Question about Microsoft Windows XP Professional SP3 Full Version OEM for PC
My system is a desktop Asus with a Crosshair motherboard and AMD Athlon 64 FX-62, 2800 MHz: nVIDIA nForce 590 SLI with Socket AM2 and 4GB Dual DDR2 SDRAM. All the drivers are up to date and all the Microsoft patches for SP2 have been installed. Before first trying to install SP3 I took the steps prescribed by Microsoft and used their tool to check system was SP3 compatible. It reported that the Computer was ready to accept SP3. I then did the install offered by Microsoft Update after first disabling my Antivirus. The installation appeared to be successful. But after a reboot the system hung at the first Windows screen. I rebooted in Safe Mode plus networking which was successful and all devices seemed to be OK. I restored the SP 2 system from a backup image and installed SP3 from the Microsoft CD in Normal Mode but the result was exactly the same. I accessed the Microsoft SP3 help chat for help but the technician could not solve the problem. Do you think I have missed something that I could do to install SP3, Would it be worth installing SP3 offline from the Microsoft SP3 CD in safe mode or is better to stop spending time on SP3?
  • onclejon May 17, 2009
    Thanks for your message. I have installed SP3 in Safe Mode. The installation completed successfully with no error messages but on rebooting I could only access windows in Safe Mode or Safe Mode with Networking. Normal Mode and VGA mode would boot but hung at the first Windows screen (chucking bricks) with the disk LED flashing continuously at about 2 second intervals.
    It is frustrating that SP3 WILL work in Safe Mode including read Optical disks and print to the default printer a correct test page and BUT I cannot detect what is stopping Normal Mode from loading. If there is no way of doing this staying with SP2 sounds best particularly as you say it will still be updated correctly by Windows Update.
    While I could make a new install of XP + SP3 from the slip-streamed XP Pro+SP3 CD I have made ( I have tested that it is valid by installing it on my backup disk), install all the applications and restore all the data and settings looks like a whole day's work I guess you advise its not worth it?
    John
    Ginko
    Thanks, I had about reached the same conclusion and your comment is very helpful. I will not bother anymore with SP3.
    John
  • Microsoft Master
  • 19,396 Answers
Evidently one of the updates in SP3 is having a compatibility problem with one of the software or drivers installed.
Installing SP3 from CD or from the online download does not make a big difference, both the setup will install the same updates in the same succession.
You can try reinstalling SP3 from safe mode, it will be successfull only if the problem was a running process that could not be shut down during upgrade (many processes are not started in safe mode).
If SP3 still does not install, then you will need to reinstall a fresh version of Windows, then upgrade to SP3 and install the rest of the software afterward.
At that point, if the system is running OK with SP2 and the rest of the updates installed, I suggest keeping SP2 rather than reinstalling the System. Most of the updates contained in SP3 are currently being distributed and installed using Microsoft Automatic Update.
Regards.
Posted on May 17, 2009
  • Ginko
    Ginko May 17, 2009
    If you can only access windows in Safe Mode, that is because in safe mode many system task are not automatically started, and the process that is in conflict with SP3 is not running in safe mode.
    finding what process is in conflict with SP3 is very difficult, if not impossible, and using a registry cleaner or similar program risks to make things worse.
    Regarding a new system installation , that will take 3 or 4 hours, and will wipe out all your old software, as you will need a new installation, possibly formatting the Hard disk, rather than doing an upgrade installation that will not work. The system should work on SP3 after doing a fresh Windows setup with SP3.
    If it is worth or not depends on your time, and on the problems caused by deleting all software and settings.
    If you really want SP3, and you do not mind formatting HD and installing a fresh Windows, a fresh setup may still be worth.
    Ensure that you have all drivers and all the software for your computer first, if you do not have motherboard original driver disk , then take a screenshot of device manager with rows expanded , so to have a list or installed devices, or ensure that you already downloaded all drivers for your system.
I want to know the graphic card slot in the motherboard ASUS M2N68-AM-SE2. Whether it supports DRR1, DDR2 OR DDR3.
Hi, you can see the list here:
http://www.asus.com/Motherboards/AMD_AM2Plus/M2N68AM/#specifications
At this site you also find drivers.
