Question about Garden
Metal meshing sound when attempting to start, Simplicity Lawn Tractor with a Kohler Engine. Believe it may be the starter motor. Oil level in engine is good, and clean. Any suggestions ,please.
  • COUGHY_MAN May 11, 2010
    Is it like a squealing sound??
  • 61 Answers
Stater gear is bad ck?
Posted on Sep 06, 2009
When I try to start my 60" Ariens rider all I get is a loud clattering sound. I just replaced the battery 2 months ago. What's wrong with my mower?
Joel, Recheck battery to make sure it has good charge >12 v and all battery and starter wiring,plugs,connections are clean,tight and undamaged. If you remove spark plug and engine spins freely from the key, the engine compression release or valve clearance needs adjusted. It is probable the solenoid or starter is faulty, the starter Bendix/drive may be sticking. If you can, give the starter a couple sharp raps with a hammer or bar and then try to start.
Check the attached links,instruction and guides to help diagnose starting issue. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://troybilt.custhelp.com/app/answers/detail/a_id/86/~/clicking-sound-while-attempting-to-key-start---riding-mower
What Are the Symptoms of Bad Starter Motor on Riding Mower Engine
My Bolens lawn tractor won start It just clicks when turn the key even...
Craftsman riding mower won start Just clicks the starter motor
Aug 27, 2016 | Ariens MaxZoom60 60" 25HP Kohler Zero Turn...
Solenoid clicks but starter does not kick in to start tractor
Clicking Sound While Attempting to Key Start - Riding Mower
troybilt.custhelp.com/.../clicking-sound-while-attempting-to-key-start---r...
Jul 19, 2002 - Why does the tractor make a clicking sound and not start? ... Thesolenoid connects the battery to the starter motor when the solenoid is energized. ...It can click, but not make a complete connection. ... Starting - Riding Mower · Professional Shop Manuals · Basic Troubleshooting - Lawn & Garden Tractors.
How Do I Tell If the Starter Solenoid Is Bad on My Kohler ...
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
Most large Kohler engines on riding lawn mowers use an electric starting system. ... A bad solenoid can deny electricity to the starter motor and prevent engine startup. ...Lawn Mower Will Fire but Not Start · Replacing a Solenoid on a Craftsman Lawn Mower or Tractor · How Does a Starter Solenoid on a Lawn Mower Work?
My Bolens lawn tractor won't start. It just clicks when I turn ...
Dec 03, 2015 | Garden
Replcement oil filter husqvarna model ltg2654
their are a few different filters for your rider --these are for the kohler 26 hp motor stores like home depot- lowes- sears- or small engine repair shops carry filters K&N PS-1002 http://www.sears.com/ayp-genuine-ayp-part-578416804-oil-filter-kohler-cou/p-SPM8242278631?redirectType=SKIP_LEVEL http://www.knfilters.com/oil_filter/all/kohler/sv735/26hp
Jul 10, 2014 | Husqvarna Lawn Tractor - 54in. Deck, 26...
I have a b&s model 330000 engine which seems to leak a small amount of oil on the left side of the engine ans accumulates on the frame rail of the lawn tractor before dropping to the ground. i rec
My guess, without seeing the engine would be a seal or gasket is bad. Use Gunk brand degreaser to clean the engine. Start it up after that with the engine cover off and watch for leaks.
Jun 23, 2014 | Simplicity Regent 22 44 Riding Lawn Mower...
Craftsman push mower won't start
OOOh I don't recomend turning any 4 cycle engine upside down for any reason , i'll bet the starter won't even turn it over now, 1st your gonna need to replace engine oil to proper level , second your gonna need to locate valve (locker) this canbe ident by a small tube comming from it to carb , remove this cover and clean/drain oil from here and last remove spark plug tilt engine that direction and remove as much oil as you can attempt to turn engine over with key off by hand or with jumper on starter several times to get it moving again , clean plug with solvent and reinstall , also reinstall valve cmpt cover and tube , attempt to start might take several tries to get fresh fuel over to cylinder to fire or you might need to reclean plug several times
Nov 27, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Simplicity lawn tractor problem
Check your fuel cap. If not venting properly, gas can be forced to places it shouldn't be. I also agree with carb over haul. If alot of gas in oil & alot of gas outta exhaust, lean towards carb issue.
Mar 19, 2012 | NRS Garden
I am removing a Kohler engine from a simplicity lawn tractor. I was told that the govenor gear inside the engine is not working because the engine just started racing (RPM's) I check teh linkage and...
While there may be a governor, I doubt that is the problem.
It is more likely just the linkage to the carburetor.
And you don't have to take the engine out to get to the carb.
Take the air cleaner off, and examine the carb butterfly.
There is a choke fast idle cam that is probably not in the correct position.
Aug 19, 2010 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Kohler engine was running, stopped abruptly, will not turn over, has oil, acts as if engine is frozen.
It may be. They can seize with oil in them. Unhook any belts from the engine and pull the starter free from it. If it still won't turn, it's probably seized.
Nov 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My craftsman 15.5HP kohler riding mower turns over
Try cleaning or better yet, replacing the spark plug. Depending on age and how your tractor was maintained, there are other possible causes.
  • Gummed up fuel system
  • dirty fuel filter
  • defective or misaligned armature/magneto (part that causes your plug to spark, igniting the air/fuel mixture, thus starting the engine)
  • throttle linkage/cable problems
  • low oil level. Some Kohler engines use a low oil shut down sensor which won't allow the engine to run or start to avoid internal damage.
  • Mechanical engine problems
I hope you find this solution helpful. Please rate it thanks for using Fixya!
Nov 05, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
93 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
