Question about Life Science Life Source Blood Pressure Monitor Ua-767
Pressure builds to about 220 then cuff pressure drops off
And something flashes in the bottom left corner of the screen. I push the button and the flasher disappears; I push it, again, and the cuff pressurizer starts again; when it gets to 220 or so, the pressurizer stops and the cycle repeats.
  • Patrick West
    Patrick West May 17, 2009
    I checked all 4 batteries and each tested "good" with the tester needle well into the green.
  • 5,568 Answers
These cuff-type BP meters are very unreliable; I have bought 4 (one standard type) so far and the one that is still working predictably measures about 10% low. I took it to my GP on an office visit and we compared the systolic & diastolic results and although three different methods/instruments (manual, upper arm portable digital and a stand mounted 'professional') also tracked poorly, mine (Samsung) measured lower than all other methods.
I suspect the sensor that should be doing the measuring is faulty.
Posted on May 17, 2009
How do I fix a homedics BPA-201 Digital Blood Pressure Monitor. Or who do I send it to be fixed. It keeps displaying E1. But I checked all cuffs connections and they are fine.
Are you moving your arm at all after you press the start button. I just have a wrist cuff, but if I move anything after I've pushed the start button I get an error code.
Apr 02, 2015 | Homedics Health & Beauty
What`s the red yellow green lines left on the screen
Looks like it's the cuff inflation meter. Go here for more info -https://www.andonline.com/uploads/documents/I-UA-767PV_0409.pdf
This is the manual for the UA-767 plus
Sep 28, 2014 | Lifesource UA 767 Plus Digital Blood...
WHAT IS THE P IN A CIRCLE FOR IN THE WRIST BP CUFF
What does the circle with a P in it mean on walgren creen of cuff bold pressure monititor?
Jul 30, 2012 | Walgreens By HoMedics Automatic Wrist...
991 error code on a Takagi T-K3 Flash gas tankless water heater
Re- set code!!!!
We have a Takagi TH3 DV 540 model.Air intake got blocked with snow, condensation etc.Once we cleared that then you just have to re-set it to clear the 991. On our model there are 4 tiny buttons across the bottom (Take off front cover) to find them. of the computer board assembly bottom left corner. Push the two buttons on the right simultaneously hold for 15-20 seconds or so, then turn the Takagi off then on again- should work now!
If you have a different model then those buttons will be in the bottom left corner still but running vertically- try doing as above with the bottom two buttons. We had to go without heat and hot water for 2 days until we could get hold of someone to tell us this. We called Seneca Supply 716-852-4744. Good luck
Apr 22, 2012 | RTO Takagi T-K3 Flash Gas Tankless Water...
How do I set the time on a philippe starck ph1110? There aren't any buttons to push...
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker
Dec 30, 2011 | Watches
How do i program a black & decker model cm1050w to start coffee breding at a certain time?
I have one. It's easy. Push the program button. The little green light in the lower left corner will flash. The only tricky part is that you only have about 3 seconds to begin setting your time. After that the light stops flashing and you will be changing the regular time. While you are pushing the Hour or Minute buttons you have all the time you need to set your brew time, but once you stop you're back to the 3 second timer. Remember, if the light in the upper left side is on, the time is PM. To turn the timer on, push the Auto button and the little light in the lower left will come on and stay on. To turn it off, just push the Auto button again. Another caution, there is no "safety" for the Hour and Minute buttons. If you push either of those buttons while the lower left light is flashing you are changing the brew start time. If it is not flashing you are changing the real time. In other words, if you push either of those buttons at any time, you are always changing something. Happy brewing.
Sep 12, 2011 | Health & Beauty
How do you set the time and date on a Welby Wrist Blood Pressure Cuff
I was able to do this by 1st pushing and holding the M button and then pushing and holding the on button and holding both for 3-4 sec. Once released you will see the month flashing. change by pushing the M key to desired month then toggle to day etc with the on button
Mar 21, 2010 | Health & Beauty
Toshiba Satellite A215-S7437 will not boot up...
Take out the hard drive completely and then see if you hear the clicking noise, if you do then that means the hard drive is bad. Also if it goes right to another message and you don't see the blinking cursor then that also verifies that the hard drive was bad and causing the system to hang.
Jun 12, 2009 | Toshiba Satellite A215-S4747 Notebook
Sphygmomanometer
most likely when you dropped it on the concrete floor the compact of it hitting the floor has either jarred something on the inside of it and has caused it to not work properly or find the papers to the machine and restart the directions for it. i hope that something i have said may work, good luck!
Jan 07, 2009 | Medline Industries Medline Manual Digital...
Machine will not work and flashes 12 minutes
remove bottom cover look for tech sheet usually on right side of cabinet at bottom fh is usually a water fill issue drain may be siphoning water may be slow filling or bad flow meter flow meter may be harder to diagnois but try tapping lightly with screwdriver (it's the round object left side with 2 small hoses attached ) slim chance may be pressure switch left side rear corner
Nov 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Life Science Life Source Blood Pressure Monitor Ua-767 Logo
234 people viewed this question
Top Life Science Health & Beauty Experts
Tom Chichester
schwaa44
schwaa44
Are you a Life Science Health and Beauty Expert? Answer questions, earn points and help others
