FAX Problem I can only send a FAX, not receive. I have a line direct to the phone jack from the printer. Do I need to have a line between the printer and the PC?
    Problem Solver:
  • 5 Answers
No. did you buy a line? it costs 10.00 per month. but the first month is 100.00 because matianence.
Posted on May 17, 2009
2 Suggested Answers
MIlfordPrint
  • 90 Answers
SOURCE: 3055 fax not working, sendng or receiving directly
Below is a link to an HP tech site. They helped me with MY hp all-in-one. It turned out I needed to download a different driver from HP's tech website (the download is free) and that is probably what you will be doing, also. God luck.
Posted on Aug 03, 2009
We cannot dial out when sending a fax. You can hear the line open but no dialing tone. Any ideas?
  1. Make sure that you have plugged the phone cord directly and securely into the wall jack and into the back port of the fax product. The fax port on your product is marked "Line," "To Wall Jack," or with a wall jack symbol.
  2. Make sure the Line Interface Unit (box that the phone cord plugs into) is fully seated into the back of the fax product.
  3. Remove any other devices from the line such as splitters, credit card machines, or telephone answering machines.
  4. Try sending and receiving faxes on a different fax line.
  5. Try using a different telephone cord.
  6. Have the phone company test your line for static or noise problems.
  7. Turn Error Correction Mode (ECM) off, if you encounter the same error repeatedly.
Regards
Riztech
Nov 26, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Does not recognize phone connection --can not send fax or receive fax--no connection. phone line is direct--works good
Hi. Here are some things you need to check: 1. Check the physical connection. Make sure the phone cable you're using is still in good condition. No obvious defects. 2. There are two phone ports behind the printer- Ext and Line. The phone jack from the wall should be plugged in to the Line port of the printer and not in the Ext. port. 3. Make sure to enter your Fax name and the correct Fax number in the printer. These are the basics on how to setup the printer for faxing. Hope these helps.
Mar 21, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Can't send or receive faxes ADSL
If you want to use the FAX - use the dedicated line to the FAX Machine..
Hi check the following steps
Problems with sending and receiving FAX
Check the TELEPHONE LINE
Check LIU
Remove the SPLITTER
Can try sending the Fax on Another Line
CHECK WITH DIFFERENT CABLE
Jan 22, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Hi my machine wont send or recieve a fax despite being properly connected. printing from computer is fine. has worked fine up until today
Hi check the following article to from HP
HP FAX ISSUES
Check LIU
Remove the SPLITTER
Jan 05, 2010 | HP Photosmart 2610 All-In-One InkJet...
Error codes 283 and 232 in received Faxes
basically error 232 indicates that a communication failure has occurred between the two machines
Following these steps may help resolving your issue
1. Make sure that the phone cord is plugged directly from the wall jack into the back port of the fax machine that is marked "Line" or "To Wall Jack", or that has a wall-jack symbol.
2. Verify that the line interface unit (LIU) (the box that the phone cord plugs into) is seated fully into the back of the fax.
3. Remove any other device from the line such as splitters, credit card machines, or telephone answering machines, and retry the fax communication.
5.Try using a different telephone cord.
7. Disable Error Correction Mode (ECM) if the same error occurs repeatedly.
Hope this helps.
thx
Jun 02, 2009 | HP LaserJet M1522nf Multifunction Printer...
Cannot receive a fax but can send one out
Make sure your phone lin is plugged in the jack on the machine that says LINE not the jack that says TEL or PHONE. I have seen this before. the unit gets a dial tone and can send but will not answer.
Hope this helps
Mar 11, 2009 | Canon Office Equipment & Supplies
Hi my canon mx310 will not fax any ideas
disconnect all equipments using the phone line (everything)
connect the fax directly to a wall jack (a working one)
Send a one page black and white text fax to 1-888-473-2963
When your fax is received by the Test Fax Service, a return fax will be generated to you within five minutes confirming that fax was received. This verifies that you can both send and receive a fax with your fax machine.
Nov 25, 2008 | Canon MX310 Office All-In-One Printer
Fax error cant receice fax
For Troubleshooting:
Disconnect all equipments using the phone line
Connect the FAX directly to the wall jack
Send a one page black and white text fax to 1-888-hpfaxme (1-888-473-2963).
When your fax is received by the HP Test Fax Service, we will generate a return fax to you within five minutes confirming that we received your fax. This verifies that you can both send and receive a fax with your fax machine.
Nov 25, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Cannot receive fax
1st is the LINE and second is to connect the telephone.
To send and receive fax, u must connect the line into the first jack.
Dec 26, 2007 | HP PSC 2210 All-In-One InkJet Printer
41 people viewed this question
k24674
jasbo
jasbo