Remember to select your operating system
AMD Socket AM2+ / AM2 Processors
for AMD Phenom™ FX / Phenom / Athlon™ / Sempron™
AMD Cool 'n' Quiet™ Technology
AMD64 architecture enables simultaneous 32-bit and 64-bit computing
Support 45nm Phenom™ II CPU Chipset NVIDIA Geforce 7025/nForce 630a
System Bus 2000/1600 MT/s Memory 2 x240-pin DIMM, Max. 4 GB, DDR2 1066/800/667/533 ECC,Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*DDR2 1066 is supported by AM2+ CPU only Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
Storage Southbridge
4 xSATA 3 Gb/s ports Support RAID 0,1,5,10,JBOD
ATAPI support ,AHCI mode
LAN RTL8211CL Phy Gigabit LAN Audio ALC662 High Definition Audio 6 -Channel CODEC
USB 10 USB 2.0 ports (4 on back I/O, 6 on board)
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCI-E x16 Graphic card slot.
Aug 25, 2011 | ASUS M2N68-AM SE2 Motherboard
What can i use processor in this motherboard can i use 1.8 mhz
Processor speed 1.8 MHz is not the parameter for using this kind of motherboard. Upgrading or replacing CPU on motherboard is based on the socket CPU, and your motherboad support AMD® Socket AM2 Athlon 64 X2 / Athlon 64 FX / Athlon 64/ Sempron....
Aug 06, 2011 | ASUS M2N-MX Motherboard
How Do I unlock CPU cores with Bios on MCP61M-M3 motherboard?
The motherboard supports AMD socket AM2 single-core Athlon 64/ Sempron and dual-core Athlon 64 X2/ Athlon 64 FX processors with 2MB / 1MB / 512KB L2 cache, which is based on 64-bit architecture. It features 2000 / 1600 MT/s Hyper Transport Bus, dual-channel un-buffered DDR2 800 memory support and AMD Cool 'n' Quiet! Technology.
The BIOS changes it on it's own when add a dual core.
Here is the PDF file on this board. Chapter 2 explains the Bios.
Jul 03, 2011 | EliteGroup ECS MCP61MM3 (V10) AM3 NVIDIA...
Id like to buy a msi nf725gtm-p31 mobo but am unsure if it supports am2 processors and ddr2 can u pls advice thanks
Here are the specs of the motherboard, both answers to your questions are "Yes". Happy purchase and have fun with it !
CPU
• Support socket AM2 for AMD® Athlon 64/Athlon 64X2 CPU / AM2+ for AMD® Phenom CPU / AM3 for AMD® Phenom II / Athlon II CPU . (95W only)
Please refer to CPU Support for compatible CPU; the above description is for reference only.
bult_ar_org.gifHyper Transport Bus
• HyperTransport 1.0 supporting speed up to 1000MT/s
bult_ar_org.gifChipset
NVIDIA® nForce 630a & GeForce 7025 chipset
bult_ar_org.gifMain Memory
• Supports Dual Channel DDR2 667/800
- 2 DDR2 DIMMs (240pin / 1.8V)
- Supports a maximum memory size up to 8GB.
bult_ar_org.gifSlots
• One PCI Express 1.0 x16 slot.
• One PCI Express 1.0 x1 slot.
• Two PCI slots (support 3.3v/5v PCI bus interface).
bult_ar_org.gifOn-Board IDE
• One IDE port by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports Ultra DMA 66/100/133 mode
- Supports PIO, Bus Master operation mode
- Can connect up to two IDE devices
bult_ar_org.gifOn-Board SATA
• Two SATA II ports by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports storage and data transfers at up to 3Gb/s
bult_ar_org.gifRAID Function
- SATA II 1~2 supports RAID 0, 1 mode by NVIDIA® nForce 630a & GeForce 7025 chipset
May 12, 2011 | Computers & Internet
What is the specification for my GA-K8N Pro motherboard?
