Question about Kenmore Elite 45986 Front Load Washer
Leaky heating element
I have a kenmore eli upright washer and the seal around the heating elment is leaking. how can i stop this
    Problem Solver:
  • 9 Answers
Their is a nut right in center of heating element. loosen it and push heating element a little in and tighten bolt. that should work.
Posted on May 21, 2009
Washer leaks
the door seal is gone check around the inside of it for a tear
you can slide a bit of newspaper under it and run a cycle on
then pull out the paper and you can see what part of the machine its coming from
if its near to the front its prob the door seal
quite easy to change by heating it up before fitting
do the drum end first
Dec 20, 2014 | Kenmore Washing Machines
I have an electric 50 gallon hot water heater 2 years old its seemed to be leaking by the upper heating element. I replaced the elment and it still leaks what could be the problem
It could leak trough the bolts that holds the element, the gasket as well, and it could be a crack in the tank around the opening of the element if it's a plate type element, if it's a screw in type elemnt, than it could be a crack in the threads or you didn't seal the threads with proper compound...
Aug 02, 2011 | Water Heaters
Dryer is going around but there is no heat? What should I do?
check you household fuses/breaker if 1/2 tripped or you have a bad heating elment or a thermal fuse opened remote chances are a faulty time but check the 3 possibilties then if not a repair person is required.
Feb 13, 2011 | Kenmore Dryers
How do you replace the heater coil on this unit
First of all you did not even begin to mention a model number. They are not all the same. Having said that the concept of changing a heating element is pretty much the same for those with through the lower tub mounts.
1. Turn off all power to the unit
2. Open the lower kick panel
(It is usually in 2 pieces) The top piece being fixed and the lower piece being adjustable to the floor. Remove BOTH panels.
3. Locate the 2 heating element terminals that pass through the bottom of the tub and disconnect the wires.
4. Losen the retaining nuts on the heating element. Push up on the elment to make sure it is free before totally removing the nuts.
5. Remove the nuts and then lift out the old element by opening the door and lifting out the element.
6. Note the position of seals and washers on the OLD element
7, Assemble the new element with the tub side seals and washers. Leave the under side washers off until after you place the new element in the dishwasher.
8. Install the underside seal and washer then install the nuts loosely.
9. Check the position of the element inside the tub. (Align as necessary)
10. Tighten the heating element retaining nuts on the under side of the tub. (DO NOT over tighten as you can damage the element.)
11. Install the 2 heating element terminals makeing very sure the connections are TIGHT. A loose connection will cause the new element to fail prematurely.
12. Connect power and test for leaks.
13 Leak test complete install both lower kick panels.
Task Complete!
Thanks for choosing FixYa,
Kelly
Oct 04, 2010 | Kenmore Dishwashers
Leaking from the heating element connectors under the diswasher
You need to probably replace the nut and seal/washer assembly that holds in the heating element. While there, check to determine if there is a hole in the tub. There was a fix for some Kenmores that had this problem. Check to see if your's was covered. You should probably replace both nut and seal/washer assemblies for added insurance.
Mar 13, 2010 | Kenmore Dishwashers
HE2 washer leaking water from bottom of door/seal during washing
Open the door so it is 90degrees from machine, see if it is upright. if not undo the door bolts slightly and re alighn door. Good luck and feel free to give feed back.
John
Sep 03, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore dryer does not heat
I have a kenmore series 80. Had the same problem...the fix was replacing the gas coils. The dryer would get hot for about 10-15min then nothing. The gas would stop firing but you could see the igniter glow over and over again. Hope this helps.
Apr 02, 2009 | Kenmore Dryers
Leaking front loader
If your washer has a rubber seal around the inside of the door and it has a little opening where the detergent comes into the washer put your hand inside the rubber piece and feel all the way around and see if you feel any holes or cracks in it and that is where it will leak from.
Dec 03, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
49 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
