Question about Sony Ericsson K800i Cellular Phone
Stuck My phone is unable to turn off. I removed the USB cable connected to my computer while the phone was in transfer mode. I have to remove the battery to turn the phone off. When I start it up again, the screen is all white. Nothing happens...
  • 490 Answers
See dear ur software might hjave got corrupted u have to consult with ur vendor, what had happedn ur phone was in the transferring mode and u have plugged out the dat cable which has caused this problem to u reinstallation of the software will sort this problem out.
Posted on Oct 17, 2007
    Sergeant:
  • 452 Answers
This is a startup software problem...when u were transfering data and u suddenly removed the cable...that startup must have been corupted , kindly visit ur Sony Erricsson service center...dont visist a local vendor...
SOURCE:
LG Optimus L9 Screen blacks when charger/usb-to-computer cable plugged in.
sounds like you have a usb cable for charging only.You need a "2 way " usb cable,the kind used to transfer music and pictures to and from phone to computer.These one way cables are usually used in mobile chargering,as you don`t need to transfer things,just charge.Or you got wrong cable for your phone.
Mar 02, 2014 | LG Optimus Black Smartphone
My phone will not download pictures
If you want to transfer data, you can use U disk function of the phone. When you connect the device to the computer, you can find 3 options. 1. Insert the SD card and connect mobile phone using a USB cable;2. Click "USB connected";3. Choose "Turn on USB storage", and click "OK";4. If succeeded, there is a new removable disk on your computer interface.
Mar 03, 2013 | ZTE Avail-Z990 Avail At&t Unlocked Android...
How to import picture from Samsung camera PL120?
Transferring files by connecting the camera
as a removable disk
Connect the camera to your computer as a removable disk.
1 In Shooting or Playback mode, press [m].
2 Select Settings - PC Software - Off.
3 Turn off the camera.
4 Connect the camera to your computer with the USB
cable.
Transferring files with Intelli-studio
Intelli-studio will start automatically when you connect the camera
to your computer with the USB cable.
The battery will charge while the camera is connected to a computer with the
USB cable.
2 Select Settings - PC Software - On.
cable.
5 Turn on the camera.
• The computer recognizes the camera automatically and
Intelli-studio launches automatically.
6 Select a destination folder on your computer, and then
select Yes.
• New files stored on the camera will automatically transfer to
the selected folder.
• If your camera has no new files, the pop-up window for saving
new files will not appear.
Rate my answer if this helped you.
Sep 13, 2011 | Cameras
I can not transfer my photos from my cellphone to my computer . I have galaxy S GTI9000.
1. Connect your Galaxy S to computer using data cable. 2. By default it tries to open Kies. Press the home button to exit kies mode. 3. Push down notification bar. You will see usb icon on the notification. 4. Click on the icon and select mass memory or Disk Drive. 5. Now phone will appear as removable as removable drive in My computer. 6. Open the removable drive, Copy your photos to Computer.
The camera pictures are found in DCIM folder on memory card.
Jun 15, 2011 | Samsung Galaxy S GTI9000 Smartphone
Transfer pictures from phone to computer. I have the correct USB cable
I found an easy step by step to do this.
  1. Connect the USB cable to the computer and the phone.
  2. In the phone: When you attach the USB cable to the phone, a USB connection window appears, Select File transfer.
  3. On the computer: Open My Computer and your phone will be visible as a removable disk.
  4. Double-click the removable disk.
  5. Here you will find specific folders (depending on your phone model) where your pictures are stored.
  6. Drag and drop or copy and paste the picture from this folder to a folder on your computer.
  7. Disconnect the phone from the USB cable.
The picture is now transferred to your computer.
Hope this helps
Dec 22, 2010 | Sony Ericsson w580i Cellular Phone
Hi i have Nikon coolpix s3000 and im not able to transfer pics to my PC. Unable to know when my camera is on after attaching USB
Try connecting the cable to the Coolpix and then turn on the camera before plugging the USB cable into the computer.
Another way to transfer photos to the computer.
Remove the memory card from the Coolpix and insert the memory card into a USB memory card reader then connect it to the USB port on the computer. The computer will see this as an external storage device, you can then open the folder/s and copy the photos from the memory card to the computer.
Nov 01, 2010 | Computers & Internet
I can't get my photos from my cell phone to my laptop
If you are unable to use your memory card, your LG CU515 has a data cable connection which supports charging and mass storage mode.
Once you connect your phone to your PC with this cable, you should be able to transfer your pictures.
USB Connection Mode:
You can transfer files between a compatible PC to
the memory in your phone using the Mass
Storage. When you connect the phone to a PC
using the USB cable, this will be displayed as a
removable disk through Windows Explorer.
After connecting your phone to your computer with the data cable on your computer, click: START > Computer > and look for the phone in the list of storage devices.
On your PC, double click on the icon that identifies your phone - and locate the folder where the picture's on your phone are located. Then double click on your picture's folder on your PC. Simply drag and drop the pictures from your phone to your PC.
If you do not have a Data cable, one can be purchased either at your local cellular retail store or on eBay:
Click on this link:
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=lg+cu515+usb+cable&_sacat=See-All-Categories
Apr 07, 2010 | AT&T LG CU515 Cell Phone - Black
How do i transfer info from phone to computer?
it can be easily transferred by a data cable or bluetooth device.connect the cable to the pc from the phone & for nokia models select "data storage mode".then drag info. to the removable disc drive.enjoy..
Nov 26, 2009 | Samsung Lands Phones
I have albums in my pc and want to transfer the albums to my nokia 97?
Not sure if you meant photo album or music album??? Here is the steps for both, music first:
Transfer music from a
computer
You can use the following methods to transfer
music:
● To install Nokia Music to manage and organise
your music files, download the PC software from
www.music.nokia.com/download, and follow
the instructions.
● To view your device on a computer as a mass
memory device where you can transfer any data
files, make the connection with a compatible USB
data cable or Bluetooth connectivity. If you are
using a USB data cable, select Mass storage as
the connection mode.
● To synchronise music with Windows Media
Player, connect a compatible USB data cable, and
select Media transfer as the connection mode.
To change the default USB connection mode, select
Menu > Settings and Connectivity > USB > USB
connection mode.
This works for music, photos, or video:
Select Menu > Settings and Connectivity >
USB.
To have the device
ask the purpose of
the connection
each time a
compatible data
cable is connected,
select Ask on connection > Yes.
If the Ask on connection option is turned off or you
want to change the mode during an active
connection, select USB connection mode and from
the following:
● PC Suite — Use Nokia PC applications such as
Nokia Ovi Suite, and Nokia Software Updater.
● Mass storage — Transfer data between your
device and a compatible PC.
● Image transfer — Print images with a
compatible printer.
● Media transfer — Synchronise music with Nokia
Music or Windows Media Player.
Here is the link for your manual online:
http://nds1.nokia.com/phones/files/guides/Nokia_N97-1_UG_en.pdf
Oct 22, 2009 | Nokia N97 Cell Phone
DATA TRANSFER
Usually if there's an application going on to the phone, you will see an additional icon on the upper part of the screen.
Try to turn the phone off and remove the battery for about 20 seconds. Put the battery back and turn the phone on.
Reconnect your phone using the USB data cable to see if you will get the same problem.
Apr 14, 2009 | Nokia N82 Handheld
Sony Ericsson K800i Cellular Phone Logo
117 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Marvin
Marvin
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