CPU
  • Socket 939 AMD Athlon™ 64 X2 / Athlon™ 64 FX / Athlon™ 64
Chipset
  • NVIDIA nForce4 SLI MCPs (media and communication processors)
  • Super I/O: ITE IT8712
  • CICADA VSC 8201 Gigabit LAN PHY
  • T.I. IEEE1394b
  • AC'97 Realtek ALC850
Memory
  • Dual channel DDR 400 / 333 / 266 184pin
  • 4 x DIMM slots up to 4GB
Expansion Slots
  • 2 x PCI Express x1
  • 2 x PCI Express x16, supports two PCI Express interface Graphics cards with SLI mode
  • 2 x PCI slot (PCI 2.3 compliant)
Internal I/O Connectors
  • 1 x CD in
  • 1 x FDD
  • 2 x IEEE 1394b (supports 3 ports)
  • 2 x UDMA ATA 133/100/66 Bus Master IDE
  • 3 x cooling fan pin headers
  • 3 x USB 2.0/1.1 (support 6 ports)
  • 4 x SATA II 3Gb/s
Back Panel Connectors
  • 1 x COM
  • 1 x LPT
  • 1 x RJ45 LAN
  • 2 x USB 2.0/1.1
  • 6 x audio ports (Line In / Line Out / MIC In / Surround Speaker Out(Rear Speaker Out) / Center/Subwoofer Speaker Out / Side Speaker Out)
  • Coaxial SPDIF input/output function
  • PS/2 (Keyboard/Mouse)
H/W Monitoring
  • H/W detecting and reporting for case open, CPU voltage and fan speed
  • System health status auto-detect and report by BIOS
BIOS
  • 2 x 4 Mbit flash ROM
  • Award BIOS
CPU/AGP/DIMM setting
  • CPU HT / Multiplier / Vcore Voltage adjustable via BIOS
  • DIMM Voltage / Clock adjustable via BIOS
  • PCI-ExpessX16 Voltage / Clock adjustable via BIOS
Unique Features
  • @BIOS™
  • Download Center
  • NVIDIA Firewall
  • NVIDIA SLI multi-GPU support
  • Q-Flash™
  • Xpress™ Install
  • Xpress™ Recovery
Bundle Software
  • Norton Internet Security™
Power
  • ATX power connector and ATX 12V connector
  • Power-off by Windows 98/Me/2000/XP shut down and switch
Form Factor
  • ATX
  • 305mm x 244mm
Remark
  • Due to different Linux support condition provided by chipset vendors, please download Linux driver from chipset vendors' website or 3rd party website
  • This product does not support Win9X/ME, due to most hardware/software vendors no longer offer support for Win9X/ME. However we still offer available related drivers to serve our customers.
Jan 08, 2011 | Gigabyte GA-K8N Pro-SLI Motherboard
Will the ASUS A8V-VM Motherboard Handle DDR2 memory & AMD 64 x2 4000 cpu?
It will not support a DDR2 memory but it will support AMD 64 x2 4000 CPU see specs below..btw your usin socket 939
Memory Supported:
2 x DIMM, Max. 2 GB, DDR 400/333/266 ECC,Non-ECC,Un-buffered Memory, Dual Channel memory architecture
Socket 939 Supported processors :
Sempron / Sempron 64 (1.8 GHz - 2 GHz, or 3000+ - 3500+)
Athlon 64 (1.8 GHz - 2.4 GHz, or 3000+ - 4000+)
Athlon 64 X2 (2 GHz - 2.4 GHz, or 3800+ - 4800+)
Athlon 64 FX (FX-53 - FX-60)
Opteron (1.8 GHz - 3 GHz, or model 144 - model 156)
Dual-Core Opteron (1.8 GHz - 2.6 GHz, or model 165 - model 185)
Jun 29, 2010 | ASUS A8V-VM Motherboard
Freeze up system after booting
  • check the CPU fans for dust,
  • run a HDregenation program on the HDD
Nov 09, 2009 | ASUS M2N32 WS Professional nForce 590 SLI...
What amd cpus does this mobo support? are there any that I can get off newegg for this mobo? and which sli connector should i get from Asus? like what length?
939 pin Athlon 64 X2 / Athlon 64 FX / Athlon 64 are the supported CPU's.
For the SLI connector, it's a 2 1/2 inch connector. (63.5mm).
Oct 26, 2009 | ASUS A8N-SLI Deluxe Motherboard
Which graphics card ican use in ASUS M2N68-AM SE2 mother bord amd athlon 64 5200+
unfortunately, this board does not appear to have slots for upgrading its graphic card.
Model Brand ASUS Model M2N68-AM SE2 Supported CPU CPU Socket Type AM2+/AM2 CPU Type Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2 Chipsets North Bridge NV Geforce 7025 / nForce 630a chipset Memory Number of Memory Slots 2×240pin Memory Standard DDR2 1066 Maximum Memory Supported 4GB Storage Devices SATA 3Gb/s 2 SATA RAID 0/1/JBOD Onboard Audio Audio Chipset Realtek ALC662 Audio Channels 6 Channels Onboard LAN LAN Chipset RTL8201CP Max LAN Speed 10/100Mbps
You are stuck with the integrated card.
Jun 28, 2009 | Computers & Internet
Eathernet card driver for M2n-MX mother board
your driver is available here: http://support.asus.com/download/download.aspx?SLanguage=en-us put in your operating system, download the driver to your desktop and install. your network card driver is included with the motherboard drivers package. it may alow you to install each individually or you may have to install the whole package to get the one you want..
Apr 15, 2009 | ASUS M2N32 WS Professional nForce 590 SLI...
Open Questions:
See all Microsoft Windows XP Professional SP3 Full Version Questions
Microsoft Windows XP Professional SP3 Full Version OEM for PC  Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
