Question about Samsung LN-S4692D 46 in. LCD HDTV
Sound but no picture
I have a 40 lcd samsung after about 6 months the picture would go out in the middle of a movie. i would turn it off and back on and the picture would appear. Is the fuse bad? or whats the problem
Re: Sound but no picture
Call Samsung and ask to speak with an Executive Customer Support specialist and they may help you which may take 6-8 months and you may have the same issue again in 15 -17 months. Try it out and if unsuccessful then contact your Better Business Bureau and see what they can do; that is what I am in the middle of right now.
Posted on Aug 06, 2008
I just had the same problem with my samsung 46". We were watching a movie and the picture went out. It is still out.l we turned it off and on and still no picture. I'ts been out all day. Any suggestions?????
Posted on Jul 21, 2008
0 characters
3 Points
Samsung 50" led un50h6350. The TV is about 18 months old and the picture went out, the audio and back light are working. I've replaced the t-con board and that didn't fix it. Someone please help!
Samsung LED TV Screed goes blank periodically for 1 sec - Forums ... > Forums > Samsung
CNETJun 11, 2015 - Lately, my Samsung LED TV's screen will black out from 1 -2 seconds then come back. The TV has been ... The TV is about 6 months old. .... I've only notice this when I'm watching in HD. ... by Stlouib / January 13, 2012 11:18 PM PST ...Mine does the same thing - picture goes black for 1 - 2 seconds and then comes back. Samsung Series 3 (330), won't show any picture/no sound?
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
More results from
Are there still capacitor problems with Samsung TVs?
Dec 21, 2015 | Samsung Flat Panel Televisions
When I switch on my Samsung 40 in LCD TV, half of the pcicture comes inverted and after a minute or so, it straightens. Initially the picture is hazy and then the picture turns normal. Sometimes, the...
This problems could be also causes by the board the call the T-CON docoders board,it sit in at middle of the bottom of the LCD screen panel.Because this board decoders incomming pictture signal before it go into the LCD screen panel to produced a picture.Tries websites like, to buy a refurbish T-CON decoderd board for the replacement.
Apr 16, 2011 | Samsung LA40A450 40 in. LCD TV
Picture won't come on
Most likely failed capacitors in the power supply. I am currently having the same problem with my 26 month old LN46A750. Samsung has agreed to fix this as an out of warranty "courtesy repair".
Jun 20, 2010 | Samsung 40 in. Flat-Panel LCD HDTV
Samsung LN40A550 40-INCH 1080P LCD HDTV power off/on quickly
you need to be vigilante in your efforts to have the problem repaired under warranty this is an intermittent fault and they are obligated to address the problem in a timely manner, contact management, contact the manufacturer. put the wore in to warranty it works good luck
Jan 31, 2010 | Samsung LN40A550 LCD TV
Samsung LN40B530 40" 1080p LCD HDTV Picture rotated
how to rotate my samsung flat screen monitor turning up side down
Sep 08, 2009 | Samsung LN40B530 40 in. LCD HDTV
Samsung 40" lcd sound but no picture.
May be the backlight is out, can you see a picture when shining a flashlight on the screen. if yes you have either a bad inverter power supply or bad screen (panel).
both are serious , also could be just a few bad capacitors on the power supply, if you want you can do a visual of the power board caps will appear swollen on top and are easy to solder in cost about $1 each
Jul 21, 2009 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Bad picture/colours on Samsung LCD TV
loretta change your power pack
entwined  try another cable
Aug 21, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
it's the T-con board attached to the lcd panel
Jul 29, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
I had a problem with a Samsung 46 inch LCD and it had audio and dim light but no picture and found out that the logic board toward the top (inside tv) was bad and was no longer available and the only way to fix it was to get the entire display panel (the logic board came with it) It was not costwise to repair. Hope this helps.
Dec 28, 2007 | Samsung LN-S4092D 40 in. LCD HDTV
Samsung 40 no picture
If it is only 6 months old you probably still have a warranty. This is definitely a hardware issue, and unless you are comfortable taking your new TV apart, I would contact Samsung for repair.
Dec 11, 2007 | Samsung LN-S4051D 40 in. LCD Television
Samsung LN-S4692D 46 in. LCD HDTV Logo
173 people viewed this question
Top Samsung Flat Panel Televisions Experts
xxxxxx xxx
Steve McIntosh
Level 1 Expert
Steven Wander
Steven Wander
Are you a Samsung Flat Panel Television Expert? Answer questions, earn points and help others
