Question about Cuisinart DLC-10S Pro Classic Food Processor
Install Cuisinart stem cover
How do you install the stem cover on a cuisinart food processor?  I managed to get the old one off, but the new one binds up about 1/2 inch before it is fully seated. It appears that there are metal ribs on the stem that cut into the stem cover and help secure it, but I find I need to pound the new stem cover on with a hammer, and I am afraid of breaking something.
What is the proper installation process?
  • dannigirlo Mar 27, 2008
    I can't get the old one off! Can't imagine how I'll get the new one on! Cuisinart is no help!
I was able to replace my pieces thru Small I ordered new parts and the directions on how to remove the old stem and put the new one on.
Put a little vaseline in the rim of the new stem. Use a wooden block and a hammer or rubber mallet and lightly tap the new one into place.
Cuisinart called two weeks after the fact to say I have to send them the machine.....
Posted on Apr 06, 2008
The stem on my food processor is broken. Help to remove old part
Hi-I have a DLC-7, it looks a lot like yours. On my machine the stem is removed by pulling straight up. It is held only by the friction of a knurled section of the shaft, no threads or other fasteners. You could grip it lightly sideways with a pliers or vise-grips and then use hammer head to tap upwards on the side of the pliers. Squeeze the shaft firmly enough to grip it adequately, but not so hard as to crush it.
May 07, 2010 | Cuisinart DLC-8S Pro Custom Food Processor
Instructions for the food processor of my Cuisinart Duet
Place the gearbox on top of the blender/food processor
Place the work bowl over the spindle, with the handle facing the front of the machine - make sure the tabs lock into place.
Place the stem adapter on top of the spindle, then the blade.
Place the lid on top of the bowl, with the feed tube facing the back of the food processor. Then the pusher into the feed tube.
Here is the link to the user manual with visuals 9p.6 is most helpful):
-Tha Mp3 Doctor
Mar 23, 2009 | Cuisinart BFP-703 SmartPower Duet Food...
Replace the spindle on Cuisinart DLC-7 Food Processor
You need to pull the old one off, probably with vise grips and a lot of effort, and then order a new one. The new one is a tiny bit larger, so you'll probably need to order new blades, too. The new one slips right on, so there's no issue that would be the reverse of removing the old one. I read somewhere else that you have to pound hard to get the new one on, but that guy must have been speaking about the older model spindles. I was perplexed that the new one slipped right on so I pounded it to be sure and ended up breaking the tip of the new spindle and cracking the housing of the whole processor.
Jan 05, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
How to attach Cuisinart blades DLC 8 to DLC7 stem
The DLC-8 blades and the DLC-7 blades are not compatible. To attach the stem, first attach the stem to one of the compatible blades - the stem should day "DLC-7" for the DLC-7 blades - by inserting the first two tabs of the stem into the first two ridges of the blade connector - the left-most tab should be sticking out past the end of the blade connector - then slide the stem into place so that all tabs fit securely into the blade connector. Next, place the end with the blade up and insert the stem into the middle of the workbowl. There is a video for all Cuisinart food processors on the Cuisinart website.
-Tha Mp3 Doctor
Jan 01, 2009 | Food Processors
Cuisinart DLC-8 Plus Motor Shaft Cover broken.
Sure, you can find it on amazon, here: Amazon com Cuisinart Motor Shaft cover. Hope this was helpful. have a nice day
Nov 16, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
I have ordered a replacement stem for my DLC-7, the stationary stem that covers the motor shaft. I'm not sure how to remove the one currently on the unit.
Remove the pusher sleeve and lid from the work bowl first, then slide the work bowl out of the locked position. At this point, the stem should be exposed.
Nov 05, 2008 | Cuisinart DLC-5 Food Processor
I can't get the blades on the processor. there is a holder that somehow snaps into the blades before they are put on the processor
The regular chopping blade requires a stem adapter. The other blades require the detachable stem. I would double-check the user manaul to get a visual on it. Cuisinart food processors are great, but they are also the hardest to assemble.
-Tha Mp3 Doctor
Jul 19, 2008 | Cuisinart Limited Edition Metal MP14 Food...
Cuisinart Food processor
Go to the cuisinart website and you can buy replacement parts. You will have to buy the entire shaft not just the top but it is still good!
Mar 25, 2008 | Cuisinart DLC-10S Pro Classic Food...
Cuisinart DLC-10S Pro Classic Food Processor Logo
508 people viewed this question
Top Cuisinart Food Processors Experts
Colin Stickland
Colin Stickland
Craig Butler
Craig Butler
Rommel Balcita
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
