Question about Nikon Zoom Tele 80-400mm f/4.5-5.6 D-AF VR Auto Focus Lens
Lens will not focus
My autofocus on my 80-400 vr quite working this moring. I shot a few photos last night turned the carmera off left it on the tripod in the bedroom and got up early to photograph birds and the lens makes a sound like it is going to focus and doesnt. Put on a different lens and it works fine. Any thoughts?
    Sergeant:
  • 291 Answers
Your motor may have gone bad. Try sending it to PhotoTech Repair Service in NYC. They are Nikon authorized, and can do the repair under warranty if you still have it. Also if you join they're facebook page, they will give you a 10% discount.
Here is the facebook page link, it has everything you need to send it in.
http://www.facebook.com/pages/New-York-NY/PhotoTech-Repair-Service-Inc/102527215194
Posted on Apr 06, 2010
Nikon d5100 Blurry photos When I take photos of a party, at night, my photos are very blurry. How can I fix..
Use autofocus if you have a AF lens on it.
Usually you get a kit 18-55 AF lens that has a A/M switch on the side. The switch should be facing the A side so it's set on autofocus. Then you have 9 points on your viewfinder, those are the autofocus points. It should usually be set to center, because you usually want the object in center of your photo to not be blurry.
Remember to press the shutter button halfway and give some time for the autofocus to focus. Then you can press it all the way, you should have your photos nice and clear.
If you happen to have a manual focus lens, you should be watching through the viewfinder and turning the focus ring on the lens and determine if your object is in focus. It's hard at night, but get some practice at home when you have some more light so you get more familiar with the focus.
Dec 26, 2012 | Nikon D5100 Digital Camera
I am using Canon 1000D dslr for more than 18months, it was working fine until last Sunday. I went outside and started taking few shots... it was not focusing properly (or should I say not at all!) and...
The autofocus motor could be be broken, or the lens may not be communicating correctly with the camera. One thing that can help if it's not communicating correctly is to clean the lens contacts. If you take the lens off, you should see some gold plating on the plastic on the side of the lens that attaches to the camera. You can clean it by lighting rubbing it with a new, CLEAN pencil eraser. if that doesn't work, you may need a new lens unfortunately. best of luck!
Oct 05, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Nikkon 18-50 mm VR lens is not do the auto focus
Try to reset it by switching on the camera, pressing and holding 'INFO' button near the trigger and 'I' button in the left-hand side bottom. Hold the buttons together for few seconds till information on LCD screen appears. I hope your autofocus will work after this.
If it doesn't, carry your camera to the service personnel.
Jun 01, 2010 | Nikon D5000 Digital Camera
Autofocus stopped working
I fix these all the time for this problem, The focus motor is bad, Tony
May 23, 2010 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Autofocus does not work
I fix these all the time for this problem, The focus motor is bad, I charge 145.00 to fix these, Tony
May 11, 2010 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
My Nikon D80 will not autofocus
Fix your issue with these steps:
1. Try forcing the lens to rotate a fraction of a inch. This will sometimes help the problem. Or simply move the switch from M to A on the lens.
2. Try to switching to a single of the 11 auto focus points. Then try if there are specific points that are the problem.
3. If all auto focus points are fine, try updating the firmware or cleaning the sensors inside the camera behind the mirror. If a one or more points are out of order, also try cleaning the sensors behind the mirror.
4. Detatch the lens from the camera, by applying pressure on the release button and twisting the lens so it can be released. See picture
5. Set the camera selection wheel to manual (M), see picture
6. Turn the camera on, and start the liveView format. This will flip op the mirror inside the camera.
7. Take a dry can blower. Or if in lack, use an empty plastic bottle, without moisture inside, and use it to blow on the autofocus sensors.
They are located at the bottom under the mirror. NOTE Do not blow with your mouth, small amount of moisture will hit the CCD also located here.
8. Turn the camera off
9. Reattach the lens. Push the lens, white point to white point and turn the lens in place.
10. This worked for me, hope it also helped you ;)
For more solutions check Nikon D80 Manual
Apr 03, 2017 | Nikon Cameras
Focus is not working well on distances far away -endless position
Sounds to me like a hardware problem. Pls send ur lens to Nikon to have it looked into
Sep 13, 2009 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
I, too, am raising my hand on this?D40 with same autofocus problem, with all AF-S lens, 18-35 kit, 18-135, 18-200 VR, 50-200 VR. No solution after trying all above.
Please give more detail on this problem .
Have you tried another AFS or G lens.
Also the af switch could be turned off or the
back focus button could be set inthe custom menu .
Apr 05, 2009 | Nikon D40x Digital Camera
Sigma 70-300 Macro Motorised Lens for Nikon has stopped autofocus
If you just purchased the lens I would take it back sounds like the lens is jarred and defective should still be on warranty
Jan 22, 2009 | Nikon D80 Digital Camera with 18-135mm...
Nikon D200 refuses to auto focus with any lens it just doesn't do anything.
Does the camera body has a M/AFswitch? it would be located in front on the left side if that accidently gets changed to M your lens will not AF any more until you change it?? I know it sounds so simple but who knows!! Barry Brown
www.coralreefphotos.com
Oct 27, 2008 | Nikon D200 Digital Camera with 18-200mm...
Nikon Zoom Tele 80-400mm f/4.5-5.6 D-AF VR Auto Focus Lens Logo
69 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
