansonic BL-C131
There's a reset button. It'll clear the user config. There is no default account.
May 10, 2009 | Panasonic BL-C131 Network Camera
I forgot my friendster email add and password,plz help me
go to friendster home.. then look for search option by name  then type the name you use in your account.. theres a lot of name could appear maybe you could find it there..
Jan 07, 2009 | Computers & Internet
Password
Well... If you forgot the password to your new email account at Yahoo, then I would recommend using their password recovery console. You can find this at...
http://us.rd.yahoo.com/reg/login1/suli/forgot_lib/us/fpctx/*https://edit.yahoo.com/config/eval_forgot_pw?new=1&.done=http%3A//www.yahoo.com&.src=fpctx&partner=&.intl=us&pkg=&stepid=&.pd=fpctx_ver%3d0%26c=&.ab=&.last=
You will need to know your Yahoo ID in order to use this feature, of course. I am assuming that you know what your Yahoo ID is.
Good luck.
Cyryl
Nov 10, 2007 | HP Compaq Presario V2000 Notebook
Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304) Logo
165 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
