Question about Nikon D90 Digital Camera with 18-105mm lens
Tight manual focus
Rotating manual focus ring - very tight. How can this be loosened
Fha mortgage loan
https://callmortgageloan.com
Posted on Oct 09, 2019
Cheap SR22 Insurance Quote https://sr22insurancenow.com/
Posted on Aug 14, 2019
SOURCE:
My manual focus ring is so tight that I can barely focus. Is there any way to lubricate or loosen this ring short of sending it out to Nikon for repair?
I'm assuming this is a DSLR camera and not a point-and-shoot. If the camera body is not set for manual focus, the focus ring on the lens will not turn.
Sep 09, 2011 | Cameras
I cant focus my a4 tech webcam pk-335mb
All webcams have a ring around the lens. If you rotate this ring then you would be able to focus on to an object. Try rotating it both clock and anti clock wise to focus.
Dec 28, 2010 | Cameras
I want to change two belts (A/C and Alternator) on my 1999 Mitsubishi Mirage 1.5 car. What steps I am suppose to do.
First, feel the tightness of your belts. You will have to tighten the new belts to the proper tightness. If they are too tight, they will wear the bearings prematurely. If they are too loose, they will slip.
Alternator Belt Removal
  1. Loosen the alternator lock nut.
  2. Loosen the adjuster bolt.
  3. Rotate the adjuster bolt counter clockwise to release the tension on the belt.
  4. Remove the belt.
Similarly for the compressor belt
  1. Loosen the lock nut.
  4. Remove the belt.
5. Install the new compressor belt
6. Rotate the adjuster bolt clockwise until the belt is tight like it was before you removed it.
7. Tighten the lock bolt.
8. Install the new alternator belt
9. Rotate the adjuster bolt clockwise until the belt is tight like it was before you removed it.
10. Tighten the lock bolt.
11. enjoy life
Oct 12, 2010 | 1999 Mitsubishi Mirage
Problem with my webcam device ''Micro Pack''
There is something known as focusing. I am sure you are aware of the phenomenon. Someone or you have inadvertently rotated the ring around the lens and changed the focus of the camera. So now all you have to do is to start the camera and sit in front of it and rotate the ring around the lens clockwise and anticlockwise till you get a perfect picture of yourself. Rotate the ring slowly so that you can concentrate on your picture's clarity and focusing.
Nov 18, 2009 | Computers & Internet
Canon lins
This is normal. The zoom ring will stop at each end of the zoom range, but the focus ring will rotate freely, there is no "end" or "stop" to the focus ring.
Apr 07, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Focusing ring looseness on 50/1.2 M-Hexanon
did you see any rubber gasket on the ring.. this could be the one turn out to be loosen,
did you dropped or any kind of incident happened on the lens.
Nov 06, 2008 | Cameras
NEC VT37
you auto focus or you can manually rotate the lens for focus
Feb 22, 2008 | NEC VT37 Multimedia Projector
Dropped the lens, nothing broke but focus ring came undone
This will need technical service eventually. Try temporary solution with Sellotape or similar
May 07, 2007 | Canon EF 50mm f/1.8 II Lens
Nikon D90 Digital Camera with 18-105mm lens Logo
52 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
