Question about HP LaserJet 2200dn Printer
HP 2200D Prints first page only
After installing a new roller kit and fuser the printer will only print the first page of a print job. This occurs when using the manual or the bottom paper tray. If the first job only has a single sheet then the second job simple won't print indicated by a flashing orange light. If I unplug the printer oftentimes it resets itself, but sometimes not again indicated by a flashing orange light. Thanks
  • beachdog May 22, 2009
    Is there any way to change the page size except manually changing the tabs in the paper tray? There is no viewing "window" on the printer. I have doubled checked the tabs in the second paper tray and they are correct. I also removed a tray and changed it out from a working printer. Still does not work properly. It also prints only the first page thru the manual feed tray.I was thinking that I had done something wrong when I installed a new roller kit or possibly the solenoid had gone bad. I have reinstalled the same roller kit again, but the same problem occurs.
  • angelus316
    angelus316 May 11, 2010
    Check that you select the right paper size of the printer properties
  • 1056 Answers
SOURCE: where to get fuser and rollers
Sorry it took me so long to get back to you, I've been out of town for a few days.
The parts you need for the 1600n are from Dell.
Part# N5796 - Fuser
Part# M5512 - ADF pickup arm roller
Posted on Aug 17, 2008
kcmetal9901
  • 102 Answers
SOURCE: HP laserJet 2100 prints blank from manual tray
I bet you have a bad USB wire.Change the wire and I suggest reinstalling the drivers.
Posted on Oct 31, 2008
  • 66 Answers
SOURCE: Paper jam error after last page prints
Hi Natoli3,
This could be a mis-match of paper sizes. Example, computer could be sending an A4 page to the printer. The paper size in the could be set to Letter. Ensure the 4 paper sizes match, in the computer - the document and printer driver; in the printer (change in control panel) and paper tray (adjust the physical side and length).
S88
Posted on Dec 18, 2008
Joed911
  • 4338 Answers
SOURCE: replaced fuser assembly and rollers
Here is the service manual , just in case you don't have it:
http://www2.yc.edu/content/its/desktopservices/Documents/LJ4000%20SM.pdf
Posted on Apr 07, 2009
SOURCE: Printer prints all pages on one sheet of paper
my printer prints overlap in all pages in one papaer
Posted on Aug 26, 2009
HP 5200 prints light at beggining of page then prints normal.
Print half way test page.,chk leading edge is same as you noticed?..
If yes: Chk transfer roller, clean it, chk side locks..if required replace it..
If no: chk fuser Teflon sleeve., is there toner deposits in surface? Replace Teflon sleeve if available or else replace fuser assembly..
Half way test page:
browse: http://www.printertechs.com/printer-troubleshooting/halfway-test
May 13, 2014 | HP LaserJet 5200 Printer
I keep on getting burnt streaks on my prints and words from the print in the background its hideous
The heated roller in the fuser is what will transfer this to your page. After switching off the pirnter and it has had time to cool you may be able to clean it with a rag moistened with a little methylated spirit, although you will not be able to rotate the roller fully without removing the fuser assembly from the printer. If the roller is physically damaged, eg. scoured, cleaning will not resolve the problem, the roller will need to be replaced. This usually occurs after a long life, so it is generally best to install a new or reconditioned fuser (includes new rollers, top and bottom and new heat lamp).
Mar 16, 2010 | Office Equipment & Supplies
I have a HP 8100 printer, when i print a configuration page, the top half of the sheet prints very light(blurr), while the bottom half of the sheet prints good. At first i thought it was the toner, so i...
There is a good chance the laser unit polygonal mirror is dirty. It spins at high speed and the lead edge generally gets dirty. Try removing it with care, cleaning the polygonal mirror and the lens's in the lazer unit
Oct 28, 2009 | HP LaserJet 8100 Printer - Refurbished
HP4345 MFP printer and the print quality is fuzzy. I put in a new toner cartridge and that didn't work and i also created a cleaning page and that didn't help. what next? just had the tech out here last...
