Question about Gateway Wireless-B Router (wbr-100)
How to install my xbox 360 to my gateway router
    Problem Solver:
  • 9 Answers
You dont have to install it just connect to it and make sure that your router enables UPnP
Posted on May 18, 2009
I cant set up xbox live
Connect to the Internet The first step is to connect your Xbox 360 console to your Internet connection. Here's how:
  1. Plug one end of a network cable into a port on your router or gateway. You might need a long network cable, depending upon on the location of your router or modem.
    Note If you do not have a router, you can plug the network cable directly into your modem.
  2. Plug the other end of the network cable into the back of your console.
Verify your setup Your setup should look similar to one of the following:
Router connection
connect_router_300px.gif Your Xbox 360 console and computer are both connected to a router. The router is connected to a modem, which is connected to a cable wall jack.
Modem connection
modemsetup_300px.gif Your Xbox 360 console is connected to a modem, which is connected to a cable wall jack.
Jul 27, 2011 | Microsoft Xbox 360 Console
Tip
Xbox Live - MTU Error
Xbox 360 MTU errors
This issue occurs if your router or the gateway is incompatible with Xbox Live, or if your router or the gateway has an incorrect MTU setting. Note: Xbox Live requires a minimum MTU setting of 1364. We recommend that you try out the steps shown below.
Things to try:
1. Ensure that you have properly setup your connection to Live by using the Connectivity Wizard http://www.xbox.com/en-US/support/connecttolive/xbox360/connectionmethods/webconnectivitywizard.htm
2. Visit the following Web site to determine whether you have the correct firmware version that has been certified as compatible: http://www.xbox.com/en-US/live/connect/routerlanding.htm
3. See the router or gateway instruction manual for information about how to change the MTU setting to 1364, to do this, or to determine whether your router supports this feature, see the router support documentation or contact support for your router device.
4. If you share a connection with a router and a modem, try a direct connection without the router.
For additional information on this topic refer to the following KB article: http://support.microsoft.com/kb/908882/
on Sep 30, 2008 | Microsoft Xbox 360 Console
My x box 360 keeps freezing ans saying you are disconnected from xbox live, what do i do ?
If your screen freezes when playing on Xbox LIVE, the problem may be related to your Internet connection. A weak wireless signal can cause poor Xbox LIVE performance. If you are using wireless connection:
1. Go to My Xbox and select System Setttings. 2. Select Network Settings. 3. Select Wired Connection or the name of your wireless network. 4. Select Test Xbox LIVE Connection.
If your wireless signal is only one or two bars, try improving your signal strength by following the suggestions below.
  • Move your router or gateway off the floor and away from walls and metal objects such as metal file cabinets).
  • Minimize obstructions along a straight-line path between your Xbox and your wireless router or gateway.
  • Shorten the distance between your console and your wireless router or gateway. Ideally, your network hardware should be near the center of your home.
  • Change the position of the antenna on your Xbox 360 Wireless Networking Adapter (external adapter only).
  • Turn off wireless devices. If your router uses the 2.4 GHz band, try turning off wireless devices, such as 2.4 GHz cordless telephones and Bluetooth devices.
  • Try changing your wireless channel. Wireless routers and gateways can broadcast on different channels and one channel might be clearer than another. See your hardware documentation for help changing wireless channels.
  • Add a wireless repeater to extend your wireless network range. You can boost your signal strength by placing a wireless repeater halfway between your router or gateway and your console.
  • Add an Xbox 360 Wireless N Networking Adapter.
  • Switch wireless signal bands. If you have a dual-band router and an external wireless adapter, try switching the router to a wireless protocol that transmits on the 5 GHz band (wireless protocol A or N). Please see your hardware documentation for help with changing the wireless protocol.
  • Switch to a cable.
Apr 05, 2011 | Video Game Consoles & Games
Wont let xbox live update i checked connection and it was fine
If your Xbox 360 console is connected to the Internet through a router or gateway (as opposed to through a direct modem connection), try connecting the console directly to the modem. Here's how:
  1. Plug one end of a network cable into the back of your Xbox 360 console and the other end into your modem.
  2. On the console, sign in to Xbox LIVE and start the game.
  3. Choose to download the game update.
If you can download game updates when the Xbox 360 console is connected directly to the modem, there might be a problem with your router or gateway configuration.
Cheers!!
Nov 01, 2010 | Microsoft Xbox 360 Console
How far away can my wireless G router be from my xbox adapter
It is about 50-75 feet depending on how many obstructions are in the way (Walls, Ceilings, etc)
Oct 23, 2009 | Microsoft Wireless Network Adapter Xbox...
How do u setup the Xbox live gateway,we can find everythhing except that.Can you help me?
The gateway is the router you are connecting the xbox 360 to... you may need to configure the router... If it says you have a restricted connection on xbox live you will need to. Otherwise everything should be working fine. Here are the settings you will need for the router if applicable:
http://support.microsoft.com/kb/908874
Oct 07, 2009 | Microsoft Xbox 360 Console
Xbox 360 ics apipa
you need to set static ip's for the xbox 360 and the lan that is on the pc, easy to bride the two connections on your computer, then set static on the lan that the 360 is plugged in to, example:
360's static settings:
ip: 192.168.1.14 sub: 255.255.255.0 gateway 192.168.1.1 ------------------------------- computers settings:
ip 192.168.1.15 sub 255.255.255.0 gateway 192.168.1.1
Feb 05, 2009 | Microsoft Xbox 360 Console
Connecting xbox 360 to laptop for xbox live.
This site has all the info you need to connect your xbox 360 to a laptop and then wirelessly to live :) :
[url=http://howtoconnectwirelesslytoxboxlive.blogspot.com/]How to connect to xbox live wirelessly[/url]
Oct 26, 2008 | Microsoft Xbox 360 Console
Xbox live
Those shouldnt be the problem. Your router is more than likely the problem and will need to be fixed
Feb 20, 2008 | Microsoft Xbox 360 Console
MTU con connecting. How to fix ?
What does MTU do on Xbox Live?
The MTU of your router or gateway must be greater than or equal to 1365. If it is less than 1365, you won’t be able to connect to Xbox Live.
To change the MTu login to your admin router panel:
  1. Go to start>Run>cmd>type ipconfig
  2. look for "default gateway" then type that address into your router login, usally the login is admin/admin if not look in your manual or call your router maker.
  3. Now login locate the area to adjust the MTU if you cant find it, contact the router maker, or look in your manual.
More info:
http://www.xbox.com/en-US/support/connecttolive/xbox/connectionmethods/diagnosingconnections.htm
Cam
Oct 21, 2007 | Microsoft Xbox 360 Console
Gateway Wireless-B Router (wbr-100) Logo
90 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
