Question about Philips Televison & Video
Phillips model # 46PP930217 I want to use convergence settings but menue will not display. The remote seems to work but no display on screen so you cant tell what your doing
  • 4 more comments
  • corayman May 17, 2009
    HI,
    I should have mentioned the tv comes on and the convergance is not right, it's just the menu portion thats not appearing on screen
    Phillips model # 46PP930217 I want to use convergence settings but menu will not display. The remote seems to work but no display on screen so you cant tell what your doing
    I should have mentioned the TV comes on and the convergence is not right, it's just the menu portion that?s not appearing on screen
    The convergence kit was installed approx. 6 months ago and all worked fine
    I want to re converge the tv. When I press the remote button for the on screen menu to appear it dose not. the remote seems to work but no visual on screen prompts appear.
    posted by corayman on May 17, 2009
    Comment posted on May 17, 2009
    HI,
    Just to double check with you , I have lost all on screen menu visual commandes, where I have no visual volume bar the remote still raises and lowers the sound, I can toggle thru av settings but not see if I'm on av 1,2 ond so on.
    Sorry for the long delay,I had to leave my home, Thank you I will change the IC chips again
  • 3,741 Answers
For your projection TV to lose all its convergence , this means that your IC has become faulty which in turn has made your convergence amplifier to malfunction. i know you have replaced the convergence kit just six months before.but the same problem is faced by many convergence kit users ,as they say the IC which comes in the kit go weak or short very early.and if the ic is faulty it will not show convergence settings when menu is pressed. ------------------ You will have to replace STK392-110s you might have 150s if not 110s upgrade it with the latest  STK392-180s.all .110s,150s and 180s are compitable.
you can get it at  www.radioshack.com and cost of each ic is near to $10 and you will have to replace two such ic.as your convergence board will have two such ic.its a common problem and this will be solved after replacing ic. thanks. please do rate the solution.thanks.keep updated.
Posted on May 17, 2009
  • charlymonty May 17, 2009
    very correct.this is the problem of convergence ic.as this board is not functioning properly due to faulty ic.replacement of ic is necessary.get it replaced to resolve the issue easily.
  • 355 Answers
If you have checked for a bad horizontal output transistor and it is ok a faulty focus block will do you in or the worst case and this may just what it is is the blue crt shorting out and causeing shutdown. I have seen that a few times
  • 2 more comments
  • Rohit  Asthana
    Rohit Asthana May 17, 2009
    our TV most likely has one of two possible problems.
    Problem #1: Convergence Chip Failure ( common problem )
    Here are some of the most common symptoms and example photos of a convergence problem
    • Screen looks 3D
    • Colors don't line up
    • One or more colors can't be adjusted when using the convergence menu.
    • Screen is bowed or warped.
    Using your original remote go-to the tv settings then goto the convergence section.
    Try to adjust the red and then the blue convergence.
    You should be able to move them up, down, left, and right.
    If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
  • Rohit  Asthana
    You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com.
    They have put together a kits for most models. If you don't see a kit
    for your set send them a quick note and they will put one together for
    you. Their kits include a photo instruction guide, original OEM Sanyo
    STK chips, convergence resistors, pico fuses, etc.
  • Rohit  Asthana
    is there issue in convergence problem??????
    there is a convergence repair kit for ypour model which has both
    convergence ICs and all 12 Feed resistors at the following link. They
    also include step by step instructions with pictures of how to do the
    repair. Heres the kit for your model.
    http://servicemanuals.vstore.ca/product_...
  • Rohit  Asthana
    hello can you tell me your problem in deep?
NO PICTURE!!!! Please HELP! I am going to kill my husband for bringing this TV home!
If the model number is correct and all you can get is the menu or on screen displays to work the set may need to be reset--not on the front or in the menu.
The set has 3 hidden menus: adjustment (keep out), tech convergence, and the OPTION menu.
Option menu enables a hard reset to factory of all settings except convergence and is designed to fix odd issues.
You need the Mitsubishi remote and a 4 digit code (model specific).
If you have the remote and want to try it let me know what the actual model number is and I will give you a link to the service manual which tells how to do it correctly.
SD TECH
May 30, 2012 | Mitsubishi WS-55857 55" Rear Projection...
I have a 2001 sony 53' rear projection tv model #KP-53HS30. It seems has a wavy section on the upper left hand corner and lower right hand corner of the screen. All the bulbs are working fine but seems...
Try this. The follow was found on tv-forums dot com by Zyntar...
There is a secret service menu to converge the Sony KP53HS30.
Caution: Be careful, there are many settings that can be tampered with. Some may be hard to undo.
Procedure: (use the remote control for these steps unless noted)
1. Turn TV off with System Off (under flap on remote)
2. Press: Display, 5, Volume +, then Power. If successful, service text will appear on the screen.
3. Use 2 & 5 to select the PJE Category.
4. Press 9 to get to fine convergence adjusting.
5. Press 6 several times to get the convergence screen of choice. I like the grid.
6. Use the remote's arrow keys (joystick), move the brackets around until you have found the area to adjust. Press the center of the joystick to change the bracket from white to a color. Use the joystick to adjust the color. Press 3 to change color to adjust. When done, press center of joystick again.
Note: Try to keep the grid even and squared up.
7. Repeat steps 5 and/or 6 for all parts of the screen that need it.
8. Once done, you need to save your settings. Press: Mute, Enter. Then on the TV, press "Flash Focus"
9. Turn off power.
TV is ready to use.
Oct 20, 2010 | Sony KP-53HS30 53" Rear Projection...
Toshiba big screen Model TZ50V60 Convergence Issue-Chips Replaced
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 29, 2010 | Toshiba TZ50V61 50" Rear Projection...
No audio ,double image bow with redish color at bottom of screen ,on my phillips big screen tv model # 55p8342
Your TV most likely a convergence failure. ( common problem )
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 18, 2009 | Televison & Video
How do you get to the convergance menu on phillips 60pp9363h/17 tv
Here are two tips from www.TvRepairKits.com
"You must have the original remote. If so you can access the convergence screen by hitting the menu key"
Jun 04, 2009 | Philips 46PP9302 46" Rear Projection...
Where can i buy remote control for phillips 55pp9401?
get a full universal at your local walmart for less then 20 with full menu and program functions, get a phillips brand and no programming required.
Mar 16, 2008 | Philips 55PP9401 55" Rear Projection...
Convergence adjustment @ 52MH84
press mute on the remote then while pressing mute press menu on the set.then you navigate with the instructions below.
3. KEY FUNCTION IN THE SERVICE MODE
The following key entry during display of adjustment menu provides special functions.
Screen adjustment mode ON/OFF: TV (ANT)/VIDEO button (on TV)
Selection of the adjustment items : Channel s/t (on TV or Remote)
Change of the data value : Volume s/t (on TV or Remote)
Adjustment menu mode ON/OFF : MENU button (on TV)
Initialization of the memory (QA02) : RECALL+Channel button on TV (s)
Initialization of the self diagnostic data: RECALL+Channel button on TV (t)
“RCUT” selection : 1 button
“GCUT” selection : 2 button
“BCUT” selection : 3 button
“SCNT” selection : 4 button
“SCOL” selection : 5 button
“TNTC” selection : 6 button
Convergence adj : 7 button
Self diagnostic display : 9 button
Jan 21, 2008 | Televison & Video
PT5499HD Covergence Akai
Yes, you have a size problem you have horizontal and vertical size. Either its' in the service mode or somewhere on the set, with this set it's probably in menu. Must be set too high. I will look for menu codes! Is this an Akai or Panasonic set?
Oct 04, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Televison & Video Logo
97 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
