Question about Delta Faucet Delta T2710-LHP Classic Roman Tub/Whirlpool Faucet, Chrome
Can I replace delta faucet t2710 with Delta SBS 84010BN ?
Can I replace delta faucet t2710 with Delta SBS 84010 with changing the plumbing?
  • 68 Answers
Yes . when buying the faucet dont forget to buy stainless steel suply lines for water line connection.
Posted on Jul 04, 2009
Fix leaky delta 794
Replace the Delta cartridge inside the faucet.
Jan 13, 2013 | Delta 794-RB-DST Linden Single Handle...
My Delta 174--WF has a constant drip from the faucet. I'm not sure how to take it apart to fix it, or what parts to replace. Can you help?
Turn off water supply and use allen wrench to remove handle then remove bonnet nut then remove internal parts replacement kits available at most lowe's and other home improvement or hardware store or plumbing supply stores take care to document how everything is removed so you can reinstall exactly how it came out.
Jun 06, 2011 | Delta Faucet Delta 174-WF Waterfall Single...
Ok i have a delta faucet with the cartridge one valve works and one doesnt is there any way to avoid getting a new faucet mine is barely a year old
You should check with delta I know where i but my plumbing supplies a lot of the delta brands have lifetime replacement parts on them so ask your lumberyard where you purchased it Delta may send you replacement parts for free. Good luck.
Jan 04, 2011 | Delta Faucet Home
Delta Faucet Company 467-SSSD-DST Palo Diamond Seal Technology Pull-out Kitchen Faucet, Stainless, 3 years old and is beginning to drip unless we position the handle just right. Is there a washer? I've...
It sounds like the cartridge is going or is possibly loose, If you take the handle off you can try to GENTLY tighten the cartridge and see if that fixes the leak. You don't have to tighten it a lot to see if it will stop; if you over tighten you can cause the housing to split and you don't want to strip the cartridge head because you may have to remove it. Use a proper set of channel locks and apply some gentle pressure if it turns and the leak stops, great! if it doesn't then the cartridge has failed and needs replacing. Your Delta faucet is covered by a limited lifetime warranty so the part should be free. Here is the warranty and the contact information to order one.
https://www.faucetdirect.com/index.cfm?page=product:warrantyPopup&uniqueId=2417692
If you are not comfortable dealing with plumbing issues I would highly recommend calling a licenced plumber. The part is free so its simply the plumbers time.
Good luck.
Oct 18, 2017 | Delta Faucet Delta 467-SSSD-DST Palo...
I have a T2710 and I have a piece that has gotten broke. it is the piece that the handles screw onto and the copper line runs out of the underside of it. The copper line broke when we took it off. it is...
It sounds like you are referring to the valve assembly. It sounds like the line broke where it is soldered into the base of the valve assembly. You may be able to solder the line back on using a union, but if not. it may be easier and cheaper in the long run to just replace it.
Sep 08, 2010 | Delta Faucet Delta T2710-LHP Classic Roman...
My delta two handle bathroom faucet the cold water handle is hard to operate tried wd40 on it and it worked for a while but it got hard to operate again
They have a lithium faucet grease for stems at hardware stores Home depot or Lowes. It a gease to help free up for movement of handle if they don't have it try a Plumbing supply house they should sell to public.
May 04, 2010 | Delta Faucet DELTA/PEERLESS FAUCET CO....
The roman tub faucet keeps dripping. I push down on the stems and it stops?
the retaining nut,located under handle may not be screwed down all the way.this happened to me on similar / same faucet's.so try this and see,nice and easy
Dec 30, 2009 | Delta Faucet Delta T2710-LHP Classic Roman...
I have a two-handle Delta faucet that drips.  With both handles turned completely to off, the faucet drips at a about 1 drip every 15 seconds
sounds like you need to replace the valve seats. if you shut the water off and remove the handles you will see the valves. you have to remove them and under that you should see these little black things. they come out but have springs under them so be careful. the black things are the valve seats. i would start by replacing them
Dec 15, 2009 | Delta Faucet DELTA/PEERLESS FAUCET CO....
Need Delta kitchen faucet repair kit # for model # 172-WHWF
you can generally purchase this kit at any plumbing supply store, or a home depot, or on line http://www.repairclinic.com/
Aug 19, 2009 | Delta Faucet Delta 172-WHWF Waterfall...
Delta Faucet Delta T2710-LHP Classic Roman Tub/Whirlpool Faucet, Chrome Logo
637 people viewed this question
Top Delta Faucet Home Experts
john h
bobalix
 John
John
Are you a Delta Faucet Home Expert? Answer questions, earn points and help others
