Question about Samsung SGH-D820 Cellular Phone
SGH-D820 screen displaying "Cingular Extend", when normally it would display "Cingular".
I am on the AT&T(Cingular origionally) Network. One day I awoke to find my Samsung SGH-D820 screen displaying "Cingular Extend", when normally it would display "Cingular". This could normally be corrected by going to the "Network Selection" feature, and after a short search, it would give me a choice of "Cingular Extend" or "Cingular" for my Network. However when I try to use the Network Selection feature, the choices that I am given are "Cingular Extend" or "T-Mobile" . "Cingular Extend" induces roaming charges and "T-Mobile" ,when seleced, reads "Not Allowed". How can I get the phone to give me an operational network?
  • 425 Answers
Try resetting your phone to its factory settings..
Posted on Oct 17, 2007
  • Johnny Miranda
    Johnny Miranda Oct 17, 2007
    try to call your operator's customer service bec usually it is set by your operator settings. try calling them thier very happy to help you...
On the SAMSUNG SGH-ZV40 how can i change the ring tones. can i get a step by step guide as my screen has broken
Hi Lilfranza,
Menu structure is: Menu/Settings/Profiles/Normal Profile/Options/Incoming Call/Voice Call Ringtone see details below
Sound Settings
You can customize various sound settings.
1. When the Idle screen displays, press the Menu soft key.
2. Select Settings and press the Select soft key or the Cingular icon key.
3. Select Profiles and press the Select soft key or the Cingular icon key. Use the Down
Navigation key to scroll through the following list of available options:
Normal Profile
To access the available options for this calling profile, press the Options soft key.
Highlight Edit and press the Select soft key or the Cingular icon key. Use the Left and Right
Navigation keys to move between the various tabs. This menu allows you to alter the
audio settings for the following categories:
• Incoming Call: allows you to edit the properties for audio alert used for incoming
phone calls.
-_ Voice Call Ringtone: allows you to select a ringtone from your My Stuff (Phone)
folder which contains not only the default phone ringtones, but also any new
ringtones which have been downloaded from the Internet.
Mar 15, 2011 | Samsung SGH-ZV40 Cellular Phone
No service only emergency
HI,
Go into your phone settings from the start menu and go to Wireless Manager, then click on Menu. Choose 3 Phone Settings from the popup and then choose More from the option, which takes you to Networks. If your "Current Network" is none, click Menu and search for networks. Cingular should be found
Aug 08, 2008 | Samsung Blackjack SGH-I607 Smartphone
I dont know the PIN2 CODE of my SAMSUNG D900I
1) Insert non Tmobile SIM (Such as a Cingular SIM)
2) Phone on. It will display wrong SIM
3) Enter *7465625*638*00000000*00000000# (The zeros will be dashes)
(Press End and the screen will clear)
4) Enter #7465625*638*00000000#
5) Reboot phone. Now you can use the Cingular SIM card.
Feb 28, 2011 | Samsung SGH-D900 Cellular Phone
My camera is up side down and i don't know how to fix it when it faces normal it up side down.
when in camera mode, press the side key, it will display in several mode, be careful to stay on normal mode
Nov 28, 2009 | Samsung SGH-D820 Cellular Phone
My screen doent dispaly at start-up.
Try connecting and external display screen to your laptop's external display port. If the external display is working, then try to access your laptop display connector (usually can access by removing the top power button access cover and/or the keyboard assembly) to the motherboard and disconnect and reconnect to motherboard. Power laptop back on, if still doesn't work, then could be the display invertor pcb or the actual display. If you have to order a display, make sure the display invertor board comes with it. Hope this helps, Ed.
Aug 25, 2009 | Dell Latitude D820 Notebook
Dell latitude d820 xp: Mouse inputs are moving
Mine did that too, its normal, the actions undearneath maybe stuck just a little and thinks it is required to move when not
Jul 15, 2009 | Dell Latitude D820 Notebook
Latitude d820 screen twitch
Take it to a service shop and ask them to open the unit and the display. The cable connector to the display is loose on one side.
Jun 22, 2009 | Dell Latitude D820 Notebook
Display problem
off the phone just aminete then remove the battary no way change thh display
Jun 11, 2009 | Samsung SGH-D820 Cellular Phone
Phone lock code
PERMANENT UNLOCK CODE SAMSUNG SGH A117, T429, T729
Insert ANY unaccepted SIM card in the phone and then turn the phone on, follow the steps in 1 to 4 below to enter all the codes. The phone will states "Wrong card" at the end of step 2 and "network lock deactivated" at the end of step 4 if you do everything right so pls take your time to enter the code or follow the instruction correctly at each step. When entering some of the zeros at steps 3 and 4 your phone may display the zero as hyphen or minus (-), dont worry, just count when entering the zero to ensure you enter just the right numbers of zeros. Now let's begin... 1/ Put any unaccepted SIM card in your SAMSUNG SGH Phone, turn the phone on, it will display "WRONG CARD"
2/ At the wrong card screen, type *7465625*638*00000000*00000000#
3/ Now remove the battery with the SIM card, Put the battery back and turn the phone on again without the SIM card, it will display "Insert SIM card" 4/ At the insert SIM card screen/end of step 3 above type #7465625*638*00000000#
At the end of step 4 phone will show "network lock deactivated" 5/ Now Reinsert your unaccepted card or any other unaccepted SIM card in the phone and enjoy your unlocked phone!
Jan 22, 2009 | Samsung SGH-a737 Cellular Phone
Samsung T809, screen display is dull(week)
unfortunately, the board of your mobile phone has corroded. When the water dried up rust was developed. try cleaning the board of your phone...
Jan 02, 2008 | Samsung SGH-D820 Cellular Phone
Samsung SGH-D820 Cellular Phone Logo
106 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
