Question about Epson Stylus Photo RX700 All-In-One InkJet Printer
Getting a white border on printable cds
My printer is leaving a white unprinted band on the left upper quadrent of printable cds so I tried realigning the heads but how do you read the head alignment pattern for adjusting heads of the epson rx700 ? what exactly am I looking for when I view the print out and does repeated realignment help if its still off?
  • 3 more comments
  • calavandriel May 17, 2009
    yes I was using epson print cd which is why I was looking for a download of it so I could re-install it
  • calavandriel May 18, 2009
    I cannot get it right by that adjustment and I really think the software is possibly corrupt. So if you have the latest version it would be lovely to have a copy please.
  • calavandriel May 19, 2009
  • Alun Cox May 11, 2010
    Adjusting the print head alignment would not help you here. Which program are you using to print your CD's? Epson print CD or a different one?
    President:
  • 2,668 Answers
Once you press print in printcd yyou can adjust the print position, however if you really want the app I have 4 versions, v1.4, v1.5 & v1.6.
Let me know which one you want and I'll email it to you in a RAR file.
pippincp@msn.com
Posted on May 17, 2009
  • Alun Cox May 18, 2009
    Let me know where to send it to.
White unprinted band on the top end of printed sheet
Look to make sure your developer is flowing evenly on the mag roller. Next I would check the scoretron\grid it is the saw tooth blade that faces the drum.
Aug 18, 2014 | Sharp AR-5320 Black and White Copier
My MP830 leaves white horizontal bands when printing black & white documents. Color printing seems fine. Pattern 'F' is missing on the print alignment page.
You need to continually clean and deep clean and realign the black until the results are acceptable. Try manual alignment if the auto does not work. Also clean around the exit hole of the black ink cartidge with a cotton bud and isoproyl alcohol.
Nov 07, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Epson Stylus r220 prints with white lines... i installed a CIS and it worked fine for about 6 months, now i'm getting prints with white lines (or fine spots) i tried nozzle check, which comes out good......
Nozzle check must perfect for perfect output. There are tranversal lines at vertical straight lines that represent same point of head micro piezo. If tranversal lines no clog at all, but vertical straight lines not perfectly straight, the result not good (like horizontal white banding). Check it? Head aligment is for vertical banding. If your result is horizontal banding, you don't need to realign head. It's caused by some residual at the output of head sprayer. So, the spray of ink not straight to paper. Try to print with photo/best photo.
Jul 18, 2009 | Epson Stylus Photo R220 InkJet Printer
THE PICTURES ARE NOT CENTERD ON THE PAPER THERE IS A WHITE BAND APROX 1/4 TO 3/4 OF AN INCH LEFT UNPRINTED
Try opening a picture and printing it, except instead of clicking OK to print, find the button that says preferences and check the setting there. Adjusting these settings should help square up the photo on the paper. You may also try using an option in there called Defaults that will print using default settings and that should print just like it did when you first got the printer.
Jun 06, 2009 | HP Photosmart D7360 All-In-One InkJet...
White border on edge of print
The only way would be to use a bigger piece of paper and cut it down to the size you need...... The copier will always leave a white border a round the edges.... It is done so the toner can be fixed into the paper with out off setting or jamming
Mar 14, 2009 | Kyocera Mita Office Equipment & Supplies
Epson stylus r1800 problem with printing on cd/dvd
Try this :
Disconnect the printer from the computer.
Turn it off & make sure the CD/DVD tray is closed then turn it back on.
Here's generic instruction for you:
If you are receiving an error pertaining to the CD TRAY NOT BEING INSERTED CORRECTLY, please do the following:
Recommendations:
-Don't force the CD/DVD tray into the printer.
-Make sure your printer is powered on, and the output tray is in the upper position.
-Please ensure there is at least 3 inches of space behind the printer, or the CD tray may eject.
Included, are the correct CD/DVD loading instructions. Please follow the instructions below:
CD/DVD LOADING:
1. Ensure the printer is powered on. Remove any paper from the sheet feeder.
2. Push in the paper support extension on the printer, and close the paper support.
3. Push in the output tray extensions, but leave the tray open.
4. Lift the output tray. Place one hand on the top of the printer, and pull up on the output tray until it stops. Lay the tray down in the upper position.
5. Place the CD or DVD into the CD TRAY with the white (or printable) side facing up. Note: To print on small 8cm CDs, please place the small CD ring on the tray first, then place the CD inside the ring.
6. Slide the tray into the tray guides located in the output tray. Push in the guide until the arrow on the tray matches up to the arrow on the tray guide.
7. Press the PAPER button to load the CD/DVD into the printing position. The CD is correctly loaded when the printer's POWER button stops flashing.
General tips for CD and DVD printing:
-Burn data/video/images onto CDs or DVDs before attempting to print on them.
-Do not use thermal-printable or regular CDs or DVDs in the printer.
-Moisture or fingerprints on the printable surface of the CD may cause marks or smearing to appear after printing.
-All printable inkjet media is different. Some surfaces will absorb ink better than others. If output appears banded, faded, or streaky, print a Nozzle Check pattern to confirm that all colors of ink are printing completely. If the ink does not completely dry or smears after 24 hours curing time, you may need to use the Epson Print CD tools to adjust (lower) the print density.
-The only supported resolution for CD/DVD printing is 1440 dpi (aka "Photo")
-Borderless printing and printing on the "inner circle" (plastic around central hole) of CDs is not supported.
-Do not use the "print preview" feature provided by the Epson printer driver as it will only show the image on a blank field and does not offer a clear indicator of where the image will print.
-The Epson Print CD software works best with JPG images and may not import some TIFF images.
Sep 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
HELP
You may need to adjust your margins so that the bottom border shows. In other words, go to file> page layout>margins and adjust the bottom margin to a lower number, the check print preview.
If that does not work, try checking the border settings. Perhaps line weight has been set to 0 or color has been set to white or no color for the bottom, causing it to be invisible.
May 29, 2008 | Microsoft Office Computers & Internet
TH-50PX60U picture problem
Try to replace the Logic Scan board on the upper left side of your tv. The part no. is printed on the board and you can order it from Panasonic's Website. Also check the Service Manual for the part description and part no.
Oct 17, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Borders outside printable area
Adjust the margins in the software you are using.
Nov 08, 2006 | HP OfficeJet 5110 All-In-One InkJet...
Epson Stylus Photo RX700 All-In-One InkJet Printer Logo
112 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
