Question about Jet 331416 24-3/4Inch x 7-1/2Inch Hydraulic Shop Press HP-15A, 15 Ton
Ricon wheel chair lift need wiring diagram
Have an electric wheel chair lift it's hydraulic,manuel,and electric need diagram to wire to battery
3 Suggested Answers
dwilkes7
  • 6 Answers
SOURCE: need a wiring diagram for jet 3 power chair
Look here: http://www.pridemobility.com/pdf/Owners_Manuals/US_Jazzy/US_Jet_3_ultra_om.pdf
Posted on May 12, 2010
  • 692 Answers
SOURCE: CAN'T LIFT OFF SEAT OF JET3 POWER CHAIR? batteries
Richard The seat is probably rusted on the seat post It will take alot of turning and pulling upward at the same time to get it off. Try spraying a penetrant on the post just below the seat to see if that will help with the turning and pulling just keep at it. It can be a tedious task and frustrating Hope this helps
Posted on Mar 17, 2011
Lark 3. Where can I get a wiring diagram?
hi , you won't get a lark 3 diagram sadly
If you tell me the controller used or better a picture (black box located at the rear ) i can help , sometimes it hard wired by a switch from batteries or the controller outputs a voltage to the lift motor ,
I have repaired many Larks...
Regards
Rob
www.gewizrepairs.co.uk
Jun 08, 2015 | Health & Beauty
Any one got a picture of the battery compartment for the flexmobil classic, or a wiring diagram. as i disconnected batteries and removed for replacment, and have now forgotten what wires go to what battery...
Oh this is a classic mistake not laughing at you done it myself, the wires are arranged so that only two of the wires go back to the controller, follow the wires.Very important both leads do not go to the same battery, one goes to one battery say a red one +, the other one say black one goes to the -, the other remaining leads go to there respective colors. the remaining wires should test with a meter should be very low resistance like testing both ends of a single strand of wire.
Scooter Doctor App you can get a email to me if this was not clear enough.
Mar 26, 2015 | Electric Mobility Power Electric Scooter...
Kubota L2250 DT wiring diagram
You can download:Kubota Tractor L2250, L2550,L2850,L3250 2WD 4WD Operator Manual
This Manual Covers
1. Servicing of Tractor
2. Specifications
3. Operating New Front Mower
4. Instrument Panel and Controls
5. Lift Link and Hydraulic Control
6. Wheels, Tires and Tread
7. Operating
8. Maintenance
9.Check and Maintenance
10. Adjustments
11. Troubleshooting
12. Long-Term Storage
13. Lubricant Specifications
14.Wiring Diagram
Jul 03, 2012 | Motorcycles
I do volunteer work for a non-profit organization in Milwaukee that recycles donated power wheelchairs, scooters and other medical equipment. I have been tasked with finding and printing battery...
Hello mmcpowers,
For the Pride Jazzy wheel chairs you can locate what you need at the Jazzy website at the following link http://www.thescooterstore.com/products/product_manuals.aspx
When on the site you will locate the chair you need and the wire diagrams are in the owners manuals. As a common problem is just a plug coming un-wired they tell you where they are and the wire configuration. If you tell me some of the other chairs you are dealing with I will try and locate the website for them as well.
Thank you for choosing FIxYa.com
Jan 10, 2011 | Pride Jazzy 1103 Ultra Standard Power...
Switch Wireing Diagram
The motor operates on low voltage DC current Robert. You will have a negative and a positive, like a car. The center connector is a common, meaning that it will be connecting to the motor whenever you switch is activated to make it go, and the other two are positive and negative to control either up or down. These should be color coded red and black and will go to the outside connectors and the remaining wire will go to the center common connection. Hook it up and then test the chair lift button. If it doesn't lift, you need to reverse the two outside wires for correct polarity, or just use the switch controls opposite; up for down, down for up.
May 03, 2009 | Pride Mobility Products Casual CL20KD Lift...
Jazzy 1200 power wheelchair is electrically inoperable after owner fell on back of chair at night. Battery was charging at time of accident. Believe problem may be in multi-pin connector betweenjoystick...
When you say inoperable I am assuming you are not getting a flash code on the joystick. I would check the wiring from the charge meter on the rear? console - you will see a yellow slug in the harness that has a fuse in it - check all the wiring from the meter as this can cause a 'power loss' problem. Of course, check the battery connections as well.
Mar 07, 2009 | Pride Health & Beauty
I would like to get a wiring diagram for a 2004 F150 trailer plug
I would probably connect directly to the positive battery cable/post and use a fusible link or high amp fuse (30 or 45).
Or you could look in the battery junction box (BJB) and find an open fuse location that is hot in run or hot all the time and use it. I tried sending an illustration, but this site doesn't support it.
Feb 23, 2009 | 2008 Ford F-350
Wheelchair through floor lift
dont know anything about a wheel chair lift, but why is it posted in dehumidifiers repair section?
Apr 12, 2008 | Dehumidifiers
Jet 331416 24-3/4Inch x 7-1/2Inch Hydraulic Shop Press HP-15A, 15 Ton Logo
733 people viewed this question
Top Jet Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Jet Measuring Tool and Sensor Expert? Answer questions, earn points and help others