Fuzzy print is mostly related to 3 items in your printer. 1 the toner cart. 2 fuser. 3 transfer roller. A fuser replacement is a normal fix for this problem. Check your PM kit status by printing a supplies status page. A PM kit will have a fuser, transfer roller and feed rollers. If the PM level is low ,order and replace kit. If not you may want to get a new fuser
Sep 23, 2009 | HP LaserJet 4345mfp Printer
I need to purchas one maintenance kit for HP 5100 laserjet printer. what contents should be there in manitenance kit. I got no authorised information about this on hp site
To ensure optimum print quality, the printer will prompt you to perform printer maintenance every 150,000 pages. When the PERFORM PRINTER MAINTENANCE message appears on the control panel, you will need to purchase a printer maintenance kit and install the new parts. To check the number of pages the printer has printed, print a configuration page.
To print a configuration page:
1 Press [Menu] until INFORMATION MENU appears.
2 Press [Item] until PRINT CONFIGURATION appears.
3 Press [Select] to print the configuration page.
To order the printer maintenance kit, contact an HP authorized service or support provider. (See the telephone support flyer included with the printer.)
The kit includes:
fuser assembly
transfer roller
feed rollers
necessary instructions
For more information on installing the printer maintenance kit, see the instructions that accompany it.
Sep 07, 2009 | HP LaserJet 5100 Printer
Print issues
Look at the fuser, and see if you can see a bad area on the fuser roller, matching the position on the paper. I suspect a bad fuser. Fusers need to be replaced periodically, and typically via a maint kit which replaces several feed rollers as well.. How many pages have been printed.. Print a config sheet to display this information.
Nov 04, 2008 | HP LaserJet 3030 All-In-One Printer
Hp laserjet 2200d
If the toner smears after the page comes out of the printer you may need a new fuser. The fuser is the heating unit in the printer and can usually be seen from opening the back door. Check and see if it has a line worn down the same side as the mark on your pages.
Feb 15, 2008 | HP LaserJet 2200D Printer
Hp 4300 laserjet
Does it jam at the fuser when doing a single print?
These machines have a Maintenance kit required every 200 000 prints, these MK's include all feed rollers, a transfer roller and the entire fuser assy. To replace the kit fixes all issues I've seen in these printers besides when the cartridge affects print quality.
If it is jamming at the fuser on a single print done via the printer operations panel, and your paper is fresh, it could only be the feed roller having trouble gripping the paper or the fuser not turning/stuffed.
Feed Kit, I have my doubts as to this being your problem
Maintenance Kit Fixes 98% of the time
Was is noisy before it died?
I have seen a few with stuffed fuser drive gears but not many and customers could hear it wearing.
How many prints since last MK? via keypad print a configuration page, count is there ie pages since last maintenance xxxxxx
Jan 31, 2008 | HP LaserJet 4300n Printer
HP LASERJET 4250n PRINTER-PROBLEM WITH PAPER JAMS AND "FUSER ERROR"
Put a maintence kit in your machine, easy install, everything just clicks in, Every 200 000 prints it should be done, it includes the fuser, all feed rollers, sep pad and transfer roller.
These are great printing machine, they only ever need the MK and on this model a fuser drive gear wears and get noisy, but once that has been done once, it is ok from then on.
KIts seem expensive but they are meant to last 200 000 prints and usally do. These are one of the best most reliable printers in the market.
fee693c.jpg LINK to part info
Jan 09, 2008 | HP 4250 Monochrome LaserJet Printer
Bad prints
You may have a repeatative defect caused by the fuser, toner cartridge or other rollers. Try to ascertain the distance between each occurance that will point to the offending assy.
Oct 22, 2007 | HP LaserJet 4350 Printer
HP LaserJet 2200dn Printer Logo
201 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
