Question about Cell Phones
Need owners manual
Auger belt to fit a Landmark/supreme snow blower, model # 310941503
boscia
  • 163 Answers
SOURCE: Transmission on snow blower-sears
most snow blowers are belt driven instead of hydraulic drive. it sound like the belt needs replaced.
Posted on Nov 30, 2008
boscia
  • 163 Answers
SOURCE: snow thrower won't throw snow
the problem could be the snow is to heavy for the motor to keep up, if thats the case you may need to upgrade to a more powerful model or try not to overload it. take it a little slower so the motor can keep up. but try tightening the belt. with your pointer finger push down on the belt it should have about a half inch give, if it moves more than that its too loose and probably slipping under load
Posted on Dec 13, 2008
SOURCE: My toro 1128 OE snow blower wont throw snow the
I have a toro 98 cc powerlite snowblower model 38182 it was running fine one day then bog down and died after that i cant get it to start it has a good fire on the plug plug isnt very wet it pops threw carb once in a while help
Posted on Dec 27, 2009
  • 151 Answers
SOURCE: snow blower auger keeps running when not
sounds like the tension adjustment is tight or sticking check for proper tension and that the action is not froze up
ToolBoxHero
  • 171 Answers
SOURCE: changing auger belt on snow blower
The most common cause of this is the drive belt is worn. If you remove the cover (usually plastic) in the middle of the snow thrower and look at the belts.
Your operator's manual will show you how to remove the cover and check/change the belts.
I am going to assume you have a Craftsman snow blower. If you don't have a copy you can get the manual through managemyhome.com
You will need the model number off the snowblower. It is usually located on the bottom right hand corner of the frame (from the handle side)
The model number looks like 247.123456.
The belt closest to the blower assembly drive the auger/blower and the belt closest to the engine drive the transmission.
With the engine not running, have someone depress the drive lever and check the belt.
You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced.
On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
The belt may be frayed on the edges or glazed causing it to slip (it is shiny on the sides of the belt) It may be torn and broke completely.
Your Craftsman manual will show you step by step how to change th belt.
You can get parts for you Craftsman and most MTD made models through searspartsdirect.com. With other makes you can get parts through jackssmallengines.com
If you are unfamiliar with repairing machines you can get your snow blower repaired by taking it to your local Sears.
They will have a technician troubleshoot and repair the unit.
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Posted on Jan 13, 2011
Belt sizes
Go to www.searspartsdirect.com and check what they list against what you got.
Nov 01, 2016 | Garden
Snowblower....auger takes time to get going...like five minutes...it will struggle to start spinning then eventually warms up and is fine....whats the issue?
It is most likely your auger drive belts. There are two of them, and they need to be replaced periodically. Your manual should describe in detail as to how to replace the belts. Always start by removing the spark plug wire.
Improper gearcase lubricant could also cause problems. Your manual should tell you specifically what to use in the gearcase, and how to fill it. Also look for grease fittings on the auger and use a low-temp grease to service those fittings.
Lastly; behind the auger is the impeller shaft. Reach in and see if it wiggles. If it does, then have your impeller bearing replaced.
Feb 13, 2015 | Craftsman Snow Blower / Snowblower Bottom...
Auger does not engage on Ariens Model 924121 sno- Thro
first check shear pins in the auger ( try to turn big auger by hand, engine off)
then if they are good then try to turn impeller by hand, engine off
youll need to turn it a few times before the larger ones turn, but thats what you want
if they dont turn then you have sheared the gear box gears
be sure belts are good tooo
Dec 15, 2013 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
I have a 3 yr old 26" snow blower. I ran the machine up against hard packed snow/ice and now the auger spins freely and all shear pins are still in place. The secondary impellor functions fine. I...
I am going to assume the belt is good if the impeller it running. You can check the belt by removing the plastic cover in the center of the snow blower.
With the unit safely turned off reach in and turn the blower by hand while putting a little resistance with your other hand on the impeller. Does the shaft from the impeller to the gear box turn?
Does the shaft that the augers are attached to turn? If the impeller shaft turns but the auger shaft doesn't, the gearbox in the front is bad and will have to be replaced.
I the auger shaft turns, check your shear pins again. Sometimes they will break but still stay stuck in the holes. Actually take one out and check it.
If it is a Craftsman you can get a manual from managemyhome.com and parts from searspartsdirect.com. You will need the model number of the snowblower. The number looks like 247.123456.
Any other questions please ask. Do't forget to rate this answer!
Jan 16, 2011 | Craftsman Garden
Snowblower doesn't throw the snow very far, and every time I stop it, it takes a while for the auger to start turning fast enough to blow the snow. Feels like the torque isn't there. This is a Husqvarna...
The belt closest to the blower assembly drives the auger/blower and the belt closest to the engine drives the transmission.
With the engine not running, have someone depress the drive lever and check the blower belt.
You can get parts for you Craftsman and most Husqvarana, MTD made models through searspartsdirect.com. You can also get parts through jackssmallengines.com or your local dealer.
If you are unfamiliar with repairing machines take it to your local dealer. They will have a technician troubleshoot and repair the unit.
Feel free to ask any other questions to troubleshoot this problem farther. I know Snow Blowers. Please remember to rate this answer!
Jan 13, 2011 | Garden
Changing auger belt on snow blower
Jan 13, 2011 | Craftsman 16" High Garden Tractor Snow and...
I have craftsman snow blower 5 hp 24inch model #
does the impeller spin and not the augers.if so check sheer bolts.if neither impeller or auger spins check auger belt.
Feb 22, 2009 | Craftsman 16" High Garden Tractor Snow and...
Snow thrower won't throw snow
Dec 13, 2008 | Toro Blowers Rake and Vac - Electric...
Cell Phones Logo
43 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
