Standard Televisions
Generic problem for all Standard Televisions
Panasonic TV - no picture, but sound is ok
shared by 6 users
posted by webinfluence on Oct 17, 2007
The picture on my panasonic tv is not working.  There is a very thin line accross the middle of the screen when you press the menu button or switch to a video input, but other than that - no picture.
Other than that, the sound and other functions seem to be working - as far as I can tell.
Is there any suggestions?
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
5 Other Users Have The Same Problem
Posted by seffieandcoc on Sep 30, 2008
I have the exact same problem.  I did not get the vertical section thing.....what is it and how do I fix it???  Like do you take the TV apart????
Posted by bitchyblond on Jul 06, 2008
I have a panasonic ct-36hx40b year 01 very finicky have done - cable conn. unplugged for an hour still nothing left on in about 10 min turned it self off then on dark pic played w/ brightness tint pic. temp to norm and had good pic afraid to turn off hope it's fix finger's crossed. any help will be appreciated ps. love my tv pretty handy have tools elc. volt omen meter
Posted by bacher43 on Jul 02, 2008
I have no picture but the sound is on. It isa Panasonic TV,\. It is hooked up to cable and I just changed the box
Posted by Guest on Jun 20, 2008
Mine is doing it too. Jiggle the cable connection to temporarily fix. Getting worse.
Posted by HeBo on Dec 18, 2007
I have a panasonic CT-27G32V and there is no picture, but we have sound. Before it went out completely, there would be a thin white horizontal line across the screen. Initially the thin white line would spread to the entire screen and the picture would return, but now the entire screen stays black. What to do? and is it worth repairing?
Best Solution
posted on Oct 17, 2007
Helpful (85)
modern
Rank:Wiz Wiz
Rating: 80%, 573 votes
it is due to vertical section failure.
  • before you start any work reduce brightness to avoid crt burn.
  • please check some loose contact or loose connector.
  • check supply to vertical section
  • check parts in vertical output section
  • check vertical ic.
  • hope this will help.
  • good luck.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Panasonic TV - no picture, but sound is ok:
I don't want to Accept this solution
Can you Help with these Standard Televisions problems?
Apex Digital GT2011S 20" TV
Hi there, we have an Omni T8005NF model tv and the screen...
Panasonic CT-27D12D 27" TV
Can I still connect cable through the input 2 jacks to the...
Samsung DLP HL-P5663W 56" TV
HI. My Samsung 56" DLP goes to complete snow with a...
This TV is 6 years old and has the original Bulb. The...
Sanyo HT32744 32" TV
I was watching t.v. and the screen turned green with a...
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Repair Service
Find Standard TV Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
