Question about Philips CCC130AT 13 in. TV/VCR Combo
POWER TURNS OFF
WHEN PUSH POWER IT TURNS ON AND THEN AFTER 40 SECOND IS TURNS OFF.
  • Gamaliet Figueroa Oct 27, 2007
    REPLACED 150MFU 200 VOLTS ELECTROLITIC CAP. IN THE POWER SUPPLY, THANK YOU. AND RETOUCHED COLD SOIDERING.
    Problem Solver:
  • 7 Answers
Either the power supply is faulty , maybe some electrolytic capacitors need replacing. Or perhaps the EHT High Voltage feedback loop to it is inoperative due to a gradually  failing state of  one or more components in the Horizontal drive or Output stages.This is not a job for a non-technician and needs checking out by a Technician with the right test equipment ot analyse the problem and find the fault/s and fix it. Dangerous voltages exist which could be very harmful if not fatal!
Posted on Oct 17, 2007
My LC-46D85UN turns on and off at about 40 second intervals what is wrong
Fault with main board. Shorted component/s. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Aug 08, 2014 | Sharp AQUOS LC-32D44U 32 in. LCD TV
My 40 inch S400A Series Full HD BRAVIA LCD TV does not turn on. When i plug it in, the green light (next to the Red power light) blinks. If i try to power on via remote, the red power light turns on and...
this again sounds like the power supply,.if you hear a click when you push the power button, this means your main board is reading good so replace the power supply,.
Apr 06, 2014 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Power cycling
Push the "menu" button on your remote
Tab over to the "time" menu
check all the settings in there, turn of the sleep timer etc...
Try a factory reset
Push the "menu" button on your remote and go to settings, scroll down and push reset.
I hope this helps
Feb 10, 2014 | Samsung LN40D550K1FXZA - LN40D550 40 1080p...
Hi, I have a Harmon Kardon Model No. AVR 325 that keeps clipping. When I push the power button the display turns off like a second after I push power. Seems like its a easy fix. Nothing if fried visually...
it sounds like Amp burned, but not all burn parts you can see, you have to measure them by DMM. I guess at least one AMP transistor shorted. you can check SPK terminals by DMM DC, it can be easy to find different with other one
Mar 19, 2011 | Harman Kardon AVR 325 Receiver
The unit will not stay on
I got similar issue and managed to fix it with excellent tech support from NAD. Flashing LED means system goes in to protective mode. Most probable reason is presence of DC voltage on amplifier out puts. In my case it was both surround amps. It had faulty resistor and a dry jpint at power line
Dec 16, 2009 | NAD T760
Model CS- 40307 40 inch Mitsubishi TV will not turn on
continue to push power button until light turns green. verie rate of push and hold
Jul 15, 2009 | Mitsubishi WS-65819 TV
55" PIONEER SD-P5795W REAR..
yeah, I have the same issue... The tv worked fine, and now it will not turn on... the light turns green, then turns off and goes red...
Aug 03, 2008 | Pioneer SD-P5795W 57" Rear Projection...
HP Officejet G85xi with no power
Hi..
You can try to reset the Printer to factory settings.Just follow the below steps, dont worry my steps will not mess your printer , as i was HP tech support for All in One printer for 20 months.
POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON buton for 30-60 seconds.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait for 40 second then release the buttons.
----(for below reset cartridges must be removed out)---------
SEMI_FULL RESET:-Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait for 40 second then release the buttons. Push the ON button and check.
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold ENTER/OK and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons for 40 seconds ,then release the button and Push the ON button.
Please try the steps and let me know the result.Waiting for good reply from u.
Cheers
RIZ.
Feb 11, 2008 | HP G85xi All-Color InkJet Printer
Philips CCC130AT 13 in. TV/VCR Combo Logo
107 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
