Question about Yamaha RX-V661 Receiver
System shuts off when the volume is moderate to high, now the system shut off and will not turn back on.
System shuts off when the volume output is moderate to high. Now the system shut down and will not turn back on
  • sdurden1 May 20, 2009
    Thanks for the help. I unplugged the rec. and then replog all the speaker wire but still no power. When I try to turn it on, it clicks like it wants to come on but no power. How hard is it to replace the fuse? Could you tell me how or should I take it and have someone do it? Thanks again for your help!!!
  • 92 Answers
Unplug the reciever for at least 15 minutes. then replug in all of your speakers making sure there is no bare wire showing. if the reciever doesnt ower on replace the fuse inside(make sure unplugged from wall)
Posted on May 20, 2009
Sony Mini Hi-Fi Systwm shuts down at high volumes
You need to have the fan in the check,possibly its not working anylonger
Jan 22, 2014 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
My 2001 330ci has the Harmon Kardon sound system. However, when I run the system at high volume for about 5 minutes, the front speakers start cutting in and out. It doesn't seem like a speaker is blown,...
Thermal issue is shutting down amps till temps moderate. You must be driving your system too hard. And check out your tone control settings especially the bass. Every 3 db boost forces amp to double power at that frequency so if you are already blasting at 100 watts, a 3 db boost will compel amp to put out 200 watts, etc. Very easy to overdrive and overheat amp. You might want to try blowing air over output stages to improve cooling at high volume levels.
You are lucky that you have good protection circuits - otherwise by now you would have blown the output stages.
May 08, 2017 | 2001 BMW 330
Boat stereo shuts off when turning up the volume
When any radio shuts off wth high volume it is caused by several things.
1. The maximum power output was reached and the unit goes into the self protection mode.
2. The most common reason.... The power transistor has partially failed and will not provide the partially amplfied output necessary.
3. Units with removable face plates vibrate enough to disengage the face plate contacts so the unit shuts off.
4. The speakers are too big for the radio causing it to self protect. (system mis-match)
5. Loose connectors/pins on the radio input and output connections.
6. A poor system ground that is good enough for low volume use but when high power use is encountered the ground is not good enough to carry the amperage necessary.
These are the most comon reasons for a unit to shut off at higher volumes.
It is not always an easy fix troubleshooting this problem. I know first hand as a life long electrician that has the exact same problem with the radio in my automobile. (Mine appears to be a power transistor grounding problem) With shipping to the repair center each way and the flat rate repair cost it would cost as much as a new one!
Thanks for using FixYa.
Kelly
May 12, 2010 | Boating
Shuts off when turning volume up. Error message
go to a computer store and tell them to rebot your computer that what i did it worked for me it should probly work for u
Dec 18, 2009 | Yamaha HTR-5760 Receiver
My Yamaha RX-V661 shuts off at moderate volumes.
Try to disconnect speakers one by one and see if any of them causes the problem.
Nov 05, 2009 | Yamaha RX-V661 Receiver
Avr Shuts down at high volume
It does that because there is a safety feature in all the newer devices. If your system is turned up to high you would blow your audio outputs or speakers. That's why it shuts off.
Jan 17, 2009 | Denon AVR-3801 Receiver
Amplifiers
The unit is shutting itself off because it has detected a problem in the output stage. In many cases the problem is in the front end. That front end stage is allowing some DC current to pass on to the output stage. DC on the outputs is bad. This unit requires service. Expect a parts cost in the range of $10-$20. Add in the local labor rate for the total repair cost.
Dan
May 05, 2008 | Audio Players & Recorders
Sub woofer shuts off
please check sub cable first with another good one and then change sub itself.because it draw too much power.
Jan 05, 2008 | JVC TH-C50 System
Shuts down at moderate volume
change the impeadence settings of the receiver page 25 of the manual will tell you how.
Dec 26, 2007 | Yamaha RX-V661 Receiver
If you have your reciever in an entertainment center that is enclosed or a tight fit for the reciever you need to remove it and put it on top of the center. I have a VR407 and it was doing the same thing. This keeps your unit much cooler and the overheat relay will not turn it off. also I found it much easier to add or wire components much easier.
Steve T. PA
Nov 25, 2007 | Kenwood VR-407 Receiver
Yamaha RX-V661 Receiver Logo
544 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
