Question about Samsung Televison & Video
Samsung flatscreen tv model LN46C600F3FXZX has sound but no picture
Samsung flatscreen tv model LN46C600F3FXZX will turn on, has sound but no picture, picture went out while watching it, unplugged set for 5 minutes and still nothing, unplugged for 24 hrs. and still nothing, please help.
  • Samsung Master
  • 1,511 Answers
Video section has become compromised and no longer functional. Audio being separate from the Video may work perfectly, but the Video portion sustained damage to the circuit board or the inline safety diode blew. If any parts of the Circuit Board fail, you need to replace the mainboard. The cost to generally fix a circuit board is usually more than the replacement cost for a new unit. Check all fuses or circuit limiters inside the TV and if there are no shorts, burned parts, or obvious smells on the mainboard, transient current may have trickled in and damaged sensitive electronics. Have a professional Technician do tests to locate the source of the problem.
Posted on Dec 25, 2013
    Top Expert:
  • Samsung Master
  • 42,927 Answers
There probably has been an internal power supply failure.
4 Suggested Answers
Fujitsu
  • 29 Answers
SOURCE: Hitachi Plasma TV model P50H401
I think you have problems with the digital main PWB.
If the power PWB failed, turn off and change the pilot ligth to red.
Posted on Nov 28, 2008
SOURCE: vizio vx42l hdtv back light
Vizio VX42L has sound but no picture, tried other connections
Posted on Apr 16, 2009
toolkits
  • 1099 Answers
SOURCE: I have no color on my Samsung Flatscreen TV
This means absolutely no color - equivalent to a black and white picture. Not even a hint of color.
First, confirm that the source is actually in color - try another channel or input device.
Next, check the settings of the color control - it may have accidentally been turned down. If your TV has some kind of automatic picture mode, try turning if off and adjusting the color control. Try adjusting fine tuning if you have such a control and the problem is with a broadcast or cable transmission.
At this point with a confirmed color signal source, there is a problem with the chroma circuitry.
Note that to the average person, the obvious question becomes: is my color picture tube bad? The answer is a definitive NO. It is virtually impossible for a defective CRT to cause a total loss of color. A defective CRT can cause a lack of a primary color - R, G, or, B or a short between two colors which will mess up the color but is not likely to result in a black and white picture.
Some possibilities in no particular order:
Weak signal or defect in tuner/IF causing loss of signal strength.
Coler killer set too high (internal control) if it has one.
Defective part around the chroma chip/circuit. Faulty color oscillator.
Bad connections in area of chroma chip/circuit.
Defective chroma chip (don't suspect this first just because it is probably very expensive).
Try prodding the main board around the chroma chip with an insulated tool to see if you can make the color come and go.
I had one set where a $.02 resistor decided to open up causing just this problem - perfect BW picture, no color. Another had a coil with a broken wire.
Posted on Jun 14, 2010
Tohiba 42" flatscreen, model # 42sl417u
Have if you can a look at the power supply board for signs of damaged parts and do not over look the filter caps there---see typical bad ones from mild to extreme:
Dec 07, 2012 | Toshiba 42 42SL417U 42 LCD TV
No picture on my flat screen sony. got sound. remote works. no picture. can it be fixed?
Sounds like an older tv---to help I need to know the model number (KV or KP?)
Mar 31, 2012 | Televison & Video
I hace a samsung flatscreen that the screen flickers with no picture and turns itself on and off.
Hi this is a power supply issue. Your power supply is not strong enough to power your tv anymore.
You can get get parts for this tv at www.interliquidparts.com
Nov 19, 2011 | Samsung HP-T4254 42 in. Plasma Television
I have a philips flatscreen (32PF5331 / 12) that I bought it around 3 years ago. Everytime I turn on the TV, I only get the sound then I should turn the TV on and off (sometimes 5-10 times) before I...
Hello, not positive what part you need...but it sounds like maybe the main board needs replacing. I have purchased parts many times from a company named ShopJimmy.com. I included a link to the part from their site for your model. Hope that helps!
TeeVeeMan2@gmail.com
http://www.shopjimmy.com/catalogsearch/result/?q=32PF5331
Aug 25, 2011 | Philips Televison & Video
Phillips 47" flatscreen sounds still
If the TV menu displays your problem is most likely not the Tv , but is caused by the signal source:
Cable box or connections. Reboot everything test using other sources like a DVD player to isolate the problem.
Aug 20, 2011 | Televison & Video
Can I turn on the samsung flatscreen without a remote? The remote got water in it and will not work. Does the tv have a power button located on the tv?
Yes, channel buttons, sound buttons and power button is located at the side of the screen. Look for it. For most TV's its located behind and for some at the side and for some in the front bottom.
Nov 24, 2009 | Samsung 52 in. LCD Flat-Panel HDTV
Ive got a 29'' tube flatscreen that wont work no more
seems to be an issue with picture tube.Please try after changing picture tube
Jul 28, 2009 | Televison & Video
Sound only with a black screen.
sounds like the backlight is out, can you see a picture when shining a flashlight on the screen. if yes you have either a bad inverter power supply or bad screen (panel).
both are serious , also could be just a few bad capacitors on the power supply, if you want you can do a visual of the power board caps will appear swollen on top and are easy to solder in if you have a soldering iron
Jul 26, 2009 | Samsung PPM42M8HB Plasma TV
Televison & Video Logo
89 people viewed this question
Jerry Greenberg
Jerry Greenberg
