Question about Pentax Photography
No manual so need help with dials
No manual
  • 571 Answers
Http://the-manuals.com/
Posted on Nov 08, 2009
I have a model 2380 and I HAVE NO IDEA HOW TO SET IT BACK TO A STRAIGHT STITCH. WHEN I SEYT THE DIAL TO "A" IT STAYS ON ZIGZAG. THE MANUAL DID NOT HELP
You need to select A but also set the Stitch Width dial to zero. The Stitch Width dial should be the one on top of the machine next to the handle.
https://www.manualslib.com/manual/776764/White-Sewing-2380.html#manual (page 25: Select Stitch Pattern A, Stitch Width to zero, Stitch Length to zero to 4)
Apr 29, 2017 | Sewing Machines
Is there an owner's manual available on line for a Stebco Attache Case Model P-16? I need to know how to set the combinations on the dial lock system.
I couldn't find the manual for your particular briefcase, but please read the instructions on the attached link. It should help you since most briefcase combination locks work the same. Hope it helps.
How to Change the Lock Combination on Briefcase
Oct 27, 2014 | Lands Phones
Help! I can't get the water heater to go on! I KEEP TRYING to set the dial, but it's not working
If I understand correctly, you have the WH40 water heater timer.
If timer dial will not rotate, then use manual override to turn on circuit to water heater.
If manual override will not move back and forth, the tripper pin might be wedged against the lever.
Lift and rotate dial out of way.
If manual override does not click back-and-forth, then timer is probably bad.
If manual override clicks, but water heater does not turn on, then check electricity.
If you need more help, post a comment and I will respond
Oct 28, 2010 | Intermatic WH40 - Water Heater Time Switch...
Have a 4003-00 Timer for a business park outdoor parking lot lights. I need to change hte tim to come on ~ can't find the book to tell me how to change this? Can you help?
ef74fbb.jpgParagon 4000 series is a mechanical dial timer
Image explains general operation of timer
Attach Black tripper to dial at time you want lights to turn OFF
Attach Silver tripper to dial at time you want lights to turn ON
Minimum on-off period is 1-1/2 hours
Re-set dial after power outage.
The dial rotates with passing time
The timer takes the Paragon X2772 tripper
If tripper does not turn lights off-and-on, then you might need new trippers
If dial does not rotate, you might need new timer
If manual override does not work then check electricity
http://waterheatertimer.org/Paragon-timers-and-manuals.html#Paragon4000
If you need more information, add a comment below and I will respond.
Oct 27, 2010 | Paragon REPLACMENT MECHANISM 110V SPST -...
I need a manual for UTILITECH #0148373.. and i need it now! PLease help me..i need to know how to use this product. HELP PLZ!
Open following link to correctly identify product:
http://cgi.ebay.it/UTILITECH-2-OUTLET-TIMER-0148373-15-AMP-LOT-OF-4-/290468257053
Utilitec 0148373 timer is plug-in type timer.
Set on-off times by moving pins.
Pins are located on dial and stick up. They can be moved back and forth like stick-shift on car.
See example of pins at following link:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Pins-tabs
Instructions:
Turn ON lamp.
Light bulb is good.
Plug lamp into timer.
Plug timer into outlet.
Move some pins outward.
Then manually rotate dial clockwise to watch how lights turn on-off.
That will tell you if lights turn on or off when pins are set outward.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial turns as time passes.
Lever on top of timer is moved to 'Timer'
Dec 30, 2009 | Kitchen Appliances - Others
Group speed dial option is not lit up and will not let me click on it.....
http://www.brother-usa.com/Manuals/Default.aspx?WT.cg_n=Support&WT.cg_s=Manuals
Pages 5-1 thru 5-3 in the Users Guide cover One Touch, Speed Dial and Group Dialing (Broadcast Dialing). Apparently one touch and/or speed dialing need to be set up first. Hope this helps.
Sep 01, 2009 | Brother IntelliFax-2820 Laser Fax
Turning alarm on and off
I'm afraid I don't have a manual, but I could walk you through the steps...
1. Press the clock/sleep/timer button twice.
2. Press enter button.
3. Turn dial to set hour for alarm to start.
4. Press enter button.
5. Turn dial to set minute for alarm to start.
6. Press enter button.
7. Turn dial to set hour for alarm auto-shut off.
8. Press enter button.
9. Turn dial to set minute for alarm auto-shut off.
10. Press enter button.
11. Turn dial to select either Radio or CD alarm setting.
12. Press enter button.
13. Turn dial to adjust volume of alarm.
14. Press enter button.
15. Press standby button. Alarm is set.
I hope this helps! Best of luck finding a manual if you still need one. :)
Jun 03, 2009 | Sony PSYC CFD-E90 Radio/Cassette/CD...
Adding/deleting a new contact to the system directory
You can download the full phone manual from Panasonic here.
Mar 26, 2009 | Panasonic KX-T7630 Corded Phone
Photography Logo
23 people viewed this question
Top Pentax Photography Experts
Bill Eager
Greg Cann
Greg Cann
Are you a Pentax Photography Expert? Answer questions, earn points and help others
