Question about Sharp R-1460 Microwave Oven
SHARP R-1460 MICROWAVE WAS USING ON A SANWICH IT DID NOT COMPLETE HEATING. NOW HAS NO POWER ON PAD ETC. OUTLET POWER IS OK
  • Sharp Master
  • 9,098 Answers
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Otherwise, it will need to be checked. I would suspect the magnetron thermostat, cavity thermostat and fuse.
To find helpful exploded view diagrams and get part numbers, you can just enter your full model number at the Sears parts site.
It's often more economical to order parts from Encompass here or you can call them toll-free at 866-779-5835.
Posted on May 20, 2009
I have a Sharp Model 1460A Microwave. It quit working while warming something up yesterday. Outlet is good. No power to unit at all. No light working, etc. Is there a fuse that I can check to see if it...
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Feb 07, 2011 | Sharp R-1460 Microwave Oven
My Sharp R-1460 Microwave Oven blanked out on me. I replaced the fuse and all lit up. When I went to turn it on to run, it blanked out again. Can you direct me to what the priblem might be?
I suggest the door switches are probbaly faulty. A job to say which one but you may find that it is caused by contamination or condensation.
Hope this helps.
Oct 28, 2010 | Sharp R-1460 Microwave Oven
My sharp R1650 has no power including light and vent
Thjere is a large Ceramic fuse on top of the chassis The outer cover has to be removed to access it The cost of replacement is about $20-30. But it would be better to know WHY this blew. replacing it may cause it to fail again immediately if there is a short circuit somewhere in the unit
Aug 15, 2009 | Sharp R-1460 Microwave Oven
The clock works & counts down but the microwave won't heat
  • Disconnect the power for 30 seconds. After restoring power, do not set the clock.
  • If your model has an ON/OFF clock display, you can choose not to have the time displayed. To choose this option, press the 0 pad for about three seconds. To Turn the display back on, press the 0 again.
Touch the clock pad. Enter in the correct time of day by touching the numbers in sequence. Touch the clock pad again.
Aug 03, 2009 | Sharp R-1460 Microwave Oven
Sharp Carousel Microwave R-1460A no power, door switch went first
You will want to replace the fuse and door switches. You will not be able to run it without replacing door switches. You do not need a new microwave. Door switches go bad, it has nothing to do with radiation.
Feb 19, 2009 | Sharp R-1460 Microwave Oven
Limited space for over the range microwave
You can call Sharp and ask them what current models if any will be drop-in replacements,either using the same mounting hardware or at least the same space.
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277) or visit them online.
Oct 19, 2008 | Sharp R-1460 Microwave Oven
R-1460
Check fuse. Remove 3 screws from the plastic grill located at along the top front of the unit. Remove the phillips head screw above the control panel. Slide up and pull out to partially remove control panel. You will see a white fuse. Replacement is CD3G 125v 20amp or BUSS ABC 20 or Little Fuse 314020 at 250v 20a. Radio shack caries the ABC.
May 12, 2008 | Sharp R-1460 Microwave Oven
Microwave Ovens Logo
582 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
