Question about HP Photosmart C5580 All-In-One InkJet Printer
On the display of the printer there is a message B3FFFB46. What does this mean. The printer will not power down compeltely. It comes back on with this error message.
On the display of the printer there is a message B3FFFB46. What does this mean? It will not completely power down when I turn it off. It comes back on immediately when I pusch the power button witht he above message.
  • 28 Answers
Unplug power cord wait for 1 minute before plugging it back in...
Posted on May 20, 2009
Error 030 fatal error
ecblank.gif What does "Fatal Error" mean? ecblank.gif ecblank.gif ecblank.gif ecblank.gif
ecblank.gif ecblank.gif Summary: Printer has displayed a "Fatal Error" message. This simply means a problem has occurred requiring you to take action. It does NOT mean that your printer has "died". ecblank.gif ecblank.gif ecblank.gif ecblank.gif
ecblank.gif ecblank.gif Your printer display or status monitor may read "Fatal Error". This simply means a problem has occurred requiring action to clear.
A "Fatal Error" does not mean your printer will "die". Fatal Error explanations are not usually found in the User's Guide or Handy Reference Guide.
RECOMMENDED NEXT STEP: First, try turning off your printer then turning it back on. If this does not clear the message or remedy the problem, check to see if your printer is on a power strip (or not plugged directly into the wall). For testing purposes, be sure the printer is plugged directly into the wall. Often, the issue is power-related.
Second, if the issue persists after this, write down the message (including the 3-digit error code number) and email us at "support@okidata.com" or call Oki Data Customer Support (1-800-654-3282) for assistance.
NOTE: If you see a series of letters and numbers(scrolling across the display) after the 3-digit error code, be sure to write these down also and report them when call or emailing Customer Support.
May 25, 2011 | OKI C5200n Laser Printer
I have a printer Lexmark W840. On the display there is a message "84 Replace PC unit" - what does mean?
The PC cartridge needs to be replaced. If you have just installed a new unit, please check if the PC cartridge is installed securely.
For further assistance please contact Lexmark Technical Support.
Feb 16, 2011 | Lexmark W840 Laser Printer
Fatal error 708
Dec 14, 2010 | OKI C3530N Color MFP Printer
When i hit "print" the
Does the red light blink or stay on sterady?
Issue: The Compact Photo printer power button is blinking red.
Solution: Turn the Compact Photo printer off, then back on again.
"Paper Jam" appears on the digital camera LCD Turn the printer off and disconnect the power cord from the printer. Then reconnect the power cord and power on the printer. If the printer fails to eject the paper, the printer may require service. Contact the Canon Customer Support help desk for assistance.
When you power down I would recommend also unplugging the printer from the power supply (wall outlet). Let it rest 5 - 10 minutes and then plug back in.
The manual says a blinking red power light indicates a problem in the printer, but the only solution provided it to turn off and on.
If there are no paper jams, and no other error messages hoepfully a completr power down will clear the error.
Issue: Printer's power button lights red without the camera's LCD monitor displaying any error message.
There is a malfunction in the printer.
Remove the paper from the paper-handling slot and take up any slack in the ink sheet. Turn the printe's power off and turn it on again.
If none of this helps I would check to see if my driver is current:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/selphy_compact_photo_series/selphy_cp510#DriversAndSoftware
Trust this is helpful. Please vote. :)
Dec 11, 2010 | Canon Selphy CP510 Thermal Photo Printer
The ink system not working
here. try to reset your printer. this will clear annoying error displayed on your printer
1. Remove all cables
2. Unplug the printer power.
3. Press and Hold down # and 6 on the keyboard.
4. Plug the power cord back in.
5. Then release the buttons....after successful boot operation, try to print.
If that did not work.. you can also try this.
1. Press/Hold down the HELP and OK button..then unplug printer..release the button
2 Press/Hold down the HELP and OK button again..then plug the printer back in. Just Press and hold down the button while you wait for the printer to turn on (it could take a minute)
3 Now release the buttons and power it back on.
4 Error message will be displayed “improper shut down”
5 Press OK to reset the printer
6. Press both HELP and OK button again to start the resetting procedure of the printer.
Now try printing again...
If you find this very helpful..please rate this solution and vote on this on the YES below....thanks..
Jun 02, 2010 | HP Photosmart C6180 All-In-One InkJet...
925 fatal error
www.okidata.com/canada_en/downloads/C9600_Bertl_4Stars.pdf
all in manual above. http://www.okic3200n.co.uk/index.asp?printername=C3200n&menumode=0&content=errorcodes
error codes above.
May 08, 2010 | OKI C9600hdn Laser Printer
Power reset message
unplug it from the computer and unplug it from the wall socket and hold the power button down for 60 seconds then replug it back in to the computer and plug the power back on then turn it on.
Nov 20, 2009 | HP Officejet 5610 All-In-One InkJet...
T8008 printer with message says "replace fuser"
The 'Replace Fuser' message on the 8008 can be cleared in the following way;
• Power the printer Off
• Hold down FORM FEED and ENTER and power the printer on
Keep the FORM FEED and ENTER keys held down until the printer displays SERVICE MENU - INFORMATION
• Press the RIGHT ARROW to MAINTENANCE, and press ENTER
• The Display should read MAINTENANCE - CLEAR FUSER, if it does not press the right arrow until it does and then press MENU/ENTER
• The Display Should now Read CLEAR FUSER NOT EXECUTE, Press the right arrow until the display reads CLEAR FUSER EXECUTE
• Press ENTER, and after a pause the display should read COMPLETED CLEAR FUSER
• Power the printer off and after about 10-15 seconds power the printer back on again.
The message should now be cleared
Jan 12, 2009 | TallyGenicom 8008 Laser Printer
Printer busy message
See if this works:
Turn computer off
  1. Power off the printer.
  2. Close all printer covers and doors.
  3. Hold down the uparrow.jpg and downarrow.jpg (up arrow and down arrow) buttons on the printer and power the printer on.
  4. Release your fingers from the buttons when the message Diagnosing... appears.
  5. When Customer Mode and ESS Diag display, press the downarrow.jpg (down arrow) button until Test Print appears, and then press the select (center) button.
  6. Press the downarrow.jpg (down arrow) button until ContaminationChk appears, and then press the select (center) button twice.
  7. After the LCD displays Busy and the printer prints the ContaminationChk pages, power off the printer and power it back on.
Jan 20, 2008 | Dell 924 All-in-One InkJet Printer
Lcd display unit on the R 300 epson printer not working
Unfortunately, once the LCD panel is gone - it's gone. This means service or replacement.
Aug 07, 2007 | Epson Stylus Photo R300 InkJet Printer
HP Photosmart C5580 All-In-One InkJet Printer Logo
255 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
