I loose channels when it rains ,tuning problem i think , can you please help ?
Iloose lots of TV channels in wet weather,i think i have a tuning problem My TV is Samsong model No WS32Z419D. Could anyone Please Help ?
techman
  • 3130 Answers
SOURCE: can not get tv to go to aux mode to hook up a playstation2
Do you have the original remote control?. Without it you will not be able to switch to video or to the TV mode. If you do have the Original remote hand unit, look for a button call input or video. A universal will not work so please do not waist your hard earnd cash. Good Luck
Posted on Mar 22, 2007
techman
  • 3130 Answers
SOURCE: Lost the Manual & can't tune digital channels, option not available on menu ?
Here is a link where you can down load a free copy of your customer user manual. Good Luck
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KV32FS120&LOC=3
Posted on Feb 03, 2008
SOURCE: no signal
Hopefully, anyway.
I had a similar problem, and my solution was this: I pressed menu on my TV and using my universal remote, went into setup, and then channel search (or near to that), at which point it began searching for analog and digital channels. This can take up to approx. 30 minutes. I suggest you occupy yourself while waiting; it is a sluggish process.
If you want assurance, your TV will have the majority of analog channels (basic cable), and a couple digital. I am basing this wholly on my experience, however. Once finished, it should switch immediately so a channel. Mine was a weather station.
I hope this is successful in helping you and those in the future.
Posted on Jul 15, 2009
SOURCE: Options to auto-tune or manual re-tune are greyed
Problem solved!!
According to the Sony website I needed to get a software download in order to fix this problem. I found out how to do this from the manual and realised that the re-tune menu I was looking at was for analogue only. The pictograms onmy remote control are a blurred but the manual helpfully provided a picture showing the correct program "info" button (next to 0) which has options to look at other things, including a "detailed set up" menu on the blue tab, which provides options for software download and re-tune of digital channels.
Incidentally, I discovered that my TV model was not quite as quoted above - it is KD-28DX200U, but expect the same process works for other oldish models.
Posted on Oct 03, 2009
SOURCE: Lock code for Onida Black Dlx channel tunner menu
My Tv is locked and cannot start. it asks for password.
how to open it?
Posted on Mar 13, 2010
POWER ON LIGHT--OFF, TV SHOWS A NO SIGNAL WINDOW, POWER SUPPLY CONVERTER HAVING 5.3VOLTS AT THE EXIT
Hi Wiison,
Rain at all channels. I hope you must already have gone through the channel search process. Despite that if you do not get TV programmes, there is some problem with the tuner section. Either it is not getting proper operating voltage or the tuning voltage. May be the tuner itself has gone bad. For the tuner to select and receive channels there are certain requirements which must be fulfilled. Please check that area properly.
Good Luck.
Jul 26, 2015 | Televison & Video
Loosing power
ever give it a full 60,000 mile tune up?
Feb 23, 2014 | 1999 Honda Odyssey
Tuning to Indianapolis Weather Channel
Here is the link to the streaming radio. You can find the frequency too.
Weather Radio Streaming Audio Indianapolis Indiana
Jan 04, 2014 | Coby CX-18 AM/FM/Weather/TV Radio
Unable to tune into any channels
It's much more likely to be the antenna. How old is the TV? Check whether the antenna connection is loose. Check whether the antenna cabling is all connected. Did anything change just before the TV stopped working, like someone doing work outside? If you're receiving cable TV check the connections to and from the cable box.
Nov 16, 2013 | GPS
My ford f 250 drivers side window goes down half way then struggles to go the rest of the way. It goes down fast all the way after it rains. It goes up fast all the time. Thanks. .
Yes, well, perhaps someday car makers will address this problem. Don't hold your breath. This problem has been around that I know of for 60 years!
Problem is likely the rubber/plastic channel that the glass rides in, and the looseness of worn parts that are part of the window movement inside the door.
If you live where the weather is warm (not freezing) you could use silicone spray or silicone grease. The grease if often expensive.
You might find yourself re-doing the silicone application every month or two weeks, depending on your rain or other weather which would "erase " your efforts.
Freezing weather? I don't know what lubricant will not freeze in the channel.
It is possible to change the rubber window channel, but my observation is it is an awful job. I've done it once, decided "never again".
Other than a Ford dealer, I think the channel replacements are available from J.C. Whitney mail-order out of Chicago.
I am not making a recommendation here.
Jan 12, 2013 | 2001 Ford F250 Super Duty Super Cab
We have samsung tv when weather is windy or raining the picture goes all choppy then reads no signal bbc is the only one not affected
hi,
First of check the antenna connection behind the tv also on dipole. If the connections is ok then try to auto tune using the Auto serch in the menu.
ok
Aug 26, 2011 | Televison & Video
I have a 2000 yukon that when we have rain or wet weather fails
its humidity that penetrates the iginition coil.check your wires,coil pack and spark plugs.have you changed them recently.it might be time for a tune up.
Oct 04, 2009 | 2000 GMC Denali
Bad satellite tv reception in the rain-is that normal?Good weather-good reception.
It's happened to me too, it could be a loose screw thats meant to hold the dish steady, it could also be more serious and could require a new feedhorn or another part. Leave it be for a few weeks and if it gets worse call sky, if thats your provider, or price around for a local technician.
Jul 15, 2009 | Televison & Video
Why do the stations keep blinking in and out all day and all night? is this how it's going to be even after 6-12-09? it really gets on my nerves when i'm watching tv and miss over half of whats going on or...
The channels are going off because the signal is not stavying strong enough to keep a regular picture. If you are having this with several channels, there are several things you can check. First, make sure all the antenna wires are not loose. Then find the signal strength option in your converter box (each is different thus you need to check the manual on how to use) to see how strong your signal is. If all channels are low, you most likely need a outdoor antenna. These can be bought at any home improvement store. There is no such thing as a digital antenna. The signal for the channels are still being sent over the same tv spectrum (most will be over UHF) thus walk away from any electronic store that is selling a special digital antenna, there is no such thing. I am using a outdoor antenna, and the picture I receive is just as good as cable. It is some effort to hook it up correctly but the improved picture is well worth the effort. Very heavy rain, wind and clouds at your home and near were the tv broadcast antenna is will also effect your picture. These problems go away as the weather gets better. Directv also has the same problems with weather.
Jun 05, 2009 | Insignia Digital-to-Analog Converter for...
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
