Question about Dishwashers
Fills with water when not in use
Kenmore dishwasher model 665.1760400 My dishwasher (6 year old) is starting to fill with water when not in use. There is about an inch of standing water in the bottom. After I drain it, it slowly fills again. Pulled it out from the wall. Didn't see any apparent problems.
There is a solenoid on the front left under the access panel at the bottom of the dishwasher. The water line goes into this solenoid. The solenoid may be letting water into the dishwasher so either clean or replace the solenoid.
Posted on Jun 26, 2009
  • 3 Answers
This is meant to happen
Posted on May 17, 2009
  • redder89 May 17, 2009
    this is meant to happen
I have a Kenmore dishwasher, not sure of the model or year (less than 10 years old) but water constantly flows into the dishwasher. So much so that it leaked all over the floor because the bottom filled up...
Hello.
If it's filling all the time when dishwasher is not even running? The water inlet valve that the house water supply connects to at the dishwasher,is sticking open and needs to be replaced..what you can do now to stop it from constantlu filling is turn off water supply to the d/w from under the kitchen sink.
Typically the model number is on a label on the egde of the door inside or on the rim of the tub..it would be needed to order a water valve
Gene
Aug 24, 2011 | Dishwashers
My Kenmore ultra wash 6651736 dishwasher broke almost to the month it turned 6 years old and I'm trying to decide if I should fix it or buy new.It washed wonderfully up to the day it stopped .the water...
very common issue on these units, the motor had failed, the motor did have a five yer warranty but we are beyond that.
You can purchase the part from the link below,
http://www.appliancerepairlesson.com/
Mar 08, 2011 | Kenmore Dishwashers
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
I just bought a good used 4 year old dishwasher
check to see if the fill hose or inlet hose is kinked , or u need a new water valve or flow meter
Oct 27, 2009 | Kenmore Dishwashers
My Kenmore dishwasher starts to fill and then stops
I've got the same dishwasher....mine is 2 years old and used only 3 times a week and now the motor is burnt out. I understand that this unit is a Frigidaire and is one of the worst ..quality speaking. I guess that why they only provide an one year warranty. Unfortunately, we got a LEMON
Oct 04, 2009 | Kenmore Dishwashers
Kenmore 665.16039403 leaks water when filling
It is coming from the fill tube. You can pull the unit out or use a mirror to look up underneath. It might have come off or got a hole chewed in it.
Eric
Sep 25, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
GE Dishwasher fills with water but does not "spray water" on dish
Here are a few things that might help you out, first is you could have a bad heating element in your dish washer, when it fills with water it has to reach a certain temperature before continuing to the next cycle, next thing is you could have a bad thermostat, or your timer is defective.
Mar 16, 2009 | Kenmore 16522 Built-in Dishwasher
While not in operation dishwasher slowly fills up.
water valve is clogged try to turn your valve to dishwasher under sink
Nov 29, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore Model 665.17669400
i think you found a solution -- by posting it on craigslist-- why dont you mention this porblem in your ad??
May 24, 2008 | Dishwashers
Dishes not getting clean
when your dishwasher was reinstalled was the discharge hose loop up high behind dishwasher to prevent the water from draining? Also make sure that there is air gap where the hose ties into the drain.
Nov 22, 2006 | Kenmore 18 in. 14432 / 14439 Built-in...
Dishwashers Logo
160 people viewed this question
Top Dishwashers Experts
Owen Barnes
