SOURCE: Wheel shaft seals on troy bilt pony 7 hp.
If the seal fits over the axle shaft it should be ok. be sure your axles are very clean as not to ruin the new seals when applying them. probably a good idea to replace them as a pair (right and left side) to save you time down the road.
SOURCE: Troy Bilt Rotor tiller, won't start
lac spark plug on motor pull cord if no spark take the pull start cover off and sand rust off fly wheel
SOURCE: how do i put a troy-bilt tiller 3 hp.into free
Knife333 is right, the hub pin method he described is the only way to disengage the wheels. The gearbox is not designed to be shifted in/out of gear, it is engaged full time. Foward and reverse movements are controlled by the drive belt direction only.
