Question about Philips TSU7000 LCD Touchscreen Remote Control
My t.v. remote, a Phillips TSU 7000 had the menu screen go "Blank" . How do I repair it?
Am unable to set up my new Phillips TV
not sure if this will help you out,but if not go to this link...
Press the button on the remote control to access the home menu. Use the cursor buttons to select SETUP and press the 'OK' button to confirm. Select CONNECT TO NETWORK and press the 'OK' button. Check whether your router supports Wi-Fi Protected Setup (WPS).
47PFL7666H/12 Philips 7000 series Smart LED TV 47PFL7666H 119 ...
www.p4c.philips.com/cgi-bin/cpindex.pl?ctn=47PFL7666H/12... set up my new Phillips TV Google Search
Oct 23, 2017 | Computers & Internet
Sound, but screen blank
When pressing the menu button on the tv remote does the menu show on the screen. If not likely the backlight is out. The panel is bad. replace the tv. Repair is not cost effective.
Feb 27, 2013 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
When I turn it on the screen stays blank and there
this a defective power supply, normaly the HV circuit is burned, needs to be repaired. send to repair shop
Jan 29, 2010 | Philips Magnavox 9P6034C 60" Rear...
Opening up Philips WAC 7000
My Phillips wac7000 wont connect to my PC
May 05, 2009 | Philips Electronics - Others
JVC LCD TV LT-42X688-powers on, blank screen. no picture,no sound
You most definately have bad capacitors in the power supply. try and get it repaired as soon as possible, not an expensive repair that iv'e seen.
Feb 04, 2009 | JVC LT-32P679 32 in. LCD TV
Mitsu vs60603 menu ?
actualy the only wat to reset is to unplug the power cord for 1 minute the plug it back in.
Aug 18, 2008 | Mitsubishi VS-60603 60" Rear Projection...
Cl034 magnavox remote versus samsung directv reciever
Go to http://www.urc.philips.com/. The Magnavox CL034 is under another name, US2-PM435, the Phillips version. Drop down menu to left of screen.Pick United States URC models. Then pick My remote is...US2-PM435. These codes really work and being the official samsung site they have many more than one recieves with the remote at time of purchase. Also note that the CL034 is the Magnavox remote (it does not have Phillips insignia)
Jul 25, 2008 | Philips Magnavox Learning Universal Remote
Can't get to the home screen
I've just solved that problem in the VSX 7000 of my girlfriend's Job.
Your VSX7000 has at least 4 video outputs, 1 for VGA and Supervideo 1 and Supervideo 2.
Firstly you should try VGA connector, because the main menu may be there, so you could change the configuracion.
If you can't see main screen in any of the output connectors you'll have to use the http tool.
In your internet browser enter the camera IP address, and you'll get the Web Interface of the VSX7000.
It will prompt you for user & password, the default options are "Admin" and your VSX7000 serial number (14 digits) you can find this number under the camera.
Once you're in the Web Main Menu, click on Site Map. There you can choose what you want to see in the screen of Monitor1 (My menus are in Spanish, maybe your menu says something like "screens" but I'm sure you'll find it)
If you choose Monitor/Screen 1 as Svideo, and select it as output for Local, Remote and Content you should see the Main Menu after the VSX7000 Reboots.
I hope it would be useful for you, if you have any problem with this let me know... This VSX7000 is working fine now, so yours should work!
Sep 19, 2007 | Polycom VSX 7000 Video Conference
Philips TSU7000 LCD Touchscreen Remote Control Logo
80 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
