Had my timing chain changed due to broken tensioner set timing marks now no spark. Car just turns over. Checked the fuel it is good pressure, but has no spark. also put in new crank position sensor. Car was running before change.
SOURCE: Engine died while driving, cranks but won't start.
not all scanners a created equal. You need to check for trouble codes...............but it must be fixec by now.
SOURCE: 2002 Interpid 2.7 L died on road now no start!
sounds like a bad ecm aka computer to me.have ecm checked
SOURCE: engine starts for half second and dies
Yes, I think it too is the theft system. Vehicle Anti Theft System...VATS. Anyhow, when you turn the key to the "run" position does the "SECURITY" lamp become illuminated in the guage panel? If so, that is normal. BUT...if it is flashing then that means the VATS security system has been activated. This happened to my friends 1996 Buick which is the same thing as your car but with a different body. Any how, here is how I fixed the problem:::::::::::::::: Find and CUT the flat ORANGE wire underneath the drivers side dashboard. Remove 3 inches of the orange sleeving from BOTH HALVES of the orange wire leads. Inside the orange you will find TWO WHITE WIRES, these are the wires that run from the micro chip in your key to the computer. I will now refer to this orange wire as having two sides...the KEY SIDE and the COMPUTER SIDE Anyways, take the two white wires that lead up to the key switch and strip an inch of protective coating off the ends of them. NEXT, Do the same with both the white wire leads that go towards the cars computer. OK, Now here's the easy part, Take the two white wires that run to the computer side and touch those COMPUTER SIDE wire leads to the actual micro-chip in your key. !!!!!!!!!!!!!!!!!! yes, get on your back and physically hold your key underneath the dash board and TOUCH BOTH COMPUTER SIDE wires to the micro chip in your key.......One wire touches the front of the micro chip and the other wire touches the back of the micro chip. Once you do this, the anti theft system will reset its self and you can reattatch the (now) four WHITE wires to eachother. Now you can start the car. If the SECURITY light in the guage panel is off then you are in good shape. If it is lit up then you have a problem with the key side of the orange wires. And it is probably right at the key cylinder on the column. NO.........a new key or cylinder will not fix it. But the car dealer can fix it for 500 bucks...It requires a whole nother column with YOUR key cylinder and YOUR key installed into it. Then that column installed into your car. So, any how if the light is on AND YOUR BATTERY EVER GOES DEAD then you will have to do the-under-dash-board-wire-touching-thing-again....
SOURCE: STARTING PROBLEM!! Have 2003 Hyundai Tiburon GT
try to get a wiring diagram it sounds like you have a rubbed thru or corroded wire in the circuit. haynes manual at autozone $20.00. Some local larger libraries have the wiring books also.
Get Ford timing tool kit, part = otc-6488 (For about $119 USD on eBay)
4 timing chains (3 front including the optional balance shaft chain + 1 back)
2 cam guides (1 front + 1 back)
2 oil tensioners (1 front + 1 back)
1 jackshaft tensioner (1 front)
1 jackshaft guide/cassette (1 front)
1 balance shaft tensioner (1 front) (will probably be ok, so dont replace it)
1 balance shaft guide (1 front) (will probably be ok, so dont replace it)
new sprockets + bolts + gaskets etc.
new spark plugs + throttle body cleaner + lithium grease spray + oil change
head gaskets
some
of these parts (the front stuff) can be obtained as a primary timing
chain rattle noise kit Part# = 2u3e-6d256-** ab for 4*4 & bb for
2*4.
The kits also have later part numbers for us$ 76 @ http://www.fordpartsonline.com
My parts order (without the balance shaft stuff) was:
$76.04 KIT-TENSIONER TIMING 2u3e-6d256-ab
$47.93 Engine, Camshaft and timing, Timing chain, TIMING CHAIN, Explorer, Mountaineer, Rear - 4.0L SOHC - 4.0L SOHC
$57.36 Engine, Camshaft and timing, Chain guide, CHAIN GUIDE, Explorer, Mountaineer, Jackshaft To Cam - 4.0L SOHC - 4.0L SOHC
$103.22 Engine, Overhaul gasket set, OVERHAUL GASKET SET, Explorer, Mountaineer, Upper (Valve Grind) - 4.0L SOHC - 4.0L SOHC
$28.93 Engine, Camshaft and timing, Tensioner, TENSIONER, Explorer, Mountaineer, Upper - 4.0L SOHC - 4.0L SOHC
Its
worth mentioning that this procedure is not enjoyable at all and
should be undertaken with at least 8 full days to completion (I recon
you could do it in half the time the second time).
It is basically on entire engine re-build with both heads off and the engine out of the vehicle.
It
is not possible to do the rear chain or sprocket with the engine in
the car as the flywheel needs to come off + at least 1 head, but it is
possible to do the front primary chain and or front cam chain with the
engine in the car.
You
will be a ford exploder and timing expert after you do this - the main
reason should be the love of your American built vehicle. Its a solid
car - except for the plastic guides!
Disclaimer
Note: This is how i successfully did the job, but i am not a ford
mechanic and don't hold me responsible if this does not work for you.
Timing Overview
A
Small Sprocket on the crank turns a larger (2 to 1 ratio) jackshaft
sprocket that is in turn connected front & back to the 2 camshafts.
Thus a 360o turn of the crank will turn both the camshafts 180o.
Firing order is 1-4 2-5 3-6, Right side numbers 1,2,3. Left Side = 4,5,6.
At TDC pistons 1 & 5 are fully raised, thus 1 is about to spark & 5 is evacuated.
The
engine will turn freely (no piston to valve contact) with the cams
180o out, it will even run (roughly) with 1 out 180o, any other
settings may cause major damage to the valves.
The
2 cam shafts come with timing markings, "yes" real timing marks that
anyone can use (even without special tools) to ensure correct timing.
The way to time it is to ensure both the off centre cam shaft slits are level/flat with the head.
With
the engine at TDC both the cams need to have the off centre slot in
the same position either up and level or down and level.
It
is super critical that both the camshafts are 100% in sink with each
other, i.e. not a few degrees off, the engine computer can compensate
for crank timing but not engineering failure.
Be
warned the camshafts can turn easily fast & hard by themselves as a
few springs are compressed at TDC, I got my finger jammed and its
still healing + if the engine is not at TDC you may damage a valve.
Now
heres the hard thing that you will need special tools for - if you
need to change the timing, you will need to be able to undo the cam
sprocket bolt on both cams & these are done up real tight.
There
is a tool that you attach that has 2 pencil thick shafts that fit into
the sprocket and prevent it from turning - then you need to put about
90Nm of force on the bolt (remember the rear one if LHT)
For
the $money$, its well worth getting yourself the tool kit - it will
save you hours in the long run. Search eBay for otc-6488 should be US
$119 - then sell them again for say $100.
There
is also a tool version of the oil tensioner in the kit that screws
right in and puts the correct amount of force on the chain + guide, to
enable you to do up the cam bolt with the chain and sprocket in the
right spot on the cam.
BTW checked for codes and none found.
Checked the wires and they all seem fine, bolt in back was tight. Still no spark.
